    Here's my printable optical encoder wheel filament sensor!
    Filament Monitor
    11
    37
    3.1k
    • o_lampeundefined
      o_lampe @arhi
      @arhi said in Here's my printable optical encoder wheel filament sensor!:
      There is no way a filament will move in contra direction of the motor
      @fractalengineer thanks for warming up this thread.
      I read it and the above quote made me think of murphy's law.
      YES there is a way filament pressure builds up so hard ( eg. Bowden setups) that the stepper looses control and gets pushed backwards a few degree (visible and audible). That happens regardless of the DIR pin value.
      I've seen that happen regularly with a Diamond mixing hotend and three 0.9° steppers.
      • arhiundefined
        arhi @o_lampe
        @o_lampe possible, dunno, I assume the motor can skip steps, it can even chew the filament so motor is spinning but filament is not moving, but never seen filament going backwards trough motor .. .but yes, with bowden everything is possible, I don't use bowden, ever, I always believed it is a terrible way to do things especially as I almost never use PLA and the "springy" filaments I use really hate bowden setups
        • o_lampeundefined
          o_lampe @fractalengineer
          @fractalengineer said in Here's my printable optical encoder wheel filament sensor!:
          Schmitt trigger equipped arduino sensor
          The endstop definition already has a threshold parameter. I was wondering, why that was not enough? Does the Schmitt-Trigger offer a bigger hysteresis or what's the difference?
          fractalengineerundefined alankilianundefined 2 Replies Last reply Reply Quote 0
          • fractalengineerundefined
            fractalengineer @o_lampe
            @o_lampe Excellent question; it worked about fine for me with pretty high tolerance (ended up running 25-200%) but would still get occasional spikes at 400% triggering false positives
            Then @JohnOCFII made this awesome in-depth investigation using a logic analyzer and found out that the signal was indeed noisy and implementing a schmitt trigger solved the issue; https://forum.duet3d.com/topic/19284/inconsistent-results-with-optical-encoder-wheel-filament-sensor
            So I found an IR sensor that has a shmitt trigger integrated and modified the housing for it
            Railcore II ZL
            • alankilianundefined
              alankilian @o_lampe
              This post is deleted!
              • rkarondeundefined
                rkaronde
                I remixed the design by Fractalengineer to use the Duet3D Laser Filament Monitor, and it seems to be working well.
                https://www.thingiverse.com/thing:4796741
                o_lampeundefined 1 Reply Last reply Reply Quote 1
                • o_lampeundefined
                  o_lampe @rkaronde
                  @rkaronde
                  Hi, nice design.
                  You should give @fractalengineer more credit in your thingiverse-description by editing the the two typos in his name:
                  Fractalenginner
                  Frantalengineer
                  How difficult is the shaft to print? Just wondering if it wouldn't be easier to glue the disks to a steel or carbon rod?
                  • rkarondeundefined
                    rkaronde
                    Oops, fixed the typos. Thanks for catching them.
                    The shaft is really easy and quick to print. It has a few different sections of varying diameters and a hexagon shape on it. These are really important parts of the overall design.
                    Getting those craved on a steel/carbon rod would be hard
                    • blt3dpundefined
                      blt3dp
                      I’ve been looking to add something like this to my printers for a while. I was wondering if maybe a non-printed wheel might improve things. Thinking it’d take out any potential inconsistencies that may exist using a printed part.
                      Maybe something like this?
                      https://www.adafruit.com/product/3782?gclid=EAIaIQobChMIoajljtm37wIVaR-tBh3jyAO0EAQYAiABEgIQAvD_BwE
                      My 3D Printing YouTube Channel
                      Better Living Through 3D Printing
                      Follow me on Instagram and Twitter
                      Instagram
                      Twitter
                      fractalengineerundefined 1 Reply Last reply Reply Quote 1
                        fractalengineer @blt3dp
                        @blt3dp Yep depending on your printing accuracy you may have reading inconsistencies due to variation in the slots sizes.
                        Hence why I'm setting readng over 50mm; that's the distance it takes it to make one revolution, averaging out this variation.
                        There are plenty of plastic molded wheels you could use to get more consistent slots, if you redesigned the shaft and possibly the housing to fit
                        I was also thinking of laser cutting the wheel in acrylic for instance
                        Railcore II ZL
