    Error M587:Failed to add SSID to remembered list.
    Duet Web Control
    1.0k
    • Hiroakiundefined
      Hiroaki @Hiroaki
      @Hiroaki The version is 1.04.
        droftarts administrators @Hiroaki
        @Hiroaki The M122 reply has been cut off, and the WiFi diagnostics is missing. If you are connecting with YAT:
        Set YAT to use <LF> as the end of line character. This will improve the readability of the messages coming from the Duet. Click "Text Settings" in the "Terminal Settings" and change "EOL sequence:" to <LF>. Click "OK" to close Text Settings. Click "OK" again to close Terminal Settings.
        Hiroakiundefined 2 Replies Last reply Reply Quote 0
        • Hiroakiundefined
          Hiroaki @droftarts
          @droftarts Thank you.
          This is it.
          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later + DueX5
          Board ID: 08DJM-956GL-M43T0-6JKDL-3S86P-994YQ
          Used output buffers: 1 of 24 (2 max)
          Static ram: 25712
          Dynamic ram: 93980 of which 84 recycled
          Exception stack ram used: 264
          Never used ram: 11032
          Tasks: NETWORK(ready,1884) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3836) IDLE(ready,160)
          Owned mutexes:
          Last reset 00:06:48 ago, cause: power up
          Last software reset time unknown, reason: User, spinning module GCodes, available RAM 10896 bytes (slot 2)
          Error status: 0
          Free file entries: 10
          MCU temperature: min 29.5, current 32.0, max 65.8
          Supply voltage: min 0.0, current 0.5, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
          Driver 0: ok, SG min/max not available
          Driver 1: ok, SG min/max not available
          Driver 2: ok, SG min/max not available
          Driver 3: ok, SG min/max not available
          Driver 4: ok, SG min/max not available
          Driver 5: ok, SG min/max not available
          Driver 6: ok, SG min/max not available
          Driver 7: ok, SG min/max not available
          Driver 8: ok, SG min/max not available
          Driver 9: ok, SG min/max not available
          Cache data hit count 681994076
          Slowest loop: 1.58ms; fastest: 0.05ms
          Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
          === DDARing ===
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is idle in state(s) 0
          serial is ready with "M122" in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 0.84ms; fastest: 0.00ms
          HTTP sessions: 0 of 8
          • WiFi -
            Network state is starting
            WiFi module is disabled
            ok
          • Hiroakiundefined
            Hiroaki @droftarts
            @droftarts
            M552 s-1
            WiFi module stopped
            ok
            M552 s0
            ok
            M122
            then it was still
            • WiFi -
              ok
              @Hiroaki Send M552 S-1, then M122, M552 S0, then M122, and M552 S1, then M122. This is what the response from my Duet 2 WiFi looks like (you can just copy the WiFi part at the end):
              M552 S-1
              WiFi module stopped
              ok
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later
              Board ID: 08DGM-9T6BU-FG3SD-6JKD4-3S86N-KAMHF
              -WiFi -
              Network state is disabled
              ok
              M552 S0
              ok
              WiFi module started
              M122
              -WiFi -
              Network state is running
              WiFi module is idle
              WiFi firmware version 1.23
              WiFi MAC address a0:20:a6:31:b4:b9
              WiFi Vcc 3.36, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 30176
              ok
              M552 S1
              ok
              WiFi module is connected to access point BTWholeHome-XXX, IP address 192.168.0.12
              M122
              -WiFi -
              WiFi Vcc 3.37, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 25568
              WiFi IP address 192.168.0.12
              WiFi signal strength -43dBm, reconnections 0, sleep mode modem
              ok
              If you're not getting something similar, I'd guess that the WiFi module has failed. The usual reason for this is a power surge on the 3.3V line; the WiFi board and SD card are often the first to fail if this has happened, but can protect the main processor from failing.
              It is possible that the WiFi module firmware has not flashed correctly. Try downloading a fresh DuetWiFiServer-1.23.bin from https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1 and upload it to the 'sys' folder on the SD card, then send M997 S1.
              • beachtecundefined
                beachtec
                Hello @Hiroaki... I have had this issue myself a few times. The advice here did solve it; but I had to do it a couple of times. Re-flashing the firmware more than once might be necessary. I also found that in BOSSA, using the setting "erase all" seemed to yield the best results. Good luck to you!
                Hiroakiundefined 1 Reply Last reply Reply Quote 0
                • Hiroakiundefined
                  Hiroaki @droftarts
                  @droftarts Thank you. As it's getting late night, I will do it tomorrow.
                  By the way do you think it's possible to change the wifi module ?
                  • Hiroakiundefined
                    Hiroaki @beachtec
                    @beachtec Thank you. I will try tomorrow. It's 0:21AM ...
                    Best Regards
                    • Hiroakiundefined
                      Hiroaki @droftarts
                      @droftarts
                      One question .
                      Upload Duetwifiserver-1.23.bin to the SYS not WWW folder?
                      Regards
                        @Hiroaki said in Error M587:Failed to add SSID to remembered list.:
                        One question .
                        Yes, firmware updates go in the 'sys' folder. The 'www' folder is for DWC components.
                        • Hiroakiundefined
                          Hiroaki @droftarts
                          @droftarts ok Thank you.
                            I think you'll need to rename the file and remove the -1.23 part so that the final file name is just DuetWiFiServer.bin
                            • Hiroakiundefined
                              Hiroaki @droftarts
                              @droftarts Hello
                              Thank you so much.
                              I could solve the problem.
                              sent M997 S1 and then ok.
                              I appreciate that.
                              Thank you
                              • Hiroakiundefined
                                Hiroaki @Phaedrux
                                @Phaedrux Thank you.
                                This was also helped me !
                                Thank you.
