    Does anyone use M120 or M121?
    22
    1.3k
      I am currently implementing variables in RRF conditional GCode. Unfortunately, there is an interaction between conditional GCode and M120/M121 that causes serious complications. Does anyone actually use M120 and M121? I am tempted to remove them.
      Note, any time that a macro is called (whether implicitly by RRF or explicitly using M98), a push and pop are done around the macro call automatically.
      • fcwiltundefined
        fcwilt
        I've seen them in the list of commands but have never had any reason to use them.
        • jrocklandundefined
          jrockland
          Same here. Never used it.
          • lee7670undefined
            lee7670
            @dc42 said in Does anyone use M120 or M121?:
            M120
            Yes, I use it for certain operations not controlled by duet macros where I need to save system state before executing commands from remote sources.
              dc42 administrators @lee7670
              @lee7670 said in Does anyone use M120 or M121?:
              M120
              Can you provide examples?
              • MaracMBundefined
                MaracMB
                @dc42 please don’t remove push and pop. It is used for python post scripts that enable toolchanger post script by mkudzia84 to work.
                https://github.com/mkudzia84/toolchanger-pspp
                MaracMBundefined dc42undefined 2 Replies Last reply Reply Quote 0
                • MaracMBundefined
                  MaracMB @MaracMB
                  That script is a nice little post for PrusaSlicer. And not only for Toolchangers but any IDEX or multihead rigs..
                  • oliofundefined
                    oliof
                    @MaracMB I was able to use SuperSlicer (PrusaSlicer fork) with an IDEX without the need for any postprocessing ... regarding M120/121 -- I had looked into using them in homing macros to save state before and after sensorless homing, but the set of settings saved and restored simply didn't match. So I never used them.
                    MaracMBundefined 1 Reply Last reply Reply Quote 0
                    • MaracMBundefined
                      MaracMB @oliof
                      @oliof and it preheated hotend before toolswap?
                      It is not the ability to use, it’s the additional functionality it gives. You can use any slicer with IDEX, that’s not the point
                        dc42 administrators @MaracMB
                        @MaracMB said in Does anyone use M120 or M121?:
                        If you mean this usage:
                        ;; TOOL_BLOCK_END:{previous_extruder}
                        T{next_extruder}
                        M120
                        M98 P"prime.g"
                        M121
                        ;; TOOL_BLOCK_START:{next_extruder}
                        then M120/M121 is redundant in that context, because of the implicit push/pop around any macro call.
                        • MaracMBundefined
                          MaracMB @dc42
                          @dc42 ok. Great then
                            It turns out that DWC uses M120/M121 for good reason. So I won't remove them any time soon.
                            Sindariusundefined ctilley79undefined o_lampeundefined 3 Replies Last reply Reply Quote 0
                            • Sindariusundefined
                              Sindarius @dc42
                              @dc42 I was about to say it is used in DWC and I use it in a similar fashion in my gamepad jogger plugin.
                              • oliofundefined
                                oliof @MaracMB
                                Ah, that's nice!
                                • zaptaundefined
                                  zapta @dc42
                                  ... a push and pop are done around the macro call automatically.
                                  What will happen to a variable that was changed by a macro, will its old value be restored by the pop?
                                  • ctilley79undefined
                                    ctilley79 @dc42
                                    @dc42 Since you're keeping m120/m121, does this delay your implementation of variables significantly?
                                      dc42 administrators @ctilley79
                                      @ctilley79 said in Does anyone use M120 or M121?:
                                      Only by a few hours, I hope.
                                        A Former User
                                        This post is deleted!
                                        • o_lampeundefined
                                          o_lampe @dc42
                                          With variable declaration, I believe @chrishamm and anyone else can write their own push/pop routine and store/restore any variable they like?
                                          • felekundefined
                                            felek
                                            PanelDue also use M120/M121 gcodes
        case evExtrude:
                                            			case evRetract:
                                            				if (currentExtrudeAmountPress.IsValid() && currentExtrudeRatePress.IsValid())
                                            					SerialIo::Sendf("M120 M83 G1 E%s%s F%s M121\n",
                                            							(ev == evRetract ? "-" : ""),
                                            							currentExtrudeAmountPress.GetSParam(),
                                            							currentExtrudeRatePress.GetSParam());
                                            				break;
