    New to Duet but heading to a major project. Advise needed.
    49
    2.8k
    • alankilianundefined
      alankilian
      @Marcossf I took a look at the manual for your stepper drivers and you certainly CAN use all the control signals at 5 Volts.
      Signals sent to the controller go into LEDs, so you the 390 Ohm resistor is there to keep the LED from burning out due to overcurrent. That's the standard way to allow the user of the controller to select whatever voltage they desire to control the equipment.
      Signals that come out of the controller are open-collector transistors, and you can choose what voltage is applied to the transistor. That's also the standard way to provide an interface that supports different voltage needs.
      Ask the representative from the company if you can supply 5 Volts to COM1+ They should say Yes. If they do not, I would highly recommend first asking to try a different representative and if that fails, I guess you need to look for a different stepper controller company.
      Marcossfundefined 1 Reply Last reply Reply Quote 0
      • Marcossfundefined
        Marcossf @alankilian
        @alankilian said in New to Duet but heading to a major project. Advise needed.:
        COM1+ input must be 24V. It is the power supply for the motor and also common for the driver supply. NP and PP (pulse and direction) accept the signal at 5v, but not all other I/Os
        Initially this is what I thought, until I spoke with the support technician at SMC Spain and he confirmed that the I/O signals are at the same voltage as the power supply (24v).
        The DIR and STEP signals are the only ones that admit 5V through an external circuit with the corresponding limiting resistors.
        My intention was to be able to use these drivers with ENA, DIR and STEP on the 1XD board and for the integrated closed loop part to be managed by the driver itself, with the home signal apart, but that's all. To which they replied that it is not possible.
        I have looked at the Thomson Linear and the Yamaha Transervo, and from what I see in their driver info, the signals and voltage are the same as the SMC driver. It appears to be the standard control for industrial PLC servos/steppers.
        @T3P3Tony said in New to Duet but heading to a major project. Advise needed.:
        how many other signals do you need to control on the drivers (that are at 24V?)
        Also it would be worth looking at alternative drivers that work with 5V signal levels.
        Yellow mandatoy, blue recommended but optional:
        For SMC drivers, a minimum of 8 I/O signals are required. Unfortunately SMC does not allow controlling its linear actuators with other brands drivers.
        I'm starting to look for alternatives with a similar form factor that can be more easily controlled, but I don't like what I find so far (poor support, no warranty, lack of approvals).
        I'll keep searching. Thanks to both.
          alankilian
          If your contact is telling you COM1+ on CN5 is the power supply for the motor, you still need to get in touch with someone more knowledgeable at their company.
          COM1+ Is not the power for the motors.
          Motor power is supplied via M24V on connector CN1 according to the document you linked to in your first posting.
          If these folks built a 24-Volt only controller you don't want to work with them anyway.
          • Marcossfundefined
            Ok, I understand what you mean, but it seems to me that there's a confusion somewhere.
            Obviously the motor and driver main supply are in CN1. It may not explain me well, my fault.
            However, in CN5, which is the connector that has to be wired to the Duet 1XD, pin 1-COM + is powered at + 24v, and internally also powers the I/O pins of the driver, except ±NP and ±PP.
            It is not like this? How would you connect it according to your suggestion to the Duet board? Do you still think it is possible?
            I do not rule out that the SMC technician could have no idea, what it may be, or that I am not interpreting the data correctly.
            • Marcossfundefined
              Marcossf
              I found this other schematic that draws two power supplies. It is true that I don't understand what the source connected to COM+ uses for.
              I'll ask for clarification asap.
              • HebigTundefined
                HebigT
                You'll have independent z-axes? I was building a machine like this in the past. Here is a relevant thread for dealing with the different z-axes offsets. It worked well enough.
                https://forum.duet3d.com/topic/18051/printer-with-two-independent-z-axes-how-to-synchronize
                  alankilian
                  If you want to use this device and follow the instructions of your technician, you can build a pretty simple board that converts all the signals you need.
                  Or you can buy some existing boards to convert the levels for you.
                  I would recommend just buying the level translator boards you need and wire them up.
                    T3P3Tony administrators
                    If possible i would avoid having two sets of optocouplers in the system (from Duet 3.3V/5V signals ->24V and then from 24V on the input to the servo logic) each optocoupler increases the delay which reduces your maximum step rate. and increases direction hold time.
                    look for fast level shifting options, either off the shelf of you can make a custom board.
                    • Marcossfundefined
                      Marcossf
                      Okay, signal conversion would work, but still there aren't enough I/O pins on the 1XD board to control all the signals received from the servo.
                      I'd better get other solutions like Oriental Motors or Clearpath with closed loop servos but only using DIR / STEP signals. SMC drivers seem too advanced for this controller. We won't to unnecessarily complicate the machine just by wanting use certain HW.
                      • Marcossfundefined
                        Marcossf
                        I think we've found a feasible alternative to SMC drivers.
                        It's from OrientalMotors, and it is their AZD-K controller:
                        http://www.orientalmotor.eu/msites/az/en/
                        It has internal closed loop with absolute encoder BUT can be controlled just with 4 signals, STEP and DIR at 5V_10mA, and apparently without using additional control pin. The closed loop position correction it's done internally in the driver controller.
                        I'll ask them for a demo unit, to see if can work with Duet 1XD board.
                        I have the doubt of how to homing the axes with this configuration. It is assumed that a G28 XO Y0 Zxxx could also be sent and as it already know where its absolute origin is, it would be positioned at zeroes before being able to move to print, although the Duet does not have real position feedback.
                        What do you think about? It' would work?
                        • hackinistratorundefined
                          hackinistrator
                          if its not a secret , can you tell what are you trying to extrude that needs those overkill actuators and servos , for such a small printing volume (200x200x100) ?
                          • Marcossfundefined
                            Marcossf
                            Microdosing of drugs and biochemicals. And other things like inkjet heads, spectrographs in the future ...
                              T3P3Tony administrators @Marcossf
                              @Marcossf any reason not to use homing on the Duet using standard endstops? move an axis to a limit whith and endstop trigger - that position is then known by the Duet (at whatever the limit is set in firmware) then proceed from there. The "absolute" psotion read internally by the servo and used for closed loop control does not need to match the position the Duet is using.
                              Marcossfundefined 1 Reply Last reply Reply Quote 1
                              • Marcossfundefined
                                Marcossf @T3P3Tony
                                @T3P3Tony Wiring and possible points of failure.
                                The printer internal environment and moving parts must be as clear, free of cables and protrusions as possible for the user.
                                The previous functional proto we made used sensorless with the TMC drivers, which works reasonably well, and putting endstops is a step backwards.
                                The home position with an absolute encoder like this would ensure that the mechanical zero position is always exactly the same. Simply the Duet controller would have to know that this position is the zero point, before starting any movement.
                                I do think it is possible to wire a "Goto home" command to the driver, but I still don't know how.
                                  @Marcossf the new drivers you selected presumably have an output to show they are at the "home" position which can be used with the input on the 1XD?
                                  • Marcossfundefined
                                    Marcossf @T3P3Tony
                                    @T3P3Tony This is the part we still need to discover, all the rest seems good so far.
                                    This is the manual:
                                    https://www.orientalmotor.eu/media/files/azd-kx_hm-60315-2e.pdf?dwnl=1
                                    • Marcossfundefined
                                      Marcossf
                                      Hello everyone
                                      The closed-loop motors and controllers we are evaluating for Oriental Motors also have some drawbacks to making the connection to the 1XD board. Less trouble than SMC but it isn't yet clear to be able to do it and make it simple.
                                      His technician said:
                                      The inputs of the AZD-K need 24 VDC. When operating with 5 VDC it will not work. Only the pulse and direction signals of the AZD-K work with 5 VDC.
                                      The same is with the outputs, they work at 12 - 24 VDC with 10 mA max.
                                      Do you think a board like that could work to handle the control signals while converting the voltage?
                                      https://cutt.ly/GlWFhPD
                                      I have asked them for a demo unit to see if we can make it work.
                                      We were hoping we had been found something that would work out of the box. 😖
                                      • Marcossfundefined
                                        Marcossf
                                        Hi everyone,
                                        We have made progress with OrientalMotors's closed loop encoder motor in conjunction with the 1XD board.
                                        Just with ±STEP and ±DIR, we have been able to move it and within its software define the required HOME point, its maximum travel and the rest of the parameters. So it works and it does it very well, without a single lost step at any speed or force.
                                        When we HOME to that axis from DWC, it moves to the home that we have defined correctly, and it waits until the timeout for an endstop to be pressed, which does not exist. Once the HOME timeout has expired, we can do a G92 X0 Y0 Z0 to define that this position is HOME and from there it works perfectly as the printer know their origins.
                                        My questions are:
                                        The motor driver has a HOME-END output pin that we would like to configure in any of the IN inputs of the 1DX board to function as the endstop trigger. The driver outputs a signal that indicates that it has reached home, which would be enough for the G28 to work on its own.
                                        Also, would the ioX.in pins directly admit the 24v signal coming from the driver for this or would we also have to transform it to 5V?
                                        How can I do this, what is the necessary configuration?
                                        Although the G28 when launched to the printer interprets it and makes the move to HOME, is there a way that when sending a G28, it can trigger a signal to the OUT pin of the 1XD so that the driver receives the signal command to go to HOME? It may not even be necessary.
                                        The ioX.out signals only work with a maximum current of 3mA so I don't know if it will be enough current to drive the optocoupler that we use to change the signals from 24v to 5V and vice versa.
                                        I think if could be possible at least to receive the HOME-END signal as endstop we could use a real closed loop with 1XD boards.
                                        The next challenge would be to interpret a STALL signal the driver has, to return to home and pause, and then continue where the obstacle has occurred, but that would be another chapter.
                                          I think the io inputs on the 1xd should be usable at 24v
                                          Three digital inputs with permanent 27K pullup resistors, protected against over-voltage: io0.in, io1.in, io2.in
                                          Example use - Alarm input, Brake Release input, Endstop
                                          But I've sought clarity on whether they are 30v tolerant the same as the inputs on the duet3 mainboard.
                                          • Marcossfundefined
                                            Marcossf
                                            Do you think I could test directly from the motor controller if there is no risk of burning the board?
                                            The idea is that the signal received on that pin acts as an endstop that indicates to the firmware that it is at home.
