    Is it possible to tweak the bed heater algorithm?
    516
    • matt3oundefined
      matt3o
      I also had to tweak my values. It is feasible but depends on your bed. What are you tuning params?
      KTWundefined 1 Reply Last reply Reply Quote 0
        jay_s_uk
        or roll back to 3.1.1 to use the other algorithms and then don't tune with the new ones.
        I had to do that on the heated bed on one of my printers
        • KTWundefined
          KTW @matt3o
          @matt3o
          M303 H0 S70
          M307 H0 R0.363 C315.930:315.930 D5.30 S1.00 V24.4 B0
          matt3oundefined 1 Reply Last reply Reply Quote 0
          • KTWundefined
            KTW @deckingman
            @deckingman
            Thank you, I will try this.
              deckingman @KTW
              @KTW If that doesn't work, you could also try increasing the "D" (dead time) parameter in your M307. Try (say) 10 secs instead of the 5.3 that the tuning algorithm calculated.
                @KTW please post your entire config.g file, also the config-override.g file if you have one.
                • matt3oundefined
                  matt3o @KTW
                  @KTW said in Is it possible to tweak the bed heater algorithm?:
                  @matt3o
                  M303 H0 S70
                  if it were my printer I would try
                  M307 H0 R0.3 C400 D6.5 S1.00 V24.4 B0
                  if you are on SSR you don't need V
                  • KTWundefined
                    KTW @dc42
                    @dc42 here is my config files.
                    I have added the command "M570 H0 P10 T5 S300" suggested by @deckingman and this seems to have helped.
                    config-override.g
                    config.g
                      What kind of a heated bed is it?
                      • KTWundefined
                        KTW @Phaedrux
                        @Phaedrux
                        It's a 220V silicone heater,
                        similar to this one:
                        https://makersupplies.dk/en/heatbed/823-heatbed-silicone-heatbed-300x300mm-220v-350w.html
                        • matt3oundefined
                          matt3o @KTW
                          @KTW as far as I understand the problem is that the sensor is integrated, for some reason RRF can't cope with that.
                            See the reason here: https://forum.duet3d.com/topic/22155/error-heater-0-fault-temperature-rising-much-more-slowly/9?_=1616081192454
                            There is still room for improvement on the new algorithm to better take into account the thermal mass of the bed plate itself.
