    Request change to wiring diagrams
    20
    889
    • fcwiltundefined
      fcwilt
      If you look some more you can find many different diagrams using many different names.
      If might be good to make such a change.
      But I would never conclude that 1A and 2A were the ends of a coil.
      The most significant "digit" is the 1 or the 2. The least significant "digit" is the A or the B.
      If the labels were...
      • 1.1
      • 1.2
      • 2.1
      • 2.2
      would you conclude that 1.1 and 2.1 were the ends of a coil?
      • luckyflyerundefined
        luckyflyer
        Never assume anything. In this case a multimeter is your friend.
        • gnydickundefined
          gnydick @fcwilt
          @fcwilt I totally understand what you're saying wrt significant digits, but I've also been around enough engineering, systems, and software to know a) people do strange things, and b) there always seems to be more conventions when I think I've "seen them all."
          Not everyone has the same experience, and it's not unreasonable for people to not have all the right debugging tools. So, if I plug in a hearty stepper with the circuits crossed, I just get the "driver ground fault" error. So it seems safe to experiment with the pin out when things aren't working.
          The other thing that could lead someone to place more emphasis on the A & B is because those seem to be the dominant names for the pins.
          It's not unreasonable when you can read 1A & 2A as First A and Second A. We even do it in our colloquial speaking, 1A and 2A are the First and Second Amendments.
          I'm sure I could think of more examples, but I think I've described how it's reasonable to mistakenly, (or out of sheer desperation) read them that way.
          • fcwiltundefined
            fcwilt @gnydick
            @gnydick said in Request change to wiring diagrams:
            Indeed.
            What's that old saying about making a system idiot proof just to have the universe create a bigger idiot?
            • zaptaundefined
              zapta @gnydick
              This is very confusing because the naming convention here also uses A and B.
              +1 for confusing. I hit the same issue recently when working on the stepper motor analyzer. First did it the intuitive way and then changed to the Duet's way. 😉
              Most of the notation I have seen, including in Wikipedia, letters denote coils and digits or +/- denote polarity.
              As for using multimeter, can it be used to determine the coil association on the Duet's connector pins?
              • gnydickundefined
                gnydick @fcwilt
                @fcwilt exactly, lol
                • zaptaundefined
                  zapta
                  Here is the coil outputs notation in the Trinamic datasheet.
                  • gnydickundefined
                    gnydick @zapta
                    @zapta yes, thank you!
                      A Former User
                      there is more documentation for those in need; https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Using_the_internal_drivers with less room for ambiguity.
                      (it also shows maestro and duet3 having been changed already)
                        @gnydick, we agree with you. That's why all our more recent boards, including all production Duet 3 series boards, label the outputs A+ A- B+ B-.
                        • zaptaundefined
                          zapta @A Former User
                          @bearer said in Request change to wiring diagrams:
                          Very good. We were knocking on an open door. 😉
                          • Swift Testerundefined
                            Swift Tester @gnydick
                            At the very least, you could put a comment on the wiring diagram that tells you 1 & 2 are the different coils and to NOT map A & B to the motor diagram's A & B.
                            For Duet 2 this suggestion looks reasonable.
                              T3P3Tony administrators
                              I have updated the wiring diagram:
                              gnydickundefined 1 Reply Last reply Reply Quote 4
                              • gnydickundefined
                                gnydick @T3P3Tony
                                @T3P3Tony thank you for the effort, but that's more confusing. The whole point was that all the motor diagrams seem to indicate A loop and B loop. This new diagram only makes sense if you understood it to begin with. Keep in mind, I'm viewing this from the "n00b" point of view. I'm suggesting making it fool proof, as there are lots of little pitfalls that can result in $200 mistakes.
                                  T3P3Tony administrators @gnydick
                                  ahh ok, fine, changed to that.
                                    Swift Tester
                                    Don't want to seem boring, but according to
                                    "On Duet 2 WiFi/Ethernet these are labelled '2B 2A 1A 1B' on the back of the board, and on the wiring diagram. The '1' and '2' refer to the coil or phase, the 'A' and 'B' refer to the positive and negative."
                                    "+" and "-" are currently reversed.
                                      T3P3Tony administrators @Swift Tester
                                      @Swift-Tester thats why i left the original labelling on the diagram as well as the AB+- which is to help those like @gnydick who are referring to a diagram labelled with AB+-
                                      The +/- are consistent with other Duet diagrams that use this scheme (i.e. black is A+ etc)
                                        basically as long as you realise that the two pairs are on pins 1,2 and 3,4 respectively its all good, you can use M569 to set the motor direction as required.
                                          Swift Tester
                                          I do not have the source, but IMHO this sketch is consistent with Wiki and have the information about special notation D2W uses. The rest is up to the reader.
