    Duet 2 wifi failures
    2.1k
      droftarts administrators @tia79
      @tia79 now it’s a SD card reading issue. Did you reformat the card? Don’t use Windows quick format, use the proper tool. What file did you decompress into the www folder? Post an image of the SD card contents, if possible. The matching version of DWC for RRF v2.03 you have installed is DuetWebControl-1.22.6.zip from here: https://github.com/Duet3D/RepRapFirmware/releases/tag/2.03
      • tia79undefined
        tia79
        @droftarts
        I decompressed the sd_content zip onto the sd card.
        https://cdn.discordapp.com/attachments/549857567342592002/821667844776919080/Screenshot_1.png
        https://cdn.discordapp.com/attachments/549857567342592002/821667845926682644/Screenshot_2.png
        https://cdn.discordapp.com/attachments/549857567342592002/821667848749056000/Screenshot_30.png
          @tia79 that all looks correct. Still not connecting?
          • tia79undefined
            tia79
            @droftarts No it doesn't.
            It doesn't even connect to my wifi. I installed the Web Interfacing matching the firmware but now it doesn't even connect to wifi.
            • Vetiundefined
              Veti @tia79
              @tia79 said in Duet 2 wifi failures:
              M21: Cannot initialise SD card 0: Card is unusable
              can you try a different sd card.
              make sure its fat formated
              • tia79undefined
                tia79
                @Veti Gotta go buy one then, i don't have this small cards. But i will try in a few days and let you know.
                • Vetiundefined
                  Veti
                  what card sizes do you have?
                  • tia79undefined
                    tia79
                    @Veti Only those that comes with Anycubic Predator and Chiron. 🙂
                    • Vetiundefined
                      Veti
                      check in a computer which filesystem you put on the sd card
                      • tia79undefined
                        tia79
                        @Veti https://cdn.discordapp.com/attachments/549857567342592002/821709016430018610/Screenshot_3.png
                          @tia79 did you format the SD card with the formatting tool from https://www.sdcard.org/downloads/formatter/index.html ? If it’s not the one supplied with Duet, what make, model and speed is it? Or post picture.
                          • tia79undefined
                            tia79
                            @droftarts It is the original Duet sd card. I got the page up again but its giving me "Your Duet rejected the HTTP request: page not found
                            Check that the SD card is mounted and has the correct files in its /www folder" even tho the content on the card is correct.
                              @tia79 how did you enable networking? By sending M552 S1 via USB? If so, the network is not being enabled because the config.g file is not being read. This will be because either the SD card isn’t working in the Duet, or the Duet SD card socket is faulty. With the information you have supplied, I don’t know which it is. So:
                              1. Format the SD card with the SD card formatting tool, copy configuration and www files on to the SD card and try again.
                              2. If that doesn’t work, inspect the SD card socket as described here: https://duet3d.dozuki.com/Wiki/SD_Card#Section_SD_Card_Socket
                                If the socket looks like the one in the picture, take a picture of yours and post it here, and we’ll work out if you need a warranty replacement.
                              • tia79undefined
                                tia79
                                @droftarts I tried to reformat the sd card but no luck. its still the "Your duet rejected the HTTP request".
                                I give up trying to fix this.
                                SD card socket pic: https://cdn.discordapp.com/attachments/549857567342592002/821769534707990558/20210317_154424.jpg
                                  Do you have some compressed air to blow off the board and the slot? It's possible there is some dirt and debris in there blocking the SD card contacts.
                                  • tia79undefined
                                    tia79
                                    @Phaedrux Dirt and debris? You sound like i used the card while i was making mudcakes 🙄
                                      Instant mudcakes. Just add water. 😜
                                      • tia79undefined
                                        tia79
                                        @Phaedrux Oh those are just from the print (duet holder). It looks like its on the card but they are mid air 🙂 And i blew the duet clean, still the same issue.
                                          When and where did you purchase the Duet?
                                          • tia79undefined
                                            tia79
                                            @Phaedrux From reprappro.me 7th July 2020
                                            redax27undefined 1 Reply Last reply Reply Quote 0
