    G32 ERROR
    5.4k
    • moe.adams9093undefined
      moe.adams9093
      That's not the issue this I mistakenly uploaded a back up file if you look up on my previous thread I have the correct file even Phaedrux moderator checked it
        dc42 administrators @fcwilt
        @fcwilt said in G32 ERROR:
        @Phaedrux said in G32 ERROR:
        @fcwilt Hmm, wonder why it didnt work for him the first time?
        I have no idea - this topic has gotten rather long and it's hard to remember it all.
        Those names you suggested are shorter by one character each which tends to reinforce the idea of a command length limitation.
        Perhaps you could speed verification of this possibility with direct communication with dc42?
        The string buffer that holds the pin name in commands that require a pin name has a limited length. AFAIR it's 50 characters. Does that explain it?
        As usual, running M98 P"config.g" should reveal if this is causing a problem.
        • fcwiltundefined
          fcwilt @dc42
          @dc42 said in G32 ERROR:
          Yes it does as the string in question was 51 characters and the error message showed the last character was missing.
          So that answers one question in regards to the OP's issues.
          Thanks very much.
          • fcwiltundefined
            fcwilt @moe.adams9093
            @moe-adams9093 said in G32 ERROR:
            even if I remove my( !) on M574 Z2 S1 code still the same M119 Message.
            Are you removing the ! from all four pin names?
            I tried this M574 Z2 S1 P"!exp.e2stop + !exp.e3stop + !exp.e4stop + !exp.e5stop"
            and M119 yields this: Endstops - X: not stopped, Y: not stopped, Z: at max stop, Z probe: not stopped
            I tried this M574 Z2 S1 P"exp.e2stop + exp.e3stop + exp.e4stop + exp.e5stop"
            That was with NOTHING connected to the end stop inputs.
            With your actual devices connected to the end stop inputs...
            ...the only way BOTH M119s could yield Endstops - X: not stopped, Y: not stopped, Z: at max stop, Z probe: not stopped..
            ...was if some of the Z axis devices were not active (closed) and some of them active (open).
            FRederick
              exp.e2stop etc. are not the same pins as duex.e2stop because the ones on the DueX are routed through the I2C chip.
              I am increasing the limit to 100 characters in RRF 3.3.
              dc42undefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                dc42 administrators @dc42
                PS - I've put a preview build of 3.3beta for Duet WiFi/Ethernet (without SBC) with the 100-character limit at https://www.dropbox.com/sh/qr98k8fbkj5ue0k/AABPawUF99QVzDrheBQBDSxia?dl=0.
                • fcwiltundefined
                  fcwilt @dc42
                  I don't understand.
                  They are listed together under Endstop Inputs for the DueX boards.
                  Yet there are no notes or markings to suggest that those with the exp.e#stop names are different from those with the duex.e#stop names.
                  Where is that difference mentioned?
                  Phaedruxundefined 1 Reply Last reply Reply Quote 2
                    Phaedrux Moderator @fcwilt
                    I don't understand.
                    They are listed as possible pins to use. They are not all equivalent in that list. For instance it lists pins on the Duet as well as the Duex. The exp pins are literally the pins on the expansion header, not the duex pins. The duex endstop pins are separate and routed differently.
                    So originally when using those exp endstop pin names it was never going to work because he wasn't actually using those pins. (he was using the actual duex endstop headers).
                    If he had 3 z axis motors and endstops instead of 4, we (you) never would have discovered this bug with the overflow.
                    fcwiltundefined 1 Reply Last reply Reply Quote 2
                      moe.adams9093
                      Ok I'm going to make some tests today and see what I'm going to end up with. I will keep you posted
                      • fcwiltundefined
                        fcwilt @Phaedrux
                        I had forgotten that was the case. I got distracted by the quest to figure out why the command was getting truncated.
                        Perhaps you should update the documentation in that regard as there are some existing pin names that are marked with a ***** to reference a note above regarding their behavior.
                        It wouldn't hurt to point out the difference in these end stop pins in much the same way.
                        It would be more work but it might be best to have Duet pin names under a Duet heading and Duex pin names under a Duex heading.
                          moe.adams9093
                          Yeah I'm going to try 3.3 and do duex.e2stop all the way to duex.e6stop and see how its going to behave
                            moe.adams9093
                            @dc42 So I went ahead and did an update to 3.3. I have 2 problems now My driver Number 10 is an external driver it doesn't move at all it's getting a signal because it locks but no movement in any direction and regarding endstops still the same issue. I will post
                            config. g
                            homall. g
                            M119
                            M122
                            M98P"config. g"
                            config. g
                            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Feb,04,2021 12:48.00 GMT-0500 (Central Daylight Time)
                            G90                                                     	; send absolute coordinates...
                            M83                                                     	; ...but relative extruder moves
                            M550 P"DIVINCI-3D (MP4560)"                             	; set printer name
                            M669 K1                                                 	; select CoreXY mode
                            M552 P0.0.0.0 S1                                        	; enable network and acquire dynamic address via DHCP
                            M586 P0 S1                                              	; enable HTTP
                            M586 P1 S0                                              	; disable FTP
                            M586 P2 S0                                              	; disable Telnet
                            M569 P10  R1 T2:2:2:2  S1  									; physical drive 0 goes forwards
                            M569 P11  R1 T2:2:2:2  S1  									; physical drive 1 goes forwards
                            M569 P3 S1                                             		; physical drive 3 goes forwards
                            M569 P4 S1                                              	; physical drive 4 goes forwards
                            M569 P5 S1                                              	; physical drive 5 goes Forwards
                            M569 P6 S1 													; physical drive 6 goes Forwards
                            M569 P8 S1			          								; physical drive 7 goes Forwards
                            M569 P9 S1                                              	; physical drive 9 goes Forwards
                            M584 X10 Y11 Z5:6:8:9 E3:4                              	; set drive mapping
                            M671 X5.0:455.0:455.0:5.0 Y25.0:25.0:455.0:455.0 S14    	; ZBelts Near Locations
                            M350 X16 Y16 Z16 E16:16 I1                              	; configure microstepping with interpolation
                            M92 X80.00 Y80.00 Z410.00 E415.00:415.00 					; set steps per mm
                            M566 X900.00 Y900.00 Z12.00 E120.00:120.00              	; set maximum instantaneous speed changes (mm/min)
                            M203 X6000.00 Y6000.00 Z400 E1200.00:1200.00        		; set maximum speeds (mm/min)
                            M201 X500.00 Y500.00 Z40.00 E250.00:250.00           		; set accelerations (mm/s^2)
                            M906 X1800 Y1800 Z1000 E500.00:500.00 I30                     	; set motor currents (mA) and motor idle factor in per cent
                            M84 S30                                                 	; Set idle timeout
                            M208 X0 Y0 Z0 S1                                        	; set axis minima
                            M208 X460 Y460 Z460 S0                                  	; set axis maxima
                            M574 X1 S1 P"!xstop"                                    		; configure active-high endstop for low end on X via pin !xstop
                            M574 Y1 S1 P"!ystop"                                    		; configure active-high endstop for low end on Y via pin !ystop
                            M574 Z1 S2 														  ;   configure Z-probe endstop for low end on Z
                            M574 Z2 S1 P"!duex.e2stop+!duex.e3stop+!duex.e4stop+!duex.e5stop" ;   configure Z-probe endstop for low end on Z
                            M558 P1 C"zprobe.in" H25 F600 T6000                      	; set Z probe type to unmodulated and the dive height + speeds
                            G31 P500 X0 Y0 Z2.5                                     	; set Z probe trigger value, offset and trigger height
                            M557 X20:440 Y20:440 S20                                	; define mesh grid
                            M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 	; configure sensor 0 as thermistor on pin bedtemp
                            M950 H0 C"bedheat" T0                                   	; create bed heater output on bedheat and map it to sensor 0
                            M307 H0 A11 C99000 D2000 B1                  				; enable bang-bang mode for the bed heater and set PWM limit
                            M140 H0                                                 	; map heated bed to heater 0
                            M143 H0 S120                                            	; set temperature limit for heater 0 to 120C
                            M308 S1 P"spi.cs1" Y"thermocouple-max31856"             	; configure sensor 1 as thermocouple via CS pin spi.cs1
                            M950 H1 C"e0heat" T1                                    	; create nozzle heater output on e0heat and map it to sensor 1
                            M307 H1 B0 S1.00                                        	; disable bang-bang mode for heater  and set PWM limit
                            M308 S2 P"spi.cs2" Y"thermocouple-max31856"             	; configure sensor 2 as thermocouple via CS pin spi.cs2
                            M950 H2 C"e1heat" T2                                    	; create nozzle heater output on e1heat and map it to sensor 2
                            M307 H2 B0 S1.00                                        	; disable bang-bang mode for heater  and set PWM limit
                            M308 S3 P"duex.e2temp" Y"thermistor" T10000 B3950       	; configure sensor 3 as thermistor on pin duex.e2temp
                            M950 H3 C"duex.e2heat" T3                               	; create chamber heater output on duex.e2heat and map it to sensor 3
                            M307 H3 A11 C99000 D2000 B1                             	; enable bang-bang mode for the chamber heater and set PWM limit
                            M141 H3                                                 	; map chamber to heater 3
                            M950 F0 C"fan0" Q500                                    	; create fan 0 on pin fan0 and set its frequency
                            M106 P0 S1 H-1                                          	; set fan 0 value. Thermostatic control is turned on
                            M950 F1 C"fan1" Q500                                    	; create fan 1 on pin fan1 and set its frequency
                            M106 P1 S1 H2 T45                                       	; set fan 1 value. Thermostatic control is turned on
                            M950 F2 C"fan2" Q500                                    	; create fan 2 on pin fan2 and set its frequency
                            M106 P2 S1 H1:2 T45                                     	; set fan 2 value. Thermostatic control is turned on
                            M563 P0 S"MAIN EXTRUDER" D0 H1 F0                       	; define tool 0
                            G10 P0 X0 Y0 Z0                                         	; set tool 0 axis offsets
                            G10 P0 R0 S0                                            	; set initial tool 0 active and standby temperatures to 0C
                            M563 P1 S"SECOND EXTRUDER" D1 H2 F0                     	; define tool 1
                            G10 P1 X0 Y0 Z0                                         	; set tool 1 axis offsets
                            G10 P1 R0 S0                                            	; set initial tool 1 active and standby temperatures to 0C
                            M575 P1 S1 B57600                                       	; enable support for PanelDue
                            M501                                                    	; load saved parameters from non-volatile memory
                            M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"      	; set voltage thresholds and actions to run on power loss
                            T0                                                      	; select first tool
                            Homeall.g
                            ; homeall.g
                            ; called to home all axes
                            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Oct 13 2020 21:14:55 GMT-0500 (Central Daylight Time)
                            G1 H1 Z500 F6000          ; lift Z relative to current position
                            G1 H1 X-465 F8000 ; move quickly to X endstop and stop there (first pass)
                            G1 H1 Y-465 F8000 ; move quickly to Y endstop and stop there (first pass)
                            G1 H2 X5 Y5 F6000       ; go back a few mm
                            G1 H1 X-465 F360        ; move slowly to X axis endstop once more (second pass)
                            G1 H1 Y-465 F360        ; then move slowly to Y axis endstop
                            G1 X235 Y235 F6000      ; Prob at Center
                            M558 F600 A1 		    ; Dive fast once
                            G30			            ; probe Z
                            M558 F300 A10 		    ; Slow second dive with more accuracy
                            G30			            ; probe z again
                            HomeZ.g
                            ; homez.g
                            ; called to home the Z axis
                            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Oct 13 2020 21:14:56 GMT-0500 (Central Daylight Time)
                            G1 H1 Z-500 F3000 ; move Z down until the endstop is triggered
                            G92 Z0            ; set Z position to axis minimum (you may want to adjust this)
                            ;G91              ; relative positioning
                            ;G1 Z0 F100       ; lift Z relative to current position
                            ;G90              ; absolute positioning
                            M122
                            M122
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3beta running on Duet Ethernet 1.02 or later + DueX5
                            Board ID: 08DLM-996RU-N8PS0-7J9D8-3S86T-1B8VP
                            Used output buffers: 6 of 24 (8 max)
                            Static ram: 23436
                            Dynamic ram: 70168 of which 24 recycled
                            Never used RAM 18452, free system stack 206 words
                            Tasks: NETWORK(ready,263) HEAT(blocked,315) DUEX(blocked,29) MAIN(running,450) IDLE(ready,19)
                            Owned mutexes:
                            Last reset 00:01:11 ago, cause: power up
                            Last software reset at 2021-02-04 13:09, reason: User, GCodes spinning, available RAM 18452, slot 2
                            Error status: 0x00
                            Aux0 errors 0,0,0
                            MCU temperature: min 23.6, current 25.7, max 26.1
                            Supply voltage: min 25.0, current 25.0, max 25.1, under voltage events: 0, over voltage events: 0, power good: yes
                            Driver 0: position 0, standstill, SG min/max not available
                            Driver 1: position 0, standstill, SG min/max not available
                            Driver 2: position 0, standstill, SG min/max not available
                            Driver 3: position 0, standstill, SG min/max not available
                            Driver 4: position 0, standstill, SG min/max not available
                            Driver 5: position 0, standstill, SG min/max not available
                            Driver 6: position 0, standstill, SG min/max not available
                            Driver 7: position 0, standstill, SG min/max not available
                            Driver 8: position 0, standstill, SG min/max not available
                            Driver 9: position 0, standstill, SG min/max not available
                            Driver 10: position 0
                            Driver 11: position 0
                            Date/time: 2021-02-04 13:12:44
                            Cache data hit count 110185932
                            Slowest loop: 6.92ms; fastest: 0.21ms
                            === Storage ===
                            Free file entries: 10
                            SD card longest read time 3.8ms, write time 0.0ms, max retries 0
                            === MainDDARing ===
                            === AuxDDARing ===
                            Bed heaters = 0 -1 -1 -1, chamberHeaters = 3 -1 -1 -1
                            Heater 1 is on, I-accum = 0.0
                            Segments left: 0
                            Movement lock held by null
                            HTTP is idle in state(s) 0
                            Telnet is idle in state(s) 0
                            File is idle in state(s) 0
                            USB is idle in state(s) 0
                            Aux is idle in state(s) 0
                            Trigger is idle in state(s) 0
                            Queue is idle in state(s) 0
                            LCD is idle in state(s) 0
                            Daemon is idle in state(s) 0
                            Code queue is empty.
                            === DueX ===
                            Read count 45, 37.91 reads/min
                            === Network ===
                            Slowest loop: 11.52ms; fastest: 0.02ms
                            HTTP sessions: 1 of 8
                            Interface state active, link 100Mbps full duplex
                            M119
                            2/4/2021, 1:14:39 PM	M119
                            Endstops - X: not stopped, Y: not stopped, **Z: no endstop**, Z probe: not stopped
                            Problems Key
                            Driver 10 external servo Motor with an encoder on 3.3FR Not moving
                            Endstop Still Same issue string Can't take more than 50 Characters.
                            Thank You
                              moe.adams9093
                              Sorry forgot to post M98
                              M98P"config.g"
                              HTTP is enabled on port 80
                              FTP is disabled
                              TELNET is disabled
                              Error: Unknown pin name 'duex.e5sto'
                              Error: bad grid definition: Too many grid points; suggest increase spacing to 21.0mm
                              Warning: Macro file config-override.g not found
                              • fcwiltundefined
                                It looks like that version of the firmware doesn't have the expanded command buffer - it's still dropping the last character.
                                  moe.adams9093
                                  I just found a solution to this problem. and it's a very simple fix. All I have to do is swap Driver 9 and Duex.e6stop to Z Drive and !Zstop that will put my string under 50 Char. But first I need to go back to 3.1.1 because 3.3 is acting a little weird.
                                  • fcwiltundefined
                                    Did you have a problem with the original driver assignments under 3.1.1?
                                    I don't recall that you did.
                                      moe.adams9093
                                      Yes I did have a problem but I was using << !exp.e2stop to !exp.e6stop >> that was another issue. Anyway I haven't downgraded yet to 3.1 I will see if it works but I think it should
                                        Maybe stick to 3.2 instead of 3.1.1
                                        moe.adams9093undefined 1 Reply Last reply Reply Quote 0
                                          moe.adams9093 @Phaedrux
                                          @Phaedrux 3.2 for somereason my external driver Number 10 it won't work
                                            moe.adams9093
                                            So I downgraded to 3.1.1 and Main board is not working now YAT won't see it to enable ethernet via USB and can even erase firmware when i jump the reset pins deg light won't even turn red. Why did that happen
