Duet3D PCB delta printer effector sneak preview
Well unless it will be cost me an arm and two legs I will be ordering a few.
The fixing holes on the carriage adapter are four M3 size holes on a 20mm square.
Sounds easy enough. If I create something useful, I'll post the design.
The hot end mounting hasn't changed. We managed to squeeze in 3 extra mounting holes in the production version, see https://duet3d.com/wiki/Smart_effector_and_carriage_adapters_for_delta_printer#Connectors_and_Wiring.
Might be worth giving the dimensions of the additional mounting Holes David.
Just so people can start working on mounting plates for different hotends.
Doug
DC42 - Just wondering if the wiring shown in the BOM for your Kossel design is still valid for the production version of the smart effector?
I have been looking at the Zesty Nimble remote direct drive extruder.
Would it be difficult getting this to work with the pcb effector?Any thoughts on making a dual hotend pcb effector?
It would be really nice to print supports with pva on extruder 2-Jannis
Dumb question, there's a jumper to switch from 12 to 24v, is it just to select the VIN you've got right, it doesn't let you plug 12v fan on a 24 VIN ?
I Suspect and am sure David will confirm that it is to allow for the LED's to work of both a 12 and 24V system and that the Fans still need to be suitable for the Vin that you are using.
at least that's how I have mine set up.
Doug
It is absolutley the bees knees as well I am getting spot on results from my autocal on the delta of dev's of 6-7 microns and a pretty flat bed map as well.
Is there a spot to use a beard air system on the effector too not. It iced any holes for a pass through. I know Doug, myself, luckless and Brian to name a couple have this installed.
I'm jealous of Doug getting to try that lol I might go steal it lol
No there isn't Rommie But I have designed a part to replace there Fan attachment so that the Berdair tube can be fitted but it may need adjusting slightly depending on the Diameter of the pipe that hopefully you have sent up to me lol.
Also I don't have the STL for the Nimble adaptor but it is on Shapeways still for about £6 Sure Lykle will send it to you or publish it on Thingyverse now we know that the hole spacing etc on the top of the collar is not going to change
Thanks for the remind Doug!
I have published the adapter on Thingiverse. Quite a simple little design really.
https://www.thingiverse.com/thing:2453322 -
https://www.thingiverse.com/thing:2453322I'll grab one of shapeways as I know it will be perfect
Will the new hotend mount be mandatory to be able to use the new effector?
If yes then it would be great if you could offer a bundle, that will help to reduce customs costs for importing because everything is shipped in one package from one vendor.
Yes we will offer a kit comprising the effector + carriage adapters + connectors + custom E3Dv6 heatsink. You will be able to order other E3Dv6 parts at the same time if you want.
It's just to select the correct series resistor for the illumination LEDs. It doesn't affect the voltage fed to the fans.
Regarding the print cooling fan, we have a suggested printable design for a fan bracket and fan duct to suit a 40mm x 10mm fan; but you can of course use a different design instead.
So with the kit I won't use my genuine E3D heatsink but the custom one in the kit?
Correct
It's possible to use a v6 lite?
No but again all the other parts from the lite are the same as the full so you just need to custom Heatsink parts. plus a heatbreak, Nozzle and heater parts are common.
Doug
