    Error M587:Failed to add SSID to remembered list.
    Duet Web Control
    1.0k
    • Hiroakiundefined
      Hiroaki @jay_s_uk
      @jay_s_uk Hello Thank you for your comment.
      I have done it, but still the same...
      • Hiroakiundefined
        Hiroaki @droftarts
        @droftarts Hello. Thank you for your comment, I did it.
        When I send M552 S-1, the light of the wifi module was turned off.
        When I sent M552 S0, it's turned on again.
        But when I sent M587 S"ooxx" P"ooxx" it's still the same...
        Only One I can't get is "Idle mode" I put....
        Hiroakiundefined 1 Reply Last reply Reply Quote 0
        • Hiroakiundefined
          Hiroaki @Hiroaki
          @Hiroaki Sorry "Idle mode" you put.
            droftarts administrators @Hiroaki
            @Hiroaki Can you send M122 and post full reply. How old is the Duet?
            And what board revision? eg 1.02, 1.04c
            • Hiroakiundefined
              Hiroaki @droftarts
              @droftarts
              Hello The board is quite new.
              I bought it about two months ago, but as I have been building the machine, it's still like new.
              The answer of M122 is as floows. Thank you.
              === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later + DueX5<LF>Board ID: 08DJM-956GL-M43T0-6JKDL-3S86P-994YQ<LF>Used output buffers: 1 of 24 (2 max)<LF>=== RTOS ===<LF>Static ram: 25712<LF>Dynamic ram: 93980 of which 84 recycled<LF>Exception stack ram used: 264<LF>Never used ram: 11032<LF>Tasks: NETWORK(ready,1884) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3824) IDLE(ready,160)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:00:14 ago, cause: power up<LF>Last software reset time unknown, reason: User, spinning module GCodes, available RAM 10896 bytes (slot 2)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 50.4, current 52.0, max 56.3<LF>Supply voltage: min 0.5, current 0.5, max 0.8, under voltage events: 0, over vol[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
              • Hiroakiundefined
                Hiroaki @Hiroaki
                @Hiroaki The version is 1.04.
                  @Hiroaki The M122 reply has been cut off, and the WiFi diagnostics is missing. If you are connecting with YAT:
                  Set YAT to use <LF> as the end of line character. This will improve the readability of the messages coming from the Duet. Click "Text Settings" in the "Terminal Settings" and change "EOL sequence:" to <LF>. Click "OK" to close Text Settings. Click "OK" again to close Terminal Settings.
                  Hiroakiundefined 2 Replies Last reply Reply Quote 0
                  • Hiroakiundefined
                    Hiroaki @droftarts
                    @droftarts Thank you.
                    This is it.
                    Static ram: 25712
                    Tasks: NETWORK(ready,1884) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3836) IDLE(ready,160)
                    Owned mutexes:
                    Last reset 00:06:48 ago, cause: power up
                    Error status: 0
                    MCU temperature: min 29.5, current 32.0, max 65.8
                    Supply voltage: min 0.0, current 0.5, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
                    Driver 0: ok, SG min/max not available
                    Driver 1: ok, SG min/max not available
                    Driver 2: ok, SG min/max not available
                    Driver 3: ok, SG min/max not available
                    Driver 4: ok, SG min/max not available
                    Driver 5: ok, SG min/max not available
                    Driver 6: ok, SG min/max not available
                    Driver 7: ok, SG min/max not available
                    Driver 8: ok, SG min/max not available
                    Driver 9: ok, SG min/max not available
                    Cache data hit count 681994076
                    Slowest loop: 1.58ms; fastest: 0.05ms
                    Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                    === DDARing ===
                    Heater 1 is on, I-accum = 0.0
                    Segments left: 0
                    Movement lock held by null
                    http is idle in state(s) 0
                    telnet is idle in state(s) 0
                    file is idle in state(s) 0
                    serial is ready with "M122" in state(s) 0
                    aux is idle in state(s) 0
                    daemon is idle in state(s) 0
                    queue is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 0.84ms; fastest: 0.00ms
                    HTTP sessions: 0 of 8
                    • WiFi -
                      Network state is starting
                      WiFi module is disabled
                      ok
                    • Hiroakiundefined
                      Hiroaki @droftarts
                      @droftarts
                      M552 s-1
                      WiFi module stopped
                      ok
                      M552 s0
                      ok
                      M122
                      then it was still
                      • WiFi -
                        ok
                        @Hiroaki Send M552 S-1, then M122, M552 S0, then M122, and M552 S1, then M122. This is what the response from my Duet 2 WiFi looks like (you can just copy the WiFi part at the end):
                        M552 S-1
                        WiFi module stopped
                        ok
                        M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later
                        Board ID: 08DGM-9T6BU-FG3SD-6JKD4-3S86N-KAMHF
                        -WiFi -
                        Network state is disabled
                        ok
                        M552 S0
                        ok
                        WiFi module started
                        M122
                        -WiFi -
                        Network state is running
                        WiFi module is idle
                        WiFi firmware version 1.23
                        WiFi MAC address a0:20:a6:31:b4:b9
                        WiFi Vcc 3.36, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 30176
                        ok
                        M552 S1
                        ok
                        WiFi module is connected to access point BTWholeHome-XXX, IP address 192.168.0.12
                        M122
                        -WiFi -
                        WiFi Vcc 3.37, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 25568
                        WiFi IP address 192.168.0.12
                        WiFi signal strength -43dBm, reconnections 0, sleep mode modem
                        ok
                        If you're not getting something similar, I'd guess that the WiFi module has failed. The usual reason for this is a power surge on the 3.3V line; the WiFi board and SD card are often the first to fail if this has happened, but can protect the main processor from failing.
                        It is possible that the WiFi module firmware has not flashed correctly. Try downloading a fresh DuetWiFiServer-1.23.bin from https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1 and upload it to the 'sys' folder on the SD card, then send M997 S1.
                        • beachtecundefined
                          beachtec
                          Hello @Hiroaki... I have had this issue myself a few times. The advice here did solve it; but I had to do it a couple of times. Re-flashing the firmware more than once might be necessary. I also found that in BOSSA, using the setting "erase all" seemed to yield the best results. Good luck to you!
                          • Hiroakiundefined
                            Hiroaki @droftarts
                            @droftarts Thank you. As it's getting late night, I will do it tomorrow.
                            By the way do you think it's possible to change the wifi module ?
                            • Hiroakiundefined
                              Hiroaki @beachtec
                              @beachtec Thank you. I will try tomorrow. It's 0:21AM ...
                              Best Regards
                              • Hiroakiundefined
                                Hiroaki @droftarts
                                @droftarts
                                One question .
                                Upload Duetwifiserver-1.23.bin to the SYS not WWW folder?
                                Regards
                                  @Hiroaki said in Error M587:Failed to add SSID to remembered list.:
                                  One question .
                                  Yes, firmware updates go in the 'sys' folder. The 'www' folder is for DWC components.
                                  • Hiroakiundefined
                                    Hiroaki @droftarts
                                    @droftarts ok Thank you.
                                      I think you'll need to rename the file and remove the -1.23 part so that the final file name is just DuetWiFiServer.bin
                                      • Hiroakiundefined
                                        Hiroaki @droftarts
                                        @droftarts Hello
                                        Thank you so much.
                                        I could solve the problem.
                                        sent M997 S1 and then ok.
                                        I appreciate that.
                                        Thank you
                                        • Hiroakiundefined
                                          Hiroaki @Phaedrux
                                          @Phaedrux Thank you.
                                          This was also helped me !
                                          Thank you.
