    Request change to wiring diagrams
    20
    889
    • gnydickundefined
      gnydick @fcwilt
      @fcwilt exactly, lol
      • zaptaundefined
        zapta
        Here is the coil outputs notation in the Trinamic datasheet.
        • gnydickundefined
          gnydick @zapta
          @zapta yes, thank you!
            A Former User
            there is more documentation for those in need; https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Using_the_internal_drivers with less room for ambiguity.
            (it also shows maestro and duet3 having been changed already)
              @gnydick, we agree with you. That's why all our more recent boards, including all production Duet 3 series boards, label the outputs A+ A- B+ B-.
              • zaptaundefined
                zapta @A Former User
                @bearer said in Request change to wiring diagrams:
                Very good. We were knocking on an open door. 😉
                • Swift Testerundefined
                  Swift Tester @gnydick
                  @gnydick said in Request change to wiring diagrams:
                  At the very least, you could put a comment on the wiring diagram that tells you 1 & 2 are the different coils and to NOT map A & B to the motor diagram's A & B.
                  For Duet 2 this suggestion looks reasonable.
                    T3P3Tony administrators
                    I have updated the wiring diagram:
                    gnydickundefined 1 Reply Last reply Reply Quote 4
                    • gnydickundefined
                      gnydick @T3P3Tony
                      @T3P3Tony thank you for the effort, but that's more confusing. The whole point was that all the motor diagrams seem to indicate A loop and B loop. This new diagram only makes sense if you understood it to begin with. Keep in mind, I'm viewing this from the "n00b" point of view. I'm suggesting making it fool proof, as there are lots of little pitfalls that can result in $200 mistakes.
                        T3P3Tony administrators @gnydick
                        ahh ok, fine, changed to that.
                          Swift Tester
                          Don't want to seem boring, but according to
                          "On Duet 2 WiFi/Ethernet these are labelled '2B 2A 1A 1B' on the back of the board, and on the wiring diagram. The '1' and '2' refer to the coil or phase, the 'A' and 'B' refer to the positive and negative."
                          "+" and "-" are currently reversed.
                            T3P3Tony administrators @Swift Tester
                            @Swift-Tester thats why i left the original labelling on the diagram as well as the AB+- which is to help those like @gnydick who are referring to a diagram labelled with AB+-
                            The +/- are consistent with other Duet diagrams that use this scheme (i.e. black is A+ etc)
                              basically as long as you realise that the two pairs are on pins 1,2 and 3,4 respectively its all good, you can use M569 to set the motor direction as required.
                                Swift Tester
                                I do not have the source, but IMHO this sketch is consistent with Wiki and have the information about special notation D2W uses. The rest is up to the reader.
