    duet3d sd not detected, rejects http, com5 denied
    2.8k
    • radcadundefined
      radcad @Phaedrux
      @Phaedrux
      for firmware update is this the file i need from the gethub
      Duet2and3Firmware-3.2.zip
        Only update the firmware if you've got a reliable connection to the web interface now.
        If you still have access to DWC. Upload these 3 zip files, one at a time. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
        That will get your firmware and DWC up to date.
        For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
        https://configtool.reprapfirmware.org/Start
        radcadundefined 2 Replies Last reply Reply Quote 0
        • radcadundefined
          radcad @Phaedrux
          @Phaedrux
          YAT and web interface are connected
          • radcadundefined
            radcad @Phaedrux
            @Phaedrux
            so i put these files on the sd card then run the M commands ?
              No. Upload them to the system tab in the web interface. One zip file at a time. Start with 2.05.1. It will prompt you to update. And reboot.
              radcadundefined 1 Reply Last reply Reply Quote 0
              • radcadundefined
                radcad @Phaedrux
                @Phaedrux
                Failed to upload network error
                M552 S1 say wifi is ok
                  And you're trying to upload it to the system tab?
                  Can you go to the console tab and send M122 and copy and paste the results?
                  • radcadundefined
                    radcad @Phaedrux
                    This post is deleted!
                      In the system tab you'd find your config.g and the homing files, etc.
                      That's where you would upload Duet2Firmware-2.05.1.zip
                      • radcadundefined
                        radcad @Phaedrux
                        @Phaedrux
                        yes in the system tab under file management on the left, is where I tried to upload it, the file does not show up in other tabs
                          And you're using the upload file button?
                          Can you post a screen shot of the error?
                          • radcadundefined
                            radcad @Phaedrux
                            @Phaedrux
                            what file format do i need to save the screen shot as to upload it here?
                              If you're on windows you can use the print screen button on your keyboard and paste that into paint and save it as a jpeg.
                              • radcadundefined
                                radcad
                                • radcadundefined
                                  radcad
                                  I kept retrying it over and over and eventually it uploaded.
                                  trying to get the 2nd file to load now. it wont get past the 4th file tho
                                  WiFi module is connected to access point 111111 IP address 11111111
                                  Trying to connect at 230400 baud: success
                                  Erasing 4096 bytes...
                                  Erasing 212992 bytes...
                                  Uploading file...
                                  5% complete
                                  10% complete
                                  15% complete
                                  20% complete
                                  25% complete
                                  30% complete
                                  35% complete
                                  40% complete
                                  45% complete
                                  50% complete
                                  55% complete
                                  60% complete
                                  65% complete
                                  70% complete
                                  75% complete
                                  80% complete
                                  85% complete
                                  90% complete
                                  95% complete
                                  Upload successful
                                  • radcadundefined
                                    radcad
                                    2nd file finally uploaded
                                      Are you uploading the zip file as is? Don't extract it first.
                                      • radcadundefined
                                        radcad @Phaedrux
                                        @Phaedrux
                                        Im not unzipping it. I go to upload the file it fails.... upload file it fails...
                                        upload the file it loads 1/17 then fails... upload again 2/17 then fails and eventually it loads all the files then updates. usually between files Im having to wait some time to try the next file or it doesn't work at all.
                                        im working on the 3rd zip now
                                        Im having more trouble with the 3rd then the first 2
                                        I can only get it to 5 / 55 files before failing
                                          When and where did you purchase the Duet?
                                          Uploading the zip files shouldn't be this painful. Could be SD card writing problem or it could be the wifi module.
                                          • radcadundefined
                                            radcad @Phaedrux
                                            @Phaedrux
                                            i just got it a few days ago and i ordered it from matter hackers because the duet page was sold out.
