    G32 ERROR
    5.3k
      Phaedrux Moderator @moe.adams9093
      @moe-adams9093 said in G32 ERROR:
      can I use stall detection to stop each motor at Zmax. please share your thoughts
      Yes. M574 Z2 S4. But you'll have to do the usual stall detection tuning.
        Phaedrux Moderator @fcwilt
        @fcwilt said in G32 ERROR:
        Perhaps you could speed verification of this possibility with direct communication with dc42?
        He's aware. But also asleep at the moment I'd wager.
        • fcwiltundefined
          fcwilt @Phaedrux
          @Phaedrux said in G32 ERROR:
          I have little idea of who lives where.
          My hours are so erratic I'm not sure what time zone I'm supposed to be in. 😉
          • moe.adams9093undefined
            moe.adams9093
            Sorry It's US central Time Here maybe we are 8 hours difference.
            M574 Z2 S1 P"!exp.e2stop+!exp.e3stop+!exp.e5stop+!exp.e6stop"
            it's not working at all.
              Can you try testing on 3.1.1?
              It's easy to switch between. Upload this zip file to the system tab. No need to change the config file.
              https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
              moe.adams9093undefined 1 Reply Last reply Reply Quote 0
                moe.adams9093
                so you dont thing the duex 5 is bad
                and run m119 it will show the endstop is triggered at max
                  moe.adams9093 @Phaedrux
                  @Phaedrux curently Im on 3.1.1
                    moe.adams9093
                    Yes. M574 Z2 S4
                    so if I can use M574 Z2 S4 how can split the axis and make one at a time when they hit max location. if you have documentation on that please share it
                    • fcwiltundefined
                      fcwilt @moe.adams9093
                      That result indicates that one or more of the end stop sensors is triggered.
                      If you could do the following we can find out if one of the end stop sensors is perhaps not working correctly.
                      From the DWC console if you issue the M574 to configure just a single end stop the M119 will report it's state independent of any others.
                      M574 Z2 S1 P"!exp.e2stop"
                      M119
                      M574 Z2 S1 P"!exp.e3stop"
                      M119
                      M574 Z2 S1 P"!exp.e5stop"
                      M119
                      M574 Z2 S1 P"!exp.e6stop"
                      M119
                      If would be very helpful to verify that each end stop sensor is working.
                        moe.adams9093 @fcwilt
                        @fcwilt ok I Will try that now thanks for keeping up with me I truly appreciated
                          moe.adams9093
                          @fcwilt I just tried that still same when I do that it will say M119 All at max and they are not even triggered it the same even if I keep ! or I remove. I know for a fact all my endstops function probably because I did install them on the X and Y and they all worked correctly
                          fcwiltundefined 2 Replies Last reply Reply Quote 0
                          • fcwiltundefined
                            Sometimes the only way to track down a problem is to approach it one little bit at a time.
                            We have seemingly discovered an interesting issue with the firmware having difficulty in processing long commands. I've been using 3.1.1 for months and I have never encountered the issue simply because nothing I did needed a long command like that. And now finally we are aware of the issue.
                            As you may recall one of my printers has three Z steppers with end stop sensors. Homing worked just fine under 3.1.1.
                            I recently upgraded the printer to 3.2.0 and almost immediately began having homing problems where one of the steppers would keep moving even though the end stop sensor had been triggered (they have LEDs).
                            I've only begun testing and need to do much more but out of 5 homing attempts 3 failed as described above.
                            As part of my testing I reverted to 3.1.1 and 5 out of 5 homing attempts worked.
                            I'm confident I will get it sorted and I am equally confident we will get your problem sorted.
                            • fcwiltundefined
                              I don't understand what you mean when you say "M119 ALL at max" - I am only interested in the status of Z.
                              And you did just configure one at a time? The presence or absence of the ! should most assuredly make a difference.
                              • fcwiltundefined
                                Refresh my memory - what sort of end stop sensor hardware do you have on Z?
                                  moe.adams9093
                                  they are normally close FYSETC and they are exactly the same as my X&Y EndStops they have 3 pins V G S
                                    Yes. M574 Z2 S4
                                    That's the point of S4. Stall detection for each motor independently. Check the wiki entry for m574
                                      moe.adams9093
                                      @dc42 could you please take a look at this problem I'm currently facing I will post the latest config files here to make it short as possible and not to have to go to the previous threads.
                                      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Oct 13 2020 21:14:55 GMT-0500 (Central Daylight Time)
                                      G90                                                     	; send absolute coordinates...
                                      M83                                                     	; ...but relative extruder moves
                                      M550 P"DIVINCI-3D (MP4560)"                             	; set printer name
                                      M669 K1                                                 	; select CoreXY mode
                                      M552 P0.0.0.0 S1                                        	; enable network and acquire dynamic address via DHCP
                                      M586 P0 S1                                              	; enable HTTP
                                      M586 P1 S0                                              	; disable FTP
                                      M586 P2 S0                                              	; disable Telnet
                                      M569 P10  R1 T2:2:2:2  S1  									; physical drive 0 goes forwards
                                      M569 P11  R1 T2:2:2:2  S1  									; physical drive 1 goes forwards
                                      M569 P3 S1                                             		; physical drive 3 goes forwards
                                      M569 P4 S1                                              	; physical drive 4 goes forwards
                                      M569 P5 S1                                              	; physical drive 5 goes Backwards
                                      M569 P6 S1 													; physical drive 6 goes Backwards
                                      M569 P8 S0			          								; physical drive 7 goes Backwards
                                      M569 P9 S0                                              	; physical drive 9 goes backwards
                                      M584 X10 Y11 Z5:6:8:9 E3:4                              	; set drive mapping
                                      M671 X5.0:455.0:455.0:5.0 Y25.0:25.0:455.0:455.0 S14    	; ZBelts Near Locations
                                      M350 X32 Y32 Z16 E16:16 I1                              	; configure microstepping with interpolation
                                      M92 X80.00 Y80.00 Z410.00 E415.00:415.00 					; set steps per mm
                                      M566 X900.00 Y900.00 Z12.00 E120.00:120.00              	; set maximum instantaneous speed changes (mm/min)
                                      M203 X6000.00 Y6000.00 Z400 E1200.00:1200.00        		; set maximum speeds (mm/min)
                                      M201 X500.00 Y500.00 Z40.00 E250.00:250.00           		; set accelerations (mm/s^2)
                                      M906 X1800 Y1800 Z1000 E500:500 I30                     	; set motor currents (mA) and motor idle factor in per cent
                                      M84 S30                                                 	; Set idle timeout
                                      M208 X0 Y0 Z0 S1                                        	; set axis minima
                                      M208 X460 Y460 Z460 S0                                  	; set axis maxima
                                      M574 X1 S1 P"!xstop"                                    		; configure active-high endstop for low end on X via pin !xstop
                                      M574 Y1 S1 P"!ystop"                                    		; configure active-high endstop for low end on Y via pin !ystop
                                      M574 Z1 S2 														; configure Z-probe endstop for low end on Z
                                      M574 Z2 S1 P"!exp.e2stop+!exp.e3stop+!exp.e5Stop+!exp.e6stop"	; configure active-high endstop for High end on Z via pin !ystop
                                      M558 P1 C"zprobe.in" H25 F600 T6000                      	; set Z probe type to unmodulated and the dive height + speeds
                                      G31 P500 X0 Y0 Z2.5                                     	; set Z probe trigger value, offset and trigger height
                                      M557 X20:440 Y20:440 S20                                	; define mesh grid
                                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 	; configure sensor 0 as thermistor on pin bedtemp
                                      M950 H0 C"bedheat" T0                                   	; create bed heater output on bedheat and map it to sensor 0
                                      M307 H0 A11 C99000 D2000 B1                  				; enable bang-bang mode for the bed heater and set PWM limit
                                      M140 H0                                                 	; map heated bed to heater 0
                                      M143 H0 S120                                            	; set temperature limit for heater 0 to 120C
                                      M308 S1 P"spi.cs1" Y"thermocouple-max31856"             	; configure sensor 1 as thermocouple via CS pin spi.cs1
                                      M950 H1 C"e0heat" T1                                    	; create nozzle heater output on e0heat and map it to sensor 1
                                      M307 H1 B0 S1.00                                        	; disable bang-bang mode for heater  and set PWM limit
                                      M308 S2 P"spi.cs2" Y"thermocouple-max31856"             	; configure sensor 2 as thermocouple via CS pin spi.cs2
                                      M950 H2 C"e1heat" T2                                    	; create nozzle heater output on e1heat and map it to sensor 2
                                      M307 H2 B0 S1.00                                        	; disable bang-bang mode for heater  and set PWM limit
                                      M308 S3 P"duex.e2temp" Y"thermistor" T10000 B3950       	; configure sensor 3 as thermistor on pin duex.e2temp
                                      M950 H3 C"duex.e2heat" T3                               	; create chamber heater output on duex.e2heat and map it to sensor 3
                                      M307 H3 A11 C99000 D2000 B1                             	; enable bang-bang mode for the chamber heater and set PWM limit
                                      M141 H3                                                 	; map chamber to heater 3
                                      M950 F0 C"fan0" Q500                                    	; create fan 0 on pin fan0 and set its frequency
                                      M106 P0 S1 H-1                                          	; set fan 0 value. Thermostatic control is turned on
                                      M950 F1 C"fan1" Q500                                    	; create fan 1 on pin fan1 and set its frequency
                                      M106 P1 S1 H2 T45                                       	; set fan 1 value. Thermostatic control is turned on
                                      M950 F2 C"fan2" Q500                                    	; create fan 2 on pin fan2 and set its frequency
                                      M106 P2 S1 H1:2 T45                                     	; set fan 2 value. Thermostatic control is turned on
                                      M563 P0 S"MAIN EXTRUDER" D0 H1 F0                       	; define tool 0
                                      G10 P0 X0 Y0 Z0                                         	; set tool 0 axis offsets
                                      G10 P0 R0 S0                                            	; set initial tool 0 active and standby temperatures to 0C
                                      M563 P1 S"SECOND EXTRUDER" D1 H2 F0                     	; define tool 1
                                      G10 P1 X0 Y0 Z0                                         	; set tool 1 axis offsets
                                      G10 P1 R0 S0                                            	; set initial tool 1 active and standby temperatures to 0C
                                      M575 P1 S1 B57600                                       	; enable support for PanelDue
                                      M501                                                    	; load saved parameters from non-volatile memory
                                      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"      	; set voltage thresholds and actions to run on power loss
                                      T0                                                      	; select first tool
                                      The endstops I have are normally close Active low. when I run my M119 I get this message
                                      2/1/2021, 10:27:05 PM: M119: Endstops - X: not stopped, Y: not stopped, Z: at max stop, Z probe: not stopped
                                      even if I remove my( !) on M574 Z2 S1 code still the same M119 Message.
                                      here's my homeall.g files
                                      ; homeall.g
                                      ; called to home all axes
                                      G1 H1 Z500 F6000          ; lift Z relative to current position
                                      G1 H1 X-465 F8000 ; move quickly to X endstop and stop there (first pass)
                                      G1 H1 Y-465 F8000 ; move quickly to Y endstop and stop there (first pass)
                                      G1 H2 X5 Y5 F6000       ; go back a few mm
                                      G1 H1 X-465 F360        ; move slowly to X axis endstop once more (second pass)
                                      G1 H1 Y-465 F360        ; then move slowly to Y axis endstop
                                      G1 H2 Z-500 F6000;
                                      G1 X235 Y235 F6000      ; Prob at Center
                                      M558 F600 A1 		    ; Dive fast once
                                      G30			            ; probe Z
                                      M558 F300 A10 		    ; Slow second dive with more accuracy
                                      G30			            ; probe z again
                                      so the purpose here all I want when I press home all I want the bed to go to the max side and trigger all 4 endstops to stop all 4 Z axis individually, then to travel back to the Min side and prob using DC42 IR Sensor and home all at the min side.
                                      • Vetiundefined
                                        Veti
                                        the duet 2 only supports interpolation at x16. so this statement is incorrect
                                        you have a mistake you wrote e5S and e6s
                                          moe.adams9093
                                          That's not the issue this I mistakenly uploaded a back up file if you look up on my previous thread I have the correct file even Phaedrux moderator checked it
                                            dc42 administrators @fcwilt
                                            @fcwilt Hmm, wonder why it didnt work for him the first time?
                                            I have no idea - this topic has gotten rather long and it's hard to remember it all.
                                            Those names you suggested are shorter by one character each which tends to reinforce the idea of a command length limitation.
                                            The string buffer that holds the pin name in commands that require a pin name has a limited length. AFAIR it's 50 characters. Does that explain it?
                                            As usual, running M98 P"config.g" should reveal if this is causing a problem.
