    RepRapFirmware road map Q1 2021
    Future Direction
    20
    29
    4.0k
    • gringoundefined
      gringo
      Will this be implemented in one of the next Firmware?
      Magnetic Compensation
      • NexxCatundefined
        NexxCat
        Thank you for your continued work on improving RepRapFirmware and the entire Duet ecosystem @dc42 🙂
        Do variables fall on the roadmap anywhere yet? I know it's possible right now using fake axes / etc, and I don't have a use in mind yet, but I was just curious.
          dc42 administrators @NexxCat
          @NexxCat said in RepRapFirmware road map Q1 2021:
          Variables are a high priority, so they may be included in 3.4.
          1 Reply Last reply Reply Quote 4
          • CCS86undefined
            CCS86
            Very excited for the motion developments slated for 3.4!
            Any chance PA can get some love in 3.3 or 3.4? I'd love to test some of the suggestions I made here, if they are reasonable to implement:
            https://forum.duet3d.com/topic/17752/pressure-advance-discussion-for-future-development
            • chivelundefined
              chivel
              Dear Sirs
              Please explain to me why in the Status section for the Delta printer at the HOME point, the head position X and Y coordinates are 0 and Z is 999.In Delta X,Y,Z are equivalent.
              May be problem in Firmware version?
              • Dougal1957undefined
                Dougal1957 @chivel
                @chivel said in RepRapFirmware road map Q1 2021:
                Dear Sirs
                Because on a delta you should always home to X0 Y0 Z(max) as this is the only way the kinematic can know where the nozzle is located I think the main confusion comes from the Towers often labelled as X Y and Z instead of A B and C.
                This this subject should not be in this thread it is off topic.
                • vistalertundefined
                  vistalert
                  I'm very much looking forward to the next wave of upgrades on RRF and also physical upgrades to my machine. I'll be selecting https://main.eva-3d.page/ for my carriage, and note that one of the community members has already created a design which includes support for the ADXL sensor, used in input shaping calibration.
                  If you're not aware of the EVA modular carriage system I'd encourage you to take a look. Like the team here, there is incredible work being done there.
                  • compatibilizerundefined
                    compatibilizer
                    I was wondering if the experimental M954 command does (or could) work for the 6HC board too? I have a spare one which I would love to use as a 6 drive expansion board.
                      dc42 administrators @compatibilizer
                      @compatibilizer said in RepRapFirmware road map Q1 2021:
                      In the latest beta firmware, yes it does.
                        jay_s_uk
                        @dc42 is there a planned improvements spreadsheet for 3.3 similar to the one made available for 3.2? https://forum.duet3d.com/topic/16291/reprapfirmware-3-2-planned-improvements
                        • Diamondbackundefined
                          Diamondback
                          Really looking forward to the input shaping work that is already happening! 🙂
                          I have a question though.
                          I'm currently building the wiring loom for my custom toolchanger and was wondering if there is any thoughts yet on whether or not the Duets will have the abilitiy to connect something like an ADXL345 sensor to them for auto calibrating the input-shaping parameters.
                          If so, is there any preferred connection method yet (I2C vs SPI), if there is, I'd directly include the necessary cables in my loom to the carriage head, which has a built-in mount for such a sensor and save me some headache of having to rebuilt the loom further down the line.
                          Thanks 🙂
                            T3P3Tony administrators
                            We are considering how we support stand alone accelerometers connected to Duet 3 mainboards. It is likely to be over SPI connected to the Temperature DB connector as I2C is not appropriate for long distance, off board wiring runs.
                            Diamondbackundefined oliofundefined 2 Replies Last reply Reply Quote 1
                              dc42 administrators @jay_s_uk
                              @jay_s_uk said in RepRapFirmware road map Q1 2021:
                              Not yet, because whether some improvements go into 3.3 and 3.4 depends on when DCS 3.3 is ready. But now that 3.3beta2 is out, we have a much better idea. RRF 3.3 is likely to include the improvements already in 3.3beta2, plus the ability to switch tool heaters between off/active/standby without selecting/deselecting the tools, and a few more bug fixes and minor new features.
                              fcwiltundefined 1 Reply Last reply Reply Quote 2
                              • fcwiltundefined
                                fcwilt @dc42
                                This post is deleted!
                                  dc42 administrators @fcwilt
                                  @fcwilt said in RepRapFirmware road map Q1 2021:
                                  Any chance of having G30 accept X and Y parameters (when no P parameter is present) thus doing the math and movement needed to place the probe at X and Y without needing a preceding G1 command?
                                  If the printer has not been homed then moving to an XY position at the start of a G30 probe move is problematic on some types of printer, e.g. delta printers. So it's possible after Z homing has been done (and the print head would move rapidly to the specified position and dive height before probing), but potentially problematic for a G30 homing move.
                                    Diamondback @T3P3Tony
                                    @T3P3Tony Perfect, thanks a lot, I will include wiring for 4-Wire SPI then. 👍
                                    • fcwiltundefined
                                      fcwilt @dc42
                                        droftarts administrators @fcwilt
                                        @fcwilt Could you move this suggestion to firmware wishlist? I think that would be a more appropriate place to discuss.
                                        • fcwiltundefined
                                          fcwilt @droftarts
                                          @droftarts said in RepRapFirmware road map Q1 2021:
                                          Will do.
                                          • oliofundefined
                                            oliof @T3P3Tony
                                            @T3P3Tony Any chance for accelerometers to be connected to the 1LC?
