    Faulty Smart Effector
    Smart effector for delta printers
    847
    • tcjundefined
      tcj
      since today my smart effector seems to be faulty.
      It continuously triggers even with the board alone (without heatsink, arms, fans ..), green trigger light and 1000 value in web control.
      It flashes three times when turned on and then lights green all the time.
      I can't see any damage
      HELP
      Thanks
      Thomas
      • Vetiundefined
        Veti
        try changing the sensitivity
        https://duet3d.dozuki.com/Wiki/Smart_effector_and_carriage_adapters_for_delta_printer#Section_Programming_the_sensitivity
        • tcjundefined
          tcj
          Thanks, but that is not the only thing that I tried several times but without any success. 😞
          • Vetiundefined
            Veti
            post high resolution pictures of the front and back of the effector
            • tcjundefined
              tcj
              I've already inspected the whole effector with a magnifying glass
              There is nothing abnormally
                When and where did you purchase it?
                • tcjundefined
                  tcj
                  Sep '19 at filafarm.de
                  I've already sent them a mail
                    Photos? Maybe we can see something you can't?
                    Wiring?
                    Did anything change recently with the printer?
                    When was it working last?
                    • tcjundefined
                      tcj
                      Wiring is ok - worked for months
                      Updated RRF a few days ago, but not yesterday
                      Working last night at last
                        Is that a scratch on the second photo on the bottom edge?
                        • tcjundefined
                          tcj
                          yes, but it's there since I received it and it is only on the lacquer coat
                            What M672 are you using?
                            • tcjundefined
                              tcj
                              tried M672 S131:131 without success - even no flashing of the LED
                              and before you're asking 😉
                              ;### Z-Probe ###
                              M558 P8 R0.2 F1200 H2 C"zprobe.in"
                              G31 P100 X0 Y0 Z-0.19           		; Set Z probe trigger value, offset and trigger height
                              M557 R180 S40                          		; Define mesh grid
                              • Vetiundefined
                                Veti
                                @tcj said in Faulty Smart Effector:
                                this is missing the zprobe.mod to control the sensitivity
                                try C"zprobe.in+zprobe.mod"
                                tcjundefined 2 Replies Last reply Reply Quote 1
                                • tcjundefined
                                  tcj @Veti
                                  @Veti 😽
                                  • tcjundefined
                                    tcj @Veti
                                    @Veti Thank you so much!
                                    It works!
                                    • Lightpathundefined
                                      Lightpath
                                      @Veti said in Faulty Smart Effector:
                                      This should be in the documentation.
                                        Phaedrux Moderator @Lightpath
                                        @Lightpath said in Faulty Smart Effector:
                                        Consider it done.
