    RepPanel - A DIY alternative to the PanelDue with WiFi support
    Third-party software
    39
    243
    30.5k
    • JohnOCFIIundefined
      JohnOCFII @seeul8er
      @seeul8er said in RepPanel - A DIY alternative to the PanelDue with WiFi support:
      @JohnOCFII Great to see you got it working now 🙂 If you click the "wifi-fan" RepPanel displays its IP address.
      It even shows signal strength. I like it!
      A couple of questions. First, based on the notes here and on GitHub I went through and added a Filament entry, and also trimmed my macro directory back to 16 items. I also trimmed my various print job directories back to 16 as well. These all seemed to help stability, as my RepPanel was freezing after a few second to minutes before I did that.
      Also, I noticed that the Hot-End / Extruder title does not show up on the attached screen shot. Second thing, while I have temperatures to choose from for Bed (active and standby) for the Hot-end I only see temps in the standby window). Curious...
      I'm doing my first print now, initiated from RepPanel! 🙂
      Thanks for this creative solution!
        JohnOCFII
        Oh -- and the password was a red herring. It works fine without an M551 password.
        • seeul8erundefined
          seeul8er
          What is your "Hotend-Name"?
          How many temperatures do you have configured?
          The temperatures should come from the Web Control config file. A user reported that there are issues if the file is too large and RepPanel can not cache it. Go to your Duet Web control and clear the command history. You do that by entering something in the command console and wait for the auto suggestions. Then you can select the trashcan to delete an entry. That may fix some issues.
          JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
            JohnOCFII @seeul8er
            @seeul8er Clearing out the command auto-complete buffer (I probably had 800 entries) allowed my hot-end temperatures to show up. So yeah -- probably some memory contention somewhere there.
            The odd thing is -- on the RepPanel 0°C shows up seven times. DWC seems to show a "normal" number of entries.
            I'll look through my config to see if anything looks odd to me.
            Screen Shot 2020-12-08 at 10.45.00 AM.png Screen Shot 2020-12-08 at 10.50.15 AM.png IMG_2086.jpeg
            • seeul8erundefined
              seeul8er
              @JohnOCFII Yeah, we are very limited on the RAM side. The Duet Config often just breaks the bank.
              Your temperatures are alright. RepPanel displays 14 temperatures at any times. If you got less, then all the remaining temps are filled up with 0°C. That is a little workaround which allows the application to use a matrix button widget. That reduces the RAM usage, is bug safe and increases speed a lot. Also makes it easier to handle programmatically.
              • paralepsisundefined
                paralepsis
                Hi! I've got one of these running now, using PCR's PCB. Thanks to you both!
                Having played a little, here are two suggestions in case someone is further improving the software:
                • If there's a simulated time available for a print, use that rather than the slicer-provided time on the Printing summary.
                • Perhaps use the full screen for the list when selecting filaments. I've found it easy to accidentally turn on a tool while selecting filaments, and difficult to select the right filament (or maybe there's a bug, hard to tell).
                Thanks again for this cool design! It's a nice little HUD of sorts for prints while I work from home and away from the printer.
                Railcore II 300XL w/ Duet 3 & RRF 3.5rc4, Makerbot R2X w/ Duet 2 WiFi & RRF 3.4
                • seeul8erundefined
                  seeul8er
                  @paralepsis Thank you for your feedback!
                  The displayed remaining time should be (simulated_time-elapsed_time) if a simulation time is available. If not it takes the time based on the file.
                  paralepsisundefined 1 Reply Last reply Reply Quote 0
                    paralepsis @seeul8er
                    @seeul8er Do I have to have performed the simulation from the RepPanel? What I did was run the simulation from the web UI, start the print from the web UI, observed an apparent use of the slicer timing on RepPanel.
                    I can try this again.
                      paralepsis @paralepsis
                      @paralepsis Repeating the experiment, I am seeing the simulated time on the RepPanel. Must have been operator error. Sorry for the misdirection.
                      • k3lagundefined
                        k3lag
                        I just got my display from buydisplay.com and realized I ordered the 3-wire SPI version instead of the 4 wire version. I also have @PCR's circuit board. Is there a way to reconfigure the software to work with the 3-wire display?
                        Also, does anyone have a close up picture of their display board? According to the data sheet there should be 0R resistors installed at R1-R10 and R21-R28 and I am missing them.
                        • seeul8erundefined
                          seeul8er
                          @k3lag I think you might be in luck. To me it is not 100% clear what the "4-wires" are exactly. The current built also does not directly specify a MISO for the SPI. The display offers a "data" connection that could be independent from the SPI to read the TFT data chip ID etc. So just give it a try!
                          k3lagundefined 1 Reply Last reply Reply Quote 0
                          • k3lagundefined
                            k3lag @seeul8er
                            I did. It didn’t work. The board appears to be jumpered for 18-bit rgb instead of SPI. I’m in contact with buydisplay and we will see what they say.
                            • k3lagundefined
                              k3lag
                              Apparently I accidentally selected the wrong option when I ordered my board and I got the 18-bit RGB version. After talking to buydisplay I choose to rejumper the board for 4-pin SPI and it works now.
                              I am having a problem with it freezing after a few minutes of operation. Right before it freezes I see the WiFi icon turn yellow momentarily then it goes back to green and it's frozen at that point. After a reset it will work again for a while then do the same thing. I have an Orbi mesh WiFi network and I wonder if it's somehow struggling with that. When I go to pick a WiFi network it shows each of the 3 Orbi bases as separate networks and there is no way to tell which one you are picking. Don't know if that's the problem or not but I plan to fiddle more to see if I can figure it out. Never mind. I don't use the filament directory so once I added a filament file it was happy.
                              • seeul8erundefined
                                seeul8er
                                @k3lag Thank you for reporting the issue. I think someone already mentioned that. I added the bug to the github issues 👍
                                • fractalengineerundefined
                                  fractalengineer
                                  Aw man did I just goof up again?
                                  I ordered this panel after ordering another one that wasn't touchscreen...
                                  The pinout doesn't look right; but it seems to have the recommended driver
                                  https://www.aliexpress.com/item/4000127949256.html?spm=a2g0s.9042311.0.0.13734c4dRwnSJw
                                  Can I use this at all?
                                  Railcore II ZL
                                    fractalengineer
                                    Ok so it appears to be a parallel display; I did however manage to get the library examples working on my esp32 using the TFT_eSPI lib on arduino IDE...Not sure how that would work on IDF
                                    Railcore II ZL
                                    • seeul8erundefined
                                      seeul8er
                                      @fractalengineer In your case to get it working you will need to write a display driver for LvGL that supports the parallel interface. The drivers from LVGL do not support the parallel display interface as far as I know. The touch screen should work out of the box since there is already a driver available.
                                      fractalengineerundefined 1 Reply Last reply Reply Quote 0
                                        fractalengineer @seeul8er
                                        @seeul8er Ok that's well beyond my skill level lol; I'll just look for an appropriate screen.
                                        Btw this is tested to work on Duet3+SBC right?
                                        Railcore II ZL
                                          jay_s_uk
                                          This currently only works with boards in standalone mode
                                          • chimaeraghundefined
                                            chimaeragh
                                            @Sindarius Can this be adapted to work in CNC mode? I would prefer this interface to the paneldue to control my workbee
                                            Duet 2 Wifi, Ooznest Workbee CNC 1510
                                            Sindariusundefined 1 Reply Last reply Reply Quote 0
