    Changing fan out from out9 to out5 has no effect
    709
    • Vetiundefined
      Veti @Snippy
      @Snippy said in Changing fan out from out9 to out5 has no effect:
      1=gnd so black
      2=12v
      3=tach
      4=not connected
      if you have connected the fan like that, no wonder its not working
      Snippyundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian
        OK, from the Wiki: https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram
        "4-pin KK connectors with offset spigot OUT_4 thru OUT_6: these are intended for PWM-controllable fans. The connector fits a standard PC-type 4-pin PWM fan. Alternatively, a 2-pin fan may be connected between the V_OULCn pin (+ve) and the OUT_n_NEG pin (-ve). "
        It looks like you should be able to start with two wires connected to your fan going to (BLACK)-> OUT5 and (RED) to V_OUTLC1
        Is that how you have it connected?
        It seems like you <may> have the fan connected to +12 and GND which will make it run all the time.
        I've never used a DUET3 (I have a DUET2) so I may be mistaken here, but this gets a lot of people, so hopefully you've done the same thing others have.
        • Vetiundefined
          Veti
          well he said his wiring is not the problem, so
          alankilianundefined 1 Reply Last reply Reply Quote -1
          • Snippyundefined
            Snippy @Veti
            @Veti Well it is spinning fine, i just cant controll it in webcontroll.
            • Vetiundefined
              Veti @Snippy
              yes that is because of your wiring
                alankilian @Veti
                @Veti said in Changing fan out from out9 to out5 has no effect:
                We all assume we know which part of our work is correct, so let's try to remain helpful.
                Because LORD KNOWS I've been wrong so many times on forums where I'm asking for help I should get spanked.
                • Vetiundefined
                  Veti
                  that is why i asked for a picture so i can be sure that his wiring is incorrect
                    alankilian
                    @alankilian said in Changing fan out from out9 to out5 has no effect:
                    @Snippy
                    Try this and see if it works for you.
                    • Snippyundefined
                      Snippy @alankilian
                      @alankilian Still running at 100% cant controll it from webcontroll.
                      • Snippyundefined
                        Snippy
                        And i cant run it from Out7-9 since fans in Out8-9 are 24v.
                        • Snippyundefined
                          Snippy @Veti
                          @Veti it is correct...
                          • Snippyundefined
                            Snippy
                            Got it to work, now the broblem is that the fans stop spinning at 70% in webcontroll, full blast at 100% and about 50% speed when set to 94% in webcontroll.
                            Vetiundefined 1 Reply Last reply Reply Quote 1
                            • Vetiundefined
                              Veti @Snippy
                              Got it to work,
                              so what was wrong?
                              try adjusting the frequency q.
                              try 10 , 50, 5000 25000
                              Snippyundefined 1 Reply Last reply Reply Quote 1
                              • Snippyundefined
                                Snippy @Veti
                                @Veti no idea, did the old ''have you tried turning it on and off again'' for about 5 times and told the printer i will build a new one so i think the tea and bisquits chip in the duet started to listen.
                                • Snippyundefined
                                  Snippy
                                  yes 10 was good, 1d0a835c-d1e7-4202-a4d2-cc5ca8c4c88a.jpg Now all i need to do is design and simulate the cooling pipes.
                                  • Snippyundefined
                                    Snippy
                                    Thanks for the help.
                                      alankilian @Snippy
                                      I'm glad you got it worked out.
                                      • Snippyundefined
                                        Snippy
                                        These duet boards are great if you dont haveto touch the settings, it seems to allways open a can of worms that requires a sacrifice or two to appease the great one.
