    RepRapFirmware road map Q1 2021
    Future Direction
    20
    29
    4.0k
    • chivelundefined
      chivel
      Dear Sirs
      Please explain to me why in the Status section for the Delta printer at the HOME point, the head position X and Y coordinates are 0 and Z is 999.In Delta X,Y,Z are equivalent.
      May be problem in Firmware version?
      • Dougal1957undefined
        Dougal1957 @chivel
        @chivel said in RepRapFirmware road map Q1 2021:
        Dear Sirs
        Because on a delta you should always home to X0 Y0 Z(max) as this is the only way the kinematic can know where the nozzle is located I think the main confusion comes from the Towers often labelled as X Y and Z instead of A B and C.
        This this subject should not be in this thread it is off topic.
        • vistalertundefined
          vistalert
          I'm very much looking forward to the next wave of upgrades on RRF and also physical upgrades to my machine. I'll be selecting https://main.eva-3d.page/ for my carriage, and note that one of the community members has already created a design which includes support for the ADXL sensor, used in input shaping calibration.
          If you're not aware of the EVA modular carriage system I'd encourage you to take a look. Like the team here, there is incredible work being done there.
          • compatibilizerundefined
            compatibilizer
            I was wondering if the experimental M954 command does (or could) work for the 6HC board too? I have a spare one which I would love to use as a 6 drive expansion board.
              dc42 administrators @compatibilizer
              @compatibilizer said in RepRapFirmware road map Q1 2021:
              In the latest beta firmware, yes it does.
                jay_s_uk
                @dc42 is there a planned improvements spreadsheet for 3.3 similar to the one made available for 3.2? https://forum.duet3d.com/topic/16291/reprapfirmware-3-2-planned-improvements
                • Diamondbackundefined
                  Diamondback
                  Really looking forward to the input shaping work that is already happening! 🙂
                  I have a question though.
                  I'm currently building the wiring loom for my custom toolchanger and was wondering if there is any thoughts yet on whether or not the Duets will have the abilitiy to connect something like an ADXL345 sensor to them for auto calibrating the input-shaping parameters.
                  If so, is there any preferred connection method yet (I2C vs SPI), if there is, I'd directly include the necessary cables in my loom to the carriage head, which has a built-in mount for such a sensor and save me some headache of having to rebuilt the loom further down the line.
                  Thanks 🙂
                    T3P3Tony administrators
                    We are considering how we support stand alone accelerometers connected to Duet 3 mainboards. It is likely to be over SPI connected to the Temperature DB connector as I2C is not appropriate for long distance, off board wiring runs.
                    Diamondbackundefined oliofundefined 2 Replies Last reply Reply Quote 1
                      dc42 administrators @jay_s_uk
                      @jay_s_uk said in RepRapFirmware road map Q1 2021:
                      Not yet, because whether some improvements go into 3.3 and 3.4 depends on when DCS 3.3 is ready. But now that 3.3beta2 is out, we have a much better idea. RRF 3.3 is likely to include the improvements already in 3.3beta2, plus the ability to switch tool heaters between off/active/standby without selecting/deselecting the tools, and a few more bug fixes and minor new features.
                      fcwiltundefined 1 Reply Last reply Reply Quote 2
                      • fcwiltundefined
                        fcwilt @dc42
                        This post is deleted!
                          dc42 administrators @fcwilt
                          @fcwilt said in RepRapFirmware road map Q1 2021:
                          Any chance of having G30 accept X and Y parameters (when no P parameter is present) thus doing the math and movement needed to place the probe at X and Y without needing a preceding G1 command?
                          If the printer has not been homed then moving to an XY position at the start of a G30 probe move is problematic on some types of printer, e.g. delta printers. So it's possible after Z homing has been done (and the print head would move rapidly to the specified position and dive height before probing), but potentially problematic for a G30 homing move.
                            Diamondback @T3P3Tony
                            @T3P3Tony Perfect, thanks a lot, I will include wiring for 4-Wire SPI then. 👍
                            • fcwiltundefined
                              fcwilt @dc42
                                droftarts administrators @fcwilt
                                @fcwilt Could you move this suggestion to firmware wishlist? I think that would be a more appropriate place to discuss.
                                • fcwiltundefined
                                  fcwilt @droftarts
                                  @droftarts said in RepRapFirmware road map Q1 2021:
                                  Will do.
                                  • oliofundefined
                                    oliof @T3P3Tony
                                    @T3P3Tony Any chance for accelerometers to be connected to the 1LC?
                                      dc42 administrators @Diamondback
                                      @Diamondback said in RepRapFirmware road map Q1 2021:
                                      A quick update: I have determined that we also need an interrupt signal from the accelerometer in order to read the data fast enough. So in total it will need 5 signal wires, plus 3.3V power and ground.
                                      • yngndrwundefined
                                        yngndrw
                                        Very excited about the input shaping, especially after this video was released yesterday:
                                        https://www.youtube.com/watch?v=6JBIEJan6zs&ab_channel=Vez3D
                                        • DocTruckerundefined
                                          DocTrucker
                                          Is there a dynamic roadmap document that is periodically updated somewhere on the Github? I fully appreciate the complexities of working on projects like this and understand dates move, but perhaps a dynamic document with estimates for the next release date and a confidence level would save mods and Duet staffers fielding the same question repeatedly?
                                          'When is RRFx.x.x' coming out mush be a very popular question on these forums!
                                            dc42 administrators @DocTrucker
                                            @doctrucker said in RepRapFirmware road map Q1 2021:
                                            Not yet, but we're working on making our development more transparent after the 3.3 release.
                                            1 Reply Last reply Reply Quote 8
                                            • Pit34undefined Pit34 referenced this topic
