    Does anyone use M120 or M121?
    22
    1.2k
      dc42 administrators @MaracMB
      @MaracMB said in Does anyone use M120 or M121?:
      @dc42 please don’t remove push and pop. It is used for python post scripts that enable toolchanger post script by mkudzia84 to work.
      https://github.com/mkudzia84/toolchanger-pspp
      If you mean this usage:
      ;; TOOL_BLOCK_END:{previous_extruder}
      T{next_extruder}
      M120
      M98 P"prime.g"
      M121
      ;; TOOL_BLOCK_START:{next_extruder}
      then M120/M121 is redundant in that context, because of the implicit push/pop around any macro call.
      MaracMBundefined 1 Reply Last reply Reply Quote 0
      • MaracMBundefined
        MaracMB @dc42
        @dc42 ok. Great then
          It turns out that DWC uses M120/M121 for good reason. So I won't remove them any time soon.
          Sindariusundefined ctilley79undefined o_lampeundefined 3 Replies Last reply Reply Quote 0
          • Sindariusundefined
            Sindarius @dc42
            @dc42 I was about to say it is used in DWC and I use it in a similar fashion in my gamepad jogger plugin.
            • oliofundefined
              oliof @MaracMB
              and it preheated hotend before toolswap?
              Ah, that's nice!
              • zaptaundefined
                zapta @dc42
                @dc42 said in Does anyone use M120 or M121?:
                ... a push and pop are done around the macro call automatically.
                What will happen to a variable that was changed by a macro, will its old value be restored by the pop?
                • ctilley79undefined
                  ctilley79 @dc42
                  @dc42 Since you're keeping m120/m121, does this delay your implementation of variables significantly?
                    dc42 administrators @ctilley79
                    @ctilley79 said in Does anyone use M120 or M121?:
                    Only by a few hours, I hope.
                      A Former User
                      This post is deleted!
                      • o_lampeundefined
                        o_lampe @dc42
                        With variable declaration, I believe @chrishamm and anyone else can write their own push/pop routine and store/restore any variable they like?
                        • felekundefined
                          felek
                          PanelDue also use M120/M121 gcodes
                                                  case evExtrude:
                          			case evRetract:
                          				if (currentExtrudeAmountPress.IsValid() && currentExtrudeRatePress.IsValid())
                          					SerialIo::Sendf("M120 M83 G1 E%s%s F%s M121\n",
                          							(ev == evRetract ? "-" : ""),
                          							currentExtrudeAmountPress.GetSParam(),
                          							currentExtrudeRatePress.GetSParam());
                          				break;
                          • arhiundefined
                            arhi
                            did, but I can remove them all easily utilizing that "any time that a macro is called a push and pop are done around the macro call automatically" ... most of them I have on start and exit of the macro so if that's done automatically ..
                            • oliofundefined
                              oliof @o_lampe
                              Possibly, but they should have at least one release where they can test old and new version to make sure they behave identically.
                              Deprecation always is tricky.
