    Capricorn PTFE Tubing XS- Low Friction
    85
    18.4k
    • Sethipusundefined
      Sethipus
      The towers and the Groot were both set to 60mm/s, but what the actual speed was would be impossible to say, since both have sections small enough that acceleration settings would slow things down somewhat. The arm that you see in the Groot photo is approximately the same diameter as the retraction towers, so we might assume that the nozzle reached similar speeds going around that arm as it did on the towers, though the towers have 90 degree corners and the arm doesn't.
      I just ran some more towers where I went from 2 to 3 perimeters to see if the difference was simply down to how much actual printing got done between retractions (see if maybe on the towers the extruder/bowden/nozzle system hadn't reached its normal steady state pressure due to how little was printed between retractions and repriming). At 2.0mm retraction I got enough oozing to create the usual "hangers" sticking off the side of the tower at an angle. At 2.5mm there were little nubbins sticking out, and at 3.0 there were nearly but not quite nonexistent nubbins, and at 3.5mm retraction no sign of any oozing whatsoever.
      I've got to go somewhere for a while, so I just started a Baby Groot with retraction set to 3.1mm. I'll see how it went when I get back.
      If it works great, and continues to work for other types of prints with larger pieces, sharper corners, wider spaces, etc., then I'll know that for at least this filament the new retraction of 3.1mm is it. This is compared to 4.6mm with my previous cheapo PTFE.
      While I was hoping to get it all the way down to 2mm, and thought I had with my original retraction tests, I'll say that 3.1mm from 4.6mm is a huge improvement. It means that the pressure "spring" inside the tubing from the filament kinking up and absorbing or releasing incoming filament feed rates is substantially reduced by using this tubing with its smaller diameter.
      This filament (Hatchbox black PLA) measures out at only 1.72 to 1.73mm, unfortunately. If reducing the diameter of the PTFE tube is mostly responsible for reducing the bowden tube pressure spring, then it's probably also true that the closer in diameter you get from the filament to the ID of the PTFE tube, the better. I'd be better off with filament measuring 1.76 or 1.77 than 1.73.
      Sounds like a small difference, but the bowden tube pressure spring effect is responsible for keeping filament flowing more than you want going into corners where the deceleration of the nozzle requires slowing down the filament flowrate to avoid blobbing, and not accelerating as fast it should coming out of corners (which results in thinning of the part coming out of the corners). If a difference of only .15mm inside diameter of the bowden tube can drop my retraction from 4.6 to 3.1mm, then .03mm difference in filament diameter is a bigger deal than you'd think.
      Most of my filaments measure out at 1.75 or 1.76 or so. I'll have to figure out what filaments tend larger and buy more of that, and less of the stuff that measures smaller. I'm disappointed that this Hatchbox PLA measured out smaller like this. My Hatchbox PETG typically comes in at least 1.75mm.
      • Whitewolfundefined
        Whitewolf
        I get mixed results based on filament. Some filaments i am running as low as 1.25mm with a 400mm tube.
          Whitewolf
          I should add that i have not compared different brands of the same type of filament and also pressure advance can have some effects on what you are seeing, try playing with it on the fly when printing grub… it also plays differently based on filament. Also do you use a retainer clip on the collet where the ptfe enters your hotend... i have found this to improve results as well (several designs sare available on thingiverse)
          • Sethipusundefined
            Sethipus
            I had pressure advance on with S0.12 and was doing a test print with retraction at 3.1mm and getting stringing and oozing. I turned off the pressure advance on the fly and the stringing just stopped.
            Went back and tried more lower retraction settings and in the upper 2s it was greatly reduced, but not eliminated or all but eliminated until 3.1mm. This is on that baby Groot. I'm doing a different print now with different infill and perimeters and whatnot, no pressure advance, with 3.1mm retraction. Haven't gotten to the point yet where I'd expect stringing if it was going to happen. I'll know in the morning.
            I'm betting that whatever stringing or oozing I get will in fact be very dependent on the specific filament, with the thicker filaments behaving better than the narrow ones like this 1.73. I've got a roll of cheap Chinese filament that's only 1.68 and it's just crap because it flexes too much.
            I've got this spool of ASA I've been experimenting with that's a little thicker. I don't recall but it may have been 1.77mm or so. I'm anxious to give it a try.
            Until this Capricorn tube I'd had to use 4.6mm as my general retraction setting. Even if I've only gone from 4.6mm to 3.1mm that's a substantial reduction, given that every mm of retraction represents a milimeter of spring-like compression in the tube that's going to blob or underextrude my accelerations and decelerations.
            This has me thinking about the rest of my system. There are some spots at the extruder and going into the tube retainer that's screwed into the extruder where the filament isn't well constrained and can bend and flex a little. I'll see what I have to do to provide some contraint to the filament in these areas. It may be good for another little drop in retraction.
            And no, I don't actually have a retaining clip under the tube entry on the print head. The carriage plate I printed up blocks it. I've been thinking about remixing it to add a little hole where I can slide in a retaining clip with a pair of tweezers or something. I've got a retaining clip at the extruder end.
            So far for $10 or whatever it was I think the Capricorn tube is worth it.
            • fcwiltundefined
              fcwilt
              I think somebody is making a good deal of money with this product.
              I wonder if if can be purchased in bulk.
              Still I would like to try it.
                Whitewolf
                It can be purchased in bulk, filastruder cuts to length ordered. It is pure raw ptfe and tight torrence production processes but yeah still overpriced but the results i have seen make it a necessary upgrade to any bowden system.
                • saffiundefined
                  saffi
                  For a Rostock Max sized build with a Bondtech Extruder and the Capricon XS my settings for Simplify3D are copied below for reference. They seem to work pretty well with PLA. I have not had any jamming issues so far.
                  I reduced my retraction length by about 25% after installing the Capricorn tubing. I would guess at 25% - 50% reduction in your previous retraction distance should work pretty well.
                  [c]Retraction: 5.00mm
                  Extra Restart Distance: -0.50mm
                  Retraction Vertical Lift = 0.15mm
                  Retraction Speed: 100mm/s
                  Coasting Distance: 1.50mm
                  Wipe Distance: 2.00mm[/c]
                  Prusa i3 Style Printer with Duet WiFi, E3D Volcano, Bondtech BMG
                    Whitewolf
                    @Sethipus:
                    Did this work on the groot?
                    • Sethipusundefined
                      Sethipus
                      I had a Groot printout working great with 3.1mm with only a few faint whisps of string until one of his arms broke for unrelated reasons (only 2 perimeter walls, low infill, and .35mm nozzle with .35mm line width, on a fairly thin arm, so it was pretty weak).
                      I did print out this geometric torture test thingy with it this morning. This was 3.2mm retraction, .35mm nozzle, .18mm layer height.
                      You can see a few very faint whisps of string. Given the challenge of printing this, I think that's pretty decent. With my normal PTFE tube I wouldn't have printed this with less than 4.5 or 4.6mm retraction. And this is with 1.71-1.72mm filament.
                      I haven't loaded the ASA filament again to try it out. It measures out at an even 1.75mm.
                      • SpeedyDadundefined
                        SpeedyDad
                        Wow. This stuff is amazing. I'm running TPU through a 2 foot bowden tube pushed by a Titan extruder and no problems at all.
                        • fmaundefined
                          fma
                          I don't remember if these links have been posted on this forum. In case, you may find them usefull to calibrate retract with Bowden config:
                          https://airtripper.com/1320/airtripper-extruder-filament-force-sensor-announcement
                          https://airtripper.com/1338/airtripper-extruder-filament-force-sensor-introduction
                          https://airtripper.com/1473/airtripper-extruder-filament-force-sensor-design-3d-print
                          https://airtripper.com/1397/electronic-kitchen-scales-teardown-versus-load-cells
                          https://airtripper.com/1626/arduino-load-cell-circuit-sketch-for-calibration-test
                          I will soon order this load cell:
                          http://www.ebay.fr/itm/Electronic-Balance-Weighing-Load-Cell-Sensor-5Kg-with-HX711-Module-/162241279056
                          Frédéric
                          • KeeganBundefined
                            KeeganB
                            If you need/want more than a meter of it, you can find it cheaper directly from Capricorn. They have a few bundle options too that come with a cutter and stickers.
                            I JUST bought some generic PTFE off of Amazon Prime. While it seems to have made a nice improvement over my worn out tube, I kinda wish I had remembered about this Capricorn stuff.
                            Artemis
                            Rostock Max v2
                            Orion
                            • DADIYundefined
                              DADIY
                              @KeeganB:
                              I just ordered some direct from Capricorn, but based on the live Q&A Tom did with E3D they are about to become a UK reseller for it.
                              • KeeganBundefined
                                KeeganB
                                I just ordered 2 meters of the XS (the dark blue 1.9 or 1.8 ID) Capricorn tubing. I will try to report back once I receive and install it.
                                Artemis
                                Rostock Max v2
                                Orion
                                • Shenundefined
                                  Shen
                                  I've got both the XS and TL series. The supposedly smaller inner diameter of the XS series is actually slightly larger than the TL series, but I'm sure it's just a batch issue. Both the XS and TL tubing does have very high quality. Maybe because of my old PTFE tubing already has a small inner diameter, the optimal pressure advance value for me only lowered to 0.5 from 0.6.
                                    @Shen:
                                    What sort of hot end do you have, and how long is the Bowden tube? It's unusual to need as much pressure advance as 0.5 or 0.6 except when using mixing extruders.
                                    • Shenundefined
                                      Shen
                                      @dc42:
                                      @Shen:
                                      I'm using it on a BCN3D sigma converted to duet wifi and 1.75mm e3d v6. The bowden tube is about 60cm. Maybe my way of finding out pressure advance value is wrong. I was doing a 20mm x 20mm tower in vase mode at 100mm/s speed. The problem on the corners resolves at a pressure advance value of 0.5.
                                        Thanks! That's a perfectly good way of finding a good pressure advance setting (but see the caveat below). The corners look quite bad with no pressure advance, but perhaps that's because you were printing quite fast, and pressure advance matters more at high printing speeds.
                                        One thing to watch out for is that high pressure advance settings have the side effect of reducing acceleration unless the extruder jerk is set quite high, and the reduced acceleration may contribute towards the pressure advance "working".
                                        • Shenundefined
                                          Shen
                                          @dc42:
                                          Since pressure advance should work independent of speed, I purposely used a high speed for magnifying it's effect. I don't print at such high speed. My extruder acceleration is 5000mm/s and jerk is 10mm/s, whereas the X/Y acceleration is 2000mm/s and jerk is 8mm/s. I guess you are right, maybe the limited printing speed from pressure advance is contribute towards the pressure advance "working". I should re-run the test with lower X/Y jerk and higher E jerk.
                                          • appjawsundefined
                                            appjaws
                                            Has anybody found a UK supplier of Capricorn PTFE Tubing XS- Low Friction?
                                            appjaws - Core XYUV Duet Ethernet Duex5
                                            firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                                            Ormerod 1-converted to laser engraver, Duet wifi
                                            OpenSCAD version 2024.03.18
                                            Simplify3D 5.1.2
