    Duet3D PCB delta printer effector sneak preview
    Smart effector for delta printers
    53
    367
    77.5k
      I hope we will have news on a possible pre-order for the effector soon. We don't need to have one for the numbers, we're having plenty made because we believe it will sell well. I should have the first production units to test at the end of this week.
      The advantage of a 4-wire connection is that the resistance of the wires and connectors gets cancelled out so that it doesn't affect the reading. However, E3D doesn't make a 4-wire PT100 cartridge yet. So I have a 2-wire PT100 plugged into the effector, and 4 conductors in an an 8-core cable back to the Duet. The other 4 cores are used for the Z probe connections.
      • saffiundefined
        saffi
        It will be nice to rule out bed tilt from the new probe with a fixed bed, the variable height readings at different probe locations is the only slight weakness of the FSR sensor arrangement (and it's only a .05mm variation in my experience, which can be effectively ignore for most things).
        I need to create an OpenSCAD design for a belt attachment for the PCB carriage. What are the screws spacing for a standard linear rail / the PCB carriage? I can probably make a temporary design that people can use if they are waiting on an aluminum carriage tensioner to ship.
        Prusa i3 Style Printer with Duet WiFi, E3D Volcano, Bondtech BMG
          The fixing holes on the carriage adapter are four M3 size holes on a 20mm square.
          • fcwiltundefined
            fcwilt
            Well unless it will be cost me an arm and two legs I will be ordering a few.
            • saffiundefined
              saffi
              @dc42:
              Sounds easy enough. If I create something useful, I'll post the design.
              • Dougal1957undefined
                Dougal1957
                @dc42:
                The hot end mounting hasn't changed. We managed to squeeze in 3 extra mounting holes in the production version, see https://duet3d.com/wiki/Smart_effector_and_carriage_adapters_for_delta_printer#Connectors_and_Wiring.
                Might be worth giving the dimensions of the additional mounting Holes David.
                Just so people can start working on mounting plates for different hotends.
                Doug
                • DADIYundefined
                  DADIY
                  DC42 - Just wondering if the wiring shown in the BOM for your Kossel design is still valid for the production version of the smart effector?
                  • jannisjundefined
                    jannisj
                    I have been looking at the Zesty Nimble remote direct drive extruder.
                    Would it be difficult getting this to work with the pcb effector?
                    Any thoughts on making a dual hotend pcb effector?
                    It would be really nice to print supports with pva on extruder 2 🙂
                    -Jannis
                      Dougal1957
                      The Zesty Nimble already will work on this effector exactly what I have on my Beta test one.
                      Doug
                      Sorry for the poor image Quality but you get the Idea
                      • Hergonowayundefined
                        Hergonoway
                        Dumb question, there's a jumper to switch from 12 to 24v, is it just to select the VIN you've got right, it doesn't let you plug 12v fan on a 24 VIN ?
                        Delta goes BrrrRRRRrrrrrRRRRrrr
                          Dougal1957
                          I Suspect and am sure David will confirm that it is to allow for the LED's to work of both a 12 and 24V system and that the Fans still need to be suitable for the Vin that you are using.
                          at least that's how I have mine set up.
                          Doug
                          It is absolutley the bees knees as well I am getting spot on results from my autocal on the delta of dev's of 6-7 microns and a pretty flat bed map as well.
                          • Rommieundefined
                            Rommie
                            Is there a spot to use a beard air system on the effector too not. It iced any holes for a pass through. I know Doug, myself, luckless and Brian to name a couple have this installed.
                            I'm jealous of Doug getting to try that lol I might go steal it lol
                              Dougal1957
                              No there isn't Rommie But I have designed a part to replace there Fan attachment so that the Berdair tube can be fitted but it may need adjusting slightly depending on the Diameter of the pipe that hopefully you have sent up to me lol.
                                Dougal1957
                                Also I don't have the STL for the Nimble adaptor but it is on Shapeways still for about £6 Sure Lykle will send it to you or publish it on Thingyverse now we know that the hole spacing etc on the top of the collar is not going to change
                                • Zesty_Lykleundefined
                                  Zesty_Lykle
                                  Thanks for the remind Doug!
                                  I have published the adapter on Thingiverse. Quite a simple little design really.
                                  https://www.thingiverse.com/thing:2453322
                                  Lykle
                                  Design, make and enjoy life
                                  Co Creator of the Zesty Nimble
                                  • Rommieundefined
                                    Rommie
                                    @Zesty_Lykle:
                                    I'll grab one of shapeways as I know it will be perfect
                                    • MiRundefined
                                      MiR
                                      Will the new hotend mount be mandatory to be able to use the new effector?
                                      If yes then it would be great if you could offer a bundle, that will help to reduce customs costs for importing because everything is shipped in one package from one vendor.
                                        Yes we will offer a kit comprising the effector + carriage adapters + connectors + custom E3Dv6 heatsink. You will be able to order other E3Dv6 parts at the same time if you want.
                                          @Hergonoway:
                                          It's just to select the correct series resistor for the illumination LEDs. It doesn't affect the voltage fed to the fans.
                                          Regarding the print cooling fan, we have a suggested printable design for a fan bracket and fan duct to suit a 40mm x 10mm fan; but you can of course use a different design instead.
                                            Hergonoway
                                            @dc42:
                                            So with the kit I won't use my genuine E3D heatsink but the custom one in the kit?
