    oozeBot Elevate
    My Duet controlled machine
    17
    92
    6.4k
    • oozeBotundefined
      oozeBot
      We just wrapped up our new build plate, with 3-point leveling, made from .25โ€ ATP-5 precision cast aluminum tooling plate. Fresh off the CNC!
      Canโ€™t wait to get it mounted for testing!
      • fcwiltundefined
        fcwilt @oozeBot
        @oozeBot said in oozeBot ele^gant:
        Boy, whoever cut that plate has a real hard time making straight cuts!
        ๐Ÿ˜‰
        oozeBotundefined 1 Reply Last reply Reply Quote 0
        • oozeBotundefined
          oozeBot @fcwilt
          @fcwilt we took a bit of creative freedom with the design.. decided not everything on our machines had to be square!
          • fcwiltundefined
            fcwilt @oozeBot
            It looks very good - somebody at your end is creative.
            I have next to no creativity - using round corners is about as creative as I can get. ๐Ÿ˜‰
            • oozeBotundefined
              oozeBot
              More photos of the new build plate after cleaning it up and getting it installed. We are very pleased but there will be some additional design tweaks. Iโ€™ve got to say, Iโ€™m really impressed with the mesh bed leveling results..!
              • JamesMundefined
                JamesM
                The wham bam pex surface works good but I have had problems with it coming apart if the material I'm printing with tries to pull up ruining the surface. Seems like the top layer of it comes apart.
                • oozeBotundefined
                  oozeBot @JamesM
                  @JamesM so far, weโ€™ve had good luck with it after sanding.. but itโ€™s just one of many surfaces we are testing. However, I do understand what you are pointing out about it and will be watching for it..
                  • oozeBotundefined
                    oozeBot
                    We have completed the motion system for the oozeBot ele^gant with all testing complete. It can sustain 400mm/s in X&Y and 250mm/s in Z!
                    Check out a quick video of it in motion here: https://vimeo.com/515410723
                    • whopping pochardundefined
                      whopping pochard
                      Beautiful machine! It's looking really great.
                        Well done. Looking forward to seeing more.
                        • fcwiltundefined
                          fcwilt
                          Your height map is obscenely good - are you just trying to make the rest of us feel inadequate? ๐Ÿ˜‰
                          What I wouldn't give to have a bed that flat.
                          And why doesn't your machine try to shake itself apart at those speeds?
                          I've never tried speeds like that but I'm pretty sure my printers would disassemble themselves in protest.
                          What printing speeds are you aiming for?
                          • oozeBotundefined
                            oozeBot @fcwilt
                            @fcwilt said in oozeBot ele^gant:
                            Thanks! I'd like to think the engineering has something to do with it not rattling itself apart.. ๐Ÿ˜‰ and for the aluminum build plate, depending on our demand, we are considering making custom sizes available for sale to help subsidize the substantial cost of the industrial CNC machine we are purchasing.
                            We only print in ABS and have found it does best between 60-80mm/s. And since we are focusing on the printed parts needed for our printers, that's our target. However, we've certainly pushed the prototypes harder.. and I truly believe the release candidates are a much more rigid design, so we shall see here very soon!
                            • fcwiltundefined
                              fcwilt @oozeBot
                              @oozeBot
                              Being able to purchase custom sized beds with appropriate mounting holes would be heaven on earth.
                              I don't print ABS but I was under the impression that there were newer alternatives that had desirable specs. Yes? No?
                              • oozeBotundefined
                                oozeBot @fcwilt
                                This is something we'd really like to help the community with once we get our design to market..
                                As for other filaments, the only alternative we'd currently consider is ASA. There are plenty of other specialty filaments out there that have better characteristics, and we've tried most, but we always end up coming back to ABS as it checks all the boxes for our needs.
                                • oozeBotundefined
                                  oozeBot
                                  One more quick video of our final motion system, this time isolated by each axis. Z is moving at 250mm/s and X&Y is moving at 400mm/s!
                                  https://vimeo.com/515982259
                                  • oozeBotundefined
                                    oozeBot
                                    A lot has been accomplished since I last posted to this thread. For starters, the codename "ele^gant" has been replaced. We are now branding our machines as the oozeBot Elevate! Our R&D is nearly complete but we have a ton of QA to do before our launch.
                                    We will also be launching with an IDEX machine that I'm very excited about. Here is a photo of our 12x12x12" (305x305x305mm) IDEX, the tool heads, and a quick video directly from my workbench.
                                    And here is a video of it moving at 200mm/s the first half and 400mm/s the second half. And yeah, it's jumping around on my workbench a bit as it's just sitting on the turntable.
                                    https://vimeo.com/549007801
                                    Sindariusundefined HebigTundefined 2 Replies Last reply Reply Quote 3
                                    • Sindariusundefined
                                      Sindarius @oozeBot
                                      @oozebot I want one just to make them dance now ๐Ÿ˜„ that looks quite amazing!
                                      • HebigTundefined
                                        HebigT @oozeBot
                                        @oozebot I really enjoy seeing your posts. Looking forward to the launch!
                                        • oozeBotundefined
                                          oozeBot
                                          We have just wrapped up the design of our electronics control panel and thought it would be of interest. It features a Duet 3 (6HC) mainboard, a Duet breakout board (IDEX only), a 2gb RPi4b, two Omron SSRs for build plate and chamber heaters, and both a 5v and 24v Meanwell power supply. Hidden underneath the Duet 3 mainboard is a 92mm intake fan with air channels venting towards the power supplies and other electronics.
                                          o_lampeundefined 1 Reply Last reply Reply Quote 4
                                            That's slick!
