Duet 2 wifi failures
@tia79 said in Duet 2 wifi failures:
M21: Cannot initialise SD card 0: Card is unusable
can you try a different sd card.
make sure its fat formated -
@Veti Gotta go buy one then, i don't have this small cards. But i will try in a few days and let you know.
what card sizes do you have?
@Veti Only those that comes with Anycubic Predator and Chiron.
check in a computer which filesystem you put on the sd card
@tia79 did you format the SD card with the formatting tool from https://www.sdcard.org/downloads/formatter/index.html ? If itâs not the one supplied with Duet, what make, model and speed is it? Or post picture.
@droftarts It is the original Duet sd card. I got the page up again but its giving me "Your Duet rejected the HTTP request: page not found
Check that the SD card is mounted and has the correct files in its /www folder" even tho the content on the card is correct. -
@tia79 how did you enable networking? By sending M552 S1 via USB? If so, the network is not being enabled because the config.g file is not being read. This will be because either the SD card isnât working in the Duet, or the Duet SD card socket is faulty. With the information you have supplied, I donât know which it is. So:
- Format the SD card with the SD card formatting tool, copy configuration and www files on to the SD card and try again.
- If that doesnât work, inspect the SD card socket as described here: https://duet3d.dozuki.com/Wiki/SD_Card#Section_SD_Card_Socket
If the socket looks like the one in the picture, take a picture of yours and post it here, and weâll work out if you need a warranty replacement.
@droftarts I tried to reformat the sd card but no luck. its still the "Your duet rejected the HTTP request".
I give up trying to fix this.
SD card socket pic: https://cdn.discordapp.com/attachments/549857567342592002/821769534707990558/20210317_154424.jpg
Do you have some compressed air to blow off the board and the slot? It's possible there is some dirt and debris in there blocking the SD card contacts.
@Phaedrux Dirt and debris? You sound like i used the card while i was making mudcakes
Instant mudcakes. Just add water.
@Phaedrux Oh those are just from the print (duet holder). It looks like its on the card but they are mid air And i blew the duet clean, still the same issue.
When and where did you purchase the Duet?
@Phaedrux From reprappro.me 7th July 2020
Please contact your vendor and initiate the warranty exchange process. Include a link to this thread as authorization.
@tia79
Hello, I donât know if you finally found a solution but I have the same issue: âDuet reject http request...â. I have understood the system didnât find the config.g file and also nothing else (after trying to install a new firmware).
I finally found the solution by reformatting the SD CARD. It has to be Fat 32 formatted. But this information isnât sufficient. If you use a Mac, you can also choose the partition map type to format your card. It has to be the master boot record partition map and nothing else. If you use the guid partition map, the duet doesnât recognise your config.
I hope this information could be helpful. -
@redax27 It's recommended to use the SD card formatting tool to ensure the card is properly formatted.
