    Error M587:Failed to add SSID to remembered list.
    Duet Web Control
    1.0k
    • Hiroakiundefined
      Hiroaki @droftarts
      @droftarts
      Hello The board is quite new.
      I bought it about two months ago, but as I have been building the machine, it's still like new.
      The answer of M122 is as floows. Thank you.
      === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later + DueX5<LF>Board ID: 08DJM-956GL-M43T0-6JKDL-3S86P-994YQ<LF>Used output buffers: 1 of 24 (2 max)<LF>=== RTOS ===<LF>Static ram: 25712<LF>Dynamic ram: 93980 of which 84 recycled<LF>Exception stack ram used: 264<LF>Never used ram: 11032<LF>Tasks: NETWORK(ready,1884) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3824) IDLE(ready,160)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:00:14 ago, cause: power up<LF>Last software reset time unknown, reason: User, spinning module GCodes, available RAM 10896 bytes (slot 2)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 50.4, current 52.0, max 56.3<LF>Supply voltage: min 0.5, current 0.5, max 0.8, under voltage events: 0, over vol[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
      Hiroakiundefined 1 Reply Last reply Reply Quote 0
      • Hiroakiundefined
        Hiroaki @Hiroaki
        @Hiroaki The version is 1.04.
          droftarts administrators @Hiroaki
          @Hiroaki The M122 reply has been cut off, and the WiFi diagnostics is missing. If you are connecting with YAT:
          Set YAT to use <LF> as the end of line character. This will improve the readability of the messages coming from the Duet. Click "Text Settings" in the "Terminal Settings" and change "EOL sequence:" to <LF>. Click "OK" to close Text Settings. Click "OK" again to close Terminal Settings.
          Hiroakiundefined 2 Replies Last reply Reply Quote 0
          • Hiroakiundefined
            Hiroaki @droftarts
            @droftarts Thank you.
            This is it.
            Static ram: 25712
            Tasks: NETWORK(ready,1884) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3836) IDLE(ready,160)
            Owned mutexes:
            Last reset 00:06:48 ago, cause: power up
            Error status: 0
            MCU temperature: min 29.5, current 32.0, max 65.8
            Supply voltage: min 0.0, current 0.5, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
            Driver 0: ok, SG min/max not available
            Driver 1: ok, SG min/max not available
            Driver 2: ok, SG min/max not available
            Driver 3: ok, SG min/max not available
            Driver 4: ok, SG min/max not available
            Driver 5: ok, SG min/max not available
            Driver 6: ok, SG min/max not available
            Driver 7: ok, SG min/max not available
            Driver 8: ok, SG min/max not available
            Driver 9: ok, SG min/max not available
            Cache data hit count 681994076
            Slowest loop: 1.58ms; fastest: 0.05ms
            Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
            === DDARing ===
            Heater 1 is on, I-accum = 0.0
            Segments left: 0
            Movement lock held by null
            http is idle in state(s) 0
            telnet is idle in state(s) 0
            file is idle in state(s) 0
            serial is ready with "M122" in state(s) 0
            aux is idle in state(s) 0
            daemon is idle in state(s) 0
            queue is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 0.84ms; fastest: 0.00ms
            HTTP sessions: 0 of 8
            • WiFi -
              Network state is starting
              WiFi module is disabled
              ok
            • Hiroakiundefined
              Hiroaki @droftarts
              @droftarts
              M552 s-1
              WiFi module stopped
              ok
              M552 s0
              ok
              M122
              then it was still
              • WiFi -
                ok
                @Hiroaki Send M552 S-1, then M122, M552 S0, then M122, and M552 S1, then M122. This is what the response from my Duet 2 WiFi looks like (you can just copy the WiFi part at the end):
                M552 S-1
                WiFi module stopped
                ok
                M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later
                Board ID: 08DGM-9T6BU-FG3SD-6JKD4-3S86N-KAMHF
                -WiFi -
                Network state is disabled
                ok
                M552 S0
                ok
                WiFi module started
                M122
                -WiFi -
                Network state is running
                WiFi module is idle
                WiFi firmware version 1.23
                WiFi MAC address a0:20:a6:31:b4:b9
                WiFi Vcc 3.36, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 30176
                ok
                M552 S1
                ok
                WiFi module is connected to access point BTWholeHome-XXX, IP address 192.168.0.12
                M122
                -WiFi -
                WiFi Vcc 3.37, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 25568
                WiFi IP address 192.168.0.12
                WiFi signal strength -43dBm, reconnections 0, sleep mode modem
                ok
                If you're not getting something similar, I'd guess that the WiFi module has failed. The usual reason for this is a power surge on the 3.3V line; the WiFi board and SD card are often the first to fail if this has happened, but can protect the main processor from failing.
                It is possible that the WiFi module firmware has not flashed correctly. Try downloading a fresh DuetWiFiServer-1.23.bin from https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1 and upload it to the 'sys' folder on the SD card, then send M997 S1.
                • beachtecundefined
                  beachtec
                  Hello @Hiroaki... I have had this issue myself a few times. The advice here did solve it; but I had to do it a couple of times. Re-flashing the firmware more than once might be necessary. I also found that in BOSSA, using the setting "erase all" seemed to yield the best results. Good luck to you!
                  • Hiroakiundefined
                    Hiroaki @droftarts
                    @droftarts Thank you. As it's getting late night, I will do it tomorrow.
                    By the way do you think it's possible to change the wifi module ?
                    • Hiroakiundefined
                      Hiroaki @beachtec
                      @beachtec Thank you. I will try tomorrow. It's 0:21AM ...
                      Best Regards
                      • Hiroakiundefined
                        Hiroaki @droftarts
                        @droftarts
                        One question .
                        Upload Duetwifiserver-1.23.bin to the SYS not WWW folder?
                        Regards
                          @Hiroaki said in Error M587:Failed to add SSID to remembered list.:
                          One question .
                          Yes, firmware updates go in the 'sys' folder. The 'www' folder is for DWC components.
                          • Hiroakiundefined
                            Hiroaki @droftarts
                            @droftarts ok Thank you.
                              I think you'll need to rename the file and remove the -1.23 part so that the final file name is just DuetWiFiServer.bin
                              • Hiroakiundefined
                                Hiroaki @droftarts
                                @droftarts Hello
                                Thank you so much.
                                I could solve the problem.
                                sent M997 S1 and then ok.
                                I appreciate that.
                                Thank you
                                • Hiroakiundefined
                                  Hiroaki @Phaedrux
                                  @Phaedrux Thank you.
                                  This was also helped me !
                                  Thank you.
