Deleting config.g file
45
2.7k
    idaho creator
    So I thought the problem was fixed. Did several prints some lasting 20+ hrs. Powered off yesterday due the hotend thermistor reading -273 degrees. Turned it on today to heat up block to remove themistor tube that is stuck due to plastic stuck on hotend from failed bed adheasion several prints ago. When fired up panel due stuck in connecting status. tried to connect to WBC and nothing there. Removed sd card and plugged into printer and again the config.g file missing. Why is my duet 3 mini wifi doing this. The only other post of this happening was my prior post a month ago. Started new thread because forum software said I needed to cause other post was old.
      idaho creator
        alankilian
        I have no idea what you are asking.
          idaho creator
          My config.g file keeps getting deleted.
            alankilian
            Why?
            There's no reason that it will get deleted unless you delete it.
            undefined 1 Reply Last reply 18 Feb 2021, 04:17 Reply Quote 0
              idaho creator @alankilian
              @alankilian yea I aint deleting it it is getting deleted on its own and why. Thats why I am here asking for help
              undefined 1 Reply Last reply 18 Feb 2021, 04:57 Reply Quote 0
                fcwilt @idaho creator
                @idaho-creator
                I wish I had a answer for you.
                I've been using a Mini 5 for several months now without losing any files.
                I started with firmware v3.1.1 - then 3.2.0 - and now 3.2.2.
                  idaho creator
                  Yea I am now having wifi dropping again. each time I boot I run the risk of the system no reconnecting to wifi. I have tried new sd cards and I am just getting tired of it. I updated firmware the last time and it worked fine for just over a month. I wish I could get it figured out.
                    idaho creator
                    M122
                    RepRapFirmware for Duet 3 Mini 5+ version 3.2 running on Duet 3 Mini5plus WiFi (standalone mode)
                    Board ID: UWSLD-U296U-D65J0-40KMS-1H03Z-7UQUB
                    Used output buffers: 3 of 40 (15 max)
                    Static ram: 98732
                    Dynamic ram: 108252 of which 40 recycled
                    Never used RAM 38192, free system stack 200 words
                    Tasks: NETWORK(ready,190) HEAT(blocked,316) CanReceiv(blocked,947) CanSender(blocked,372) CanClock(blocked,363) TMC(blocked,104) MAIN(running,444) IDLE(ready,20) AIN(blocked,267)
                    Owned mutexes: WiFi(NETWORK)
                    Last reset 00:00:33 ago, cause: software
                    Last software reset at 2021-02-17 22:00, reason: User, GCodes spinning, available RAM 38192, slot 0
                    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                    Error status: 0x00
                    Aux0 errors 0,0,0
                    Aux1 errors 0,0,0
                    Supply voltage: min 0.0, current 24.5, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                    Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 85, reads 4809, writes 9, timeouts 0, DMA errors 0
                    Driver 1: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 85, reads 4809, writes 9, timeouts 0, DMA errors 0
                    Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 85, reads 4809, writes 9, timeouts 0, DMA errors 0
                    Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 79, reads 4809, writes 9, timeouts 0, DMA errors 0
                    Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 79, reads 4809, writes 9, timeouts 0, DMA errors 0
                    Driver 5: position 0, assumed not present
                    Driver 6: position 0, assumed not present
                    Date/time: 2021-02-17 22:00:54
                    Cache data hit count 70097951
                    Slowest loop: 5.00ms; fastest: 0.12ms
                    === Storage ===
                    Free file entries: 10
                    SD card longest read time 1.0ms, write time 0.0ms, max retries 0
                    === MainDDARing ===
                    === AuxDDARing ===
                    Bed heaters = 0 -1, chamberHeaters = -1 -1
                    Segments left: 0
                    Movement lock held by null
                    HTTP is idle in state(s) 0
                    Telnet is idle in state(s) 0
                    File is idle in state(s) 0
                    USB is idle in state(s) 0
                    Aux is idle in state(s) 0
                    Trigger is idle in state(s) 0
                    Queue is idle in state(s) 0
                    LCD is idle in state(s) 0
                    SBC is idle in state(s) 0
                    Daemon is idle in state(s) 0
                    Aux2 is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 12.07ms; fastest: 0.00ms
                    HTTP sessions: 1 of 8
                    • WiFi -
                      Network state is active
                      WiFi firmware version 1.25
                      WiFi MAC address f4:cf:a2:6f:bd:71
                      WiFi Vcc 3.34, reset reason Power up
                      WiFi flash size 2097152, free heap 26176
                      WiFi IP address 192.168.1.55
                      WiFi signal strength -53dBm, mode 802.11n, reconnections 0, sleep mode modem
                      Clock register 00002002
                      === CAN ===
                      Messages queued 303, send timeouts 301, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
                      chrishamm administrators
                      I can't think of any good reason why config.g would be deleted except for perhaps a damaged SD card and/or file system. Try running a file system check when the SD card is plugged into a PC.
                      If you are not planning on changing it again soon, you can right-click config.g on Windows, go to Properties and check the "Read-only" attribute. That way RRF and/or DWC cannot delete or modify it.
                      Duet software engineer
                      undefined 1 Reply Last reply 18 Feb 2021, 09:11 Reply Quote 0
                        jay_s_uk @chrishamm
                        chrishamm said in Deleting config.g file:
                        @Phaedrux This is my new thing I've learnt for today. This might be good to detail somewhere. Especially for people who use a duet machine in a schools environment and want a way to stop people messing with the settings
                          idaho creator
                          I will lock the file. It is frustrating to have it happen the first several times it was bad cause I didnt have back up. now I have backup but I have made changes and have to figure out. I now have a rolling backup I manually do.
                            T3P3Tony administrators
                            @idaho-creator when the file gets deleted, is the config.bak still there?
                            undefined 1 Reply Last reply 18 Feb 2021, 18:45 Reply Quote 0
                              idaho creator @T3P3Tony
                              @T3P3Tony no it doesnt. The picture in the second post is what is left in the folder. I am also having to fight the board connecting to the wifi. It occurs now every other reset making me have to reset by pressing the stop button on the duet mini.
                                The files being deleted is very odd.
                                We have a macro for renamin and deleting files at the end of the board testing. is there any chance that that file could be being run. whats in your /macros directory?
                                undefined undefined 2 Replies Last reply 18 Feb 2021, 19:15 Reply Quote 0
                                  @T3P3Tony if you are referencing 2_tests_completed macro yes I have that macro but I dont use macros. I will delete it.
                                  undefined 1 Reply Last reply 19 Feb 2021, 17:29 Reply Quote 0
                                    If it happens again please let us know, and if it does I think we should replace the board in case it's an issue with the card slot.
                                    When and where did you purchase it?
                                    undefined 2 Replies Last reply 19 Feb 2021, 18:31 Reply Quote 0
                                      T3P3Tony administrators @idaho creator
                                      @idaho-creator yes feel free to delete that macro
                                      It would also be good to see if the problem re-occurs with a different SD card.
                                      undefined 1 Reply Last reply 19 Feb 2021, 18:32 Reply Quote 0
                                        idaho creator @Phaedrux
                                        @Phaedrux I purchased through filastruder. I am still having wifi issues were it wont connect to wifi either about every other reset. sometimes it connects but sometimes I have to reset board 2 or 3 times.
                                          @T3P3Tony I had used different sd card and problem still occurred but that macro was still in macro folder. It has been deleted.
                                          6 out of 45
