    Here's my printable optical encoder wheel filament sensor!
    Filament Monitor
    11
    37
    2.9k
    • arhiundefined
      arhi @A Former User
      @bearer said in Here's my printable optical encoder wheel filament sensor!:
      no point in building one if using PA with current firmware
      well it depends, I did not notice PA reversing my extruder yet at the value I'm using it (0.042) .. higher values are more problematic...
      anyhow, don't have enough experience, still did not have a single print done with "enabled" sensor, I'm running it disabled for now
      • fractalengineerundefined
        fractalengineer @A Former User
        @bearer awesome 🙂 well I made all holes 2.8mm diameter so to make a 3M screw "self-tap" itself in.
        Came out great out of my well tuned railcore but it might quickly get too tight with a little overextrusion; drilling should care for that.
        Btw the clamping side of the enclosure is 3.5mm as to let the screw slide freely until set.
        @arhi @T3P3Tony That just made me think; how about a mechanical freewheel physically stopping the encoder from spinning backwards; could be a ratchet or one-way bearing -although I don't know of any smaller than 608 size) or something else
        Railcore II ZL
        • arhiundefined
          arhi @fractalengineer
          @fractalengineer said in Here's my printable optical encoder wheel filament sensor!:
          can be done for new desings, will not work for existing ones + IMO that's a wrong approach to solving software issue
            fractalengineer
            Just published the updated model using a $3 Schmitt trigger equipped arduino sensor;
            Getting much more consistent reading
            Check it out there
            https://www.thingiverse.com/thing:4445504
            Railcore II ZL
            o_lampeundefined 1 Reply Last reply Reply Quote 2
            • o_lampeundefined
              o_lampe @arhi
              @arhi said in Here's my printable optical encoder wheel filament sensor!:
              There is no way a filament will move in contra direction of the motor
              @fractalengineer thanks for warming up this thread.
              I read it and the above quote made me think of murphy's law.
              YES there is a way filament pressure builds up so hard ( eg. Bowden setups) that the stepper looses control and gets pushed backwards a few degree (visible and audible). That happens regardless of the DIR pin value.
              I've seen that happen regularly with a Diamond mixing hotend and three 0.9° steppers.
              • arhiundefined
                arhi @o_lampe
                @o_lampe possible, dunno, I assume the motor can skip steps, it can even chew the filament so motor is spinning but filament is not moving, but never seen filament going backwards trough motor .. .but yes, with bowden everything is possible, I don't use bowden, ever, I always believed it is a terrible way to do things especially as I almost never use PLA and the "springy" filaments I use really hate bowden setups
                • o_lampeundefined
                  o_lampe @fractalengineer
                  The endstop definition already has a threshold parameter. I was wondering, why that was not enough? Does the Schmitt-Trigger offer a bigger hysteresis or what's the difference?
                  fractalengineerundefined alankilianundefined 2 Replies Last reply Reply Quote 0
                    fractalengineer @o_lampe
                    @o_lampe Excellent question; it worked about fine for me with pretty high tolerance (ended up running 25-200%) but would still get occasional spikes at 400% triggering false positives
                    Then @JohnOCFII made this awesome in-depth investigation using a logic analyzer and found out that the signal was indeed noisy and implementing a schmitt trigger solved the issue; https://forum.duet3d.com/topic/19284/inconsistent-results-with-optical-encoder-wheel-filament-sensor
                    So I found an IR sensor that has a shmitt trigger integrated and modified the housing for it
                    Railcore II ZL
                    • alankilianundefined
                      alankilian @o_lampe
                      This post is deleted!
                      • rkarondeundefined
                        rkaronde
                        I remixed the design by Fractalengineer to use the Duet3D Laser Filament Monitor, and it seems to be working well.
                        https://www.thingiverse.com/thing:4796741
                        o_lampeundefined 1 Reply Last reply Reply Quote 1
                        • o_lampeundefined
                          o_lampe @rkaronde
                          @rkaronde
                          Hi, nice design.
                          You should give @fractalengineer more credit in your thingiverse-description by editing the the two typos in his name:
                          Fractalenginner
                          Frantalengineer
                          How difficult is the shaft to print? Just wondering if it wouldn't be easier to glue the disks to a steel or carbon rod?
                          • rkarondeundefined
                            rkaronde
                            Oops, fixed the typos. Thanks for catching them.
                            The shaft is really easy and quick to print. It has a few different sections of varying diameters and a hexagon shape on it. These are really important parts of the overall design.
                            Getting those craved on a steel/carbon rod would be hard
                            • blt3dpundefined
                              blt3dp
                              I’ve been looking to add something like this to my printers for a while. I was wondering if maybe a non-printed wheel might improve things. Thinking it’d take out any potential inconsistencies that may exist using a printed part.
                              Maybe something like this?
                              https://www.adafruit.com/product/3782?gclid=EAIaIQobChMIoajljtm37wIVaR-tBh3jyAO0EAQYAiABEgIQAvD_BwE
                              My 3D Printing YouTube Channel
                              Better Living Through 3D Printing
                              Follow me on Instagram and Twitter
                              Instagram
                              Twitter
                              fractalengineerundefined 1 Reply Last reply Reply Quote 1
                                fractalengineer @blt3dp
                                @blt3dp Yep depending on your printing accuracy you may have reading inconsistencies due to variation in the slots sizes.
                                Hence why I'm setting readng over 50mm; that's the distance it takes it to make one revolution, averaging out this variation.
                                There are plenty of plastic molded wheels you could use to get more consistent slots, if you redesigned the shaft and possibly the housing to fit
                                I was also thinking of laser cutting the wheel in acrylic for instance
                                Railcore II ZL
