    G32 ERROR
    5.3k
    • fcwiltundefined
      fcwilt @moe.adams9093
      @moe-adams9093 said in G32 ERROR:
      @fcwilt Ok what about when I use my Z-Probe and to run G32 how that going work
      The changes I suggested were only for TESTING to verify that each Z stepper on it's own was working as expected with no possible interactions with the other Z steppers.
      Once you were sure that they were working then you would restore the original stepper configuration commands.
      • moe.adams9093undefined
        moe.adams9093
        Ok make sense thank you
          M574 Z2 S1 P"!exp.e2stop+!exp.e3stop+!exp.e5stop+!exp.e6stop"
          Instead of using exp.e#stop let's try using the pin names for the actual deux pins.
          duex.e2stop
          duex.e3stop
          duex.e4stop
          duex.e5stop
          duex.e6stop
          When using these names I think you can remove the !, but please test carefully.
          moe.adams9093undefined 1 Reply Last reply Reply Quote 0
            moe.adams9093 @Phaedrux
            @Phaedrux so I did move the ! And did exactly as
            M574 Z2 S1 P" duex.e2stop+ duex.e3stop+duex.e5stop+ duex.e6stop"; when I click home Z axis are not moving they do get power but no signal
              And if you check M119 what does the endstop status say?
              If it says the z endstop is triggered but the switch isn't pressed, then you would need to add the ! again to invert the signal.
                @Phaedrux yes thats what I got
                2/1/2021, 1:30:18 PM: M119: Endstops - X: not stopped, Y: not stopped, Z: at max stop, Z probe: not stopped
                  moe.adams9093 @moe.adams9093
                  I'm going to put ! back and see what's going on
                    moe.adams9093
                    The only one is communicating probably is e6stop
                      moe.adams9093
                      Its not working. when I added this code
                      M574 Z2 S1 p"!duex.e6stop+!duex.e5stop+!duex.e3stop+!duex.e4stop";
                      and run M119
                      M119
                      Endstops - X: at min stop, Y: at min stop, Z: no endstop, Z probe: not stopped
                      but If I remove any one of any of the above endstops
                      example:
                      M574 Z2 S1 p"!duex.e6stop+!duex.e5stop+!duex.e3stop";
                      my M119 will show Z end stop is available I don't know what's causing this issue to not take all 4endstops. also when I press any of the endstops they all stop automatically not individually. I don't know whats happening maybe my duex 5 is bad or if you guys know any solution around please let me know. thank you
                        moe.adams9093
                        I believe somehow some of my end stop input on my duex 5 is not responding correctly. can I use stall detection to stop each motor at Zmax. please share your thoughts
                        fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                        • alankilianundefined
                          alankilian
                          @dc42 I hate to jump in and be an idiot, but is it because MaxAxes is set to six in the firmware?
                          • fcwiltundefined
                            I have the same board setup as you - Duet 2 WiFi + Duex5.
                            On my printer I only have 3 Z steppers so my end stop configuration command is:
                            M574 Z1 S1 P"!duex.e2stop + !duex.e3stop + !duex.e4stop"
                            As an experiment I entered this on the DWC Console
                            M574 Z1 S1 P"!duex.e2stop + !duex.e3stop + !duex.e4stop + !duex.e5stop"
                            and got this error message:
                            Error: M574: Unknown pin name 'duex.e5sto'
                            Notice the last character, the p, is missing.
                            I then took that same text and created a gcode file with it in my sys directory.
                            I executed the file with the M98 command and got the same error.
                            I then used this text to create another gcode file with it in my sys directory:
                            M574 Z1 S1 P"!exp.4 + !exp.9 + !exp.14 + !exp.19"
                            which are alternate names for the pins.
                            I executed the file with the M98 command and got NO error.
                            Then I executed from the DWC console a M574 and got this:
                            Endstop configuration:
                            X: low end switch connected to pin xstop
                            Y: high end switch connected to pin ystop
                            Z: low end switches connected to pins !(exp.e2stop,exp.4) !(exp.e3stop,exp.9,spi.cs6,duex.cs6) !(exp.e4stop,exp.14,spi.cs7,duex.cs7) !(exp.e5stop,exp.19,spi.cs8,duex.cs8)
                            Notice for Z that all four pins are now present - albeit with all possible names for each pin.
                            It looks like there may be some sort of command length limitation causing the problem.
                            I tried this test with both 3.1.1 and 3.2.0.
                            Try the alternate names and see if they work for you.
                              Phaedrux Moderator @fcwilt
                              @fcwilt Do you get the same error with the original pin names he had used?
                              fcwiltundefined 2 Replies Last reply Reply Quote 0
                              • fcwiltundefined
                                fcwilt @Phaedrux
                                @Phaedrux said in G32 ERROR:
                                Hold on and I will try.
                                  Phaedrux Moderator @alankilian
                                  @alankilian said in G32 ERROR:
                                  It shouldn't because in RRF3 you can use multiple endstops on a single axis. No need to create additional axis anymore.
                                  • fcwiltundefined
                                    fcwilt @Phaedrux
                                    That works.
                                      @fcwilt Hmm, wonder why it didnt work for him the first time?
                                      • fcwiltundefined
                                        fcwilt @Phaedrux
                                        I have no idea - this topic has gotten rather long and it's hard to remember it all.
                                        Those names you suggested are shorter by one character each which tends to reinforce the idea of a command length limitation.
                                        Perhaps you could speed verification of this possibility with direct communication with dc42?
                                        Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                          Phaedrux Moderator @moe.adams9093
                                          Yes. M574 Z2 S4. But you'll have to do the usual stall detection tuning.
                                            @fcwilt said in G32 ERROR:
                                            He's aware. But also asleep at the moment I'd wager.
