Duet3D PCB delta printer effector sneak preview
Smart effector for delta printers
53
367
77.3k
    Dougal1957
    The Zesty Nimble already will work on this effector exactly what I have on my Beta test one.
    Doug
    Sorry for the poor image Quality but you get the Idea
      Hergonoway
      Dumb question, there's a jumper to switch from 12 to 24v, is it just to select the VIN you've got right, it doesn't let you plug 12v fan on a 24 VIN ?
      Delta goes BrrrRRRRrrrrrRRRRrrr
        Dougal1957
        I Suspect and am sure David will confirm that it is to allow for the LED's to work of both a 12 and 24V system and that the Fans still need to be suitable for the Vin that you are using.
        at least that's how I have mine set up.
        Doug
        It is absolutley the bees knees as well I am getting spot on results from my autocal on the delta of dev's of 6-7 microns and a pretty flat bed map as well.
          Rommie
          Is there a spot to use a beard air system on the effector too not. It iced any holes for a pass through. I know Doug, myself, luckless and Brian to name a couple have this installed.
          I'm jealous of Doug getting to try that lol I might go steal it lol
            Dougal1957
            No there isn't Rommie But I have designed a part to replace there Fan attachment so that the Berdair tube can be fitted but it may need adjusting slightly depending on the Diameter of the pipe that hopefully you have sent up to me lol.
              Dougal1957
              Also I don't have the STL for the Nimble adaptor but it is on Shapeways still for about £6 Sure Lykle will send it to you or publish it on Thingyverse now we know that the hole spacing etc on the top of the collar is not going to change
                Zesty_Lykle
                Thanks for the remind Doug!
                I have published the adapter on Thingiverse. Quite a simple little design really.
                https://www.thingiverse.com/thing:2453322
                Lykle
                Design, make and enjoy life
                Co Creator of the Zesty Nimble
                  Rommie
                  @Zesty_Lykle:
                  I'll grab one of shapeways as I know it will be perfect
                    MiR
                    Will the new hotend mount be mandatory to be able to use the new effector?
                    If yes then it would be great if you could offer a bundle, that will help to reduce customs costs for importing because everything is shipped in one package from one vendor.
                      Yes we will offer a kit comprising the effector + carriage adapters + connectors + custom E3Dv6 heatsink. You will be able to order other E3Dv6 parts at the same time if you want.
                        @Hergonoway:
                        It's just to select the correct series resistor for the illumination LEDs. It doesn't affect the voltage fed to the fans.
                        Regarding the print cooling fan, we have a suggested printable design for a fan bracket and fan duct to suit a 40mm x 10mm fan; but you can of course use a different design instead.
                          Hergonoway
                          @dc42:
                          So with the kit I won't use my genuine E3D heatsink but the custom one in the kit?
                            A Former User
                            @Hergonoway:
                            Correct
                              Cata
                              It's possible to use a v6 lite?
                                Dougal1957
                                No but again all the other parts from the lite are the same as the full so you just need to custom Heatsink parts. plus a heatbreak, Nozzle and heater parts are common.
                                Doug
                                  The first 4 production effectors passed testing this morning, so I've just given the go ahead for manufacture of the rest of this batch to proceed.
                                    Dougal1957
                                    David that is excellent news.
                                    So I guess we are talking about 2-3 weeks for them to be available then?
                                    Doug
                                      Rommie
                                      Ahhhhh I need one lol
                                        loic
                                        i really love the design and the light weight
                                        now it will be great to have piezo sensor available for this effector with nimble it could be a beast combo
                                          loic
                                          @dc42:
                                          It's a secret until we start shipping them.
                                          does it will be compatible with smoothieware software?
                                          i hope uk shipping cost will not killing us..(it so expansive..)
                                          144 out of 367
