    DWC 3.1.1
    Duet Web Control
    6.1k
    • luca Massimilianoundefined
      luca Massimiliano
      si p0 e p1 viene riconosciuto e letta la sonda ma il comando g10 p1 \p2 devo camiarli in g10 p0 e g10 p1?
        droftarts administrators @luca Massimiliano
        @luca-Massimiliano yes, change lines starting G10 P0 to G10 P1, and G10 P1 to G10 P2.
          luca Massimiliano
          VORREI FARE UNA PROVA DI STAMPA IN ABS E' CORRETTO
          HO UNA DIFFICOLTA' SUL FILAMENO :
          CONFIG.G
          HO COPIATO DAL MANUALE L ESEMPIO E COPIATO ,
          M207 S0.9 R0.0 F3000 T3000 Z0.0 ; firmware retraction settings for PETG
          M307 H0 A214.3 C641.7 D1.3 S1.00 V24.0 B0 ; Bed PID tune for 120c
          M307 H1 A491.0 C190.9 D2.8 S1.00 V23.9 B0 ; Hot end PID tune at 280c
          M566 X1200 Y1200 Z60 E3000 ; jerk settings for PETG
          M204 P1000 T4000
          Carica macro,:
          M291 P"Please wait while the nozzle is being heated up" R"Loading ABS" T5 ; Display message
          G10 S200 ; Set current tool temperature to 200C
          M116 ; Wait for the temperatures to be reached
          M291 P"Feeding filament..." R"Loading ABS" T5 ; Display new message
          M83 ; Extruder to relative mode
          G1 E10 F600 ; Feed 10mm of filament at 600mm/min
          G1 E470 F3000 ; Feed 470mm of filament at 3000mm/min
          G1 E20 F300 ; Feed 20mm of filament at 300mm/min
          G4 P1000 ; Wait one second
          G1 E-10 F1800 ; Retract 10mm of filament at 1800mm/min
          M400 ; Wait for moves to complete
          M292 ; Hide the message
          G10 S0 ; Turn off the heater again
          SCARICARE macro,:
          M291 P"Please wait while the nozzle is being heated up" R"Unloading ABS" T5 ; Display message
          G10 S100 ; Heat up the current tool to 100C
          M291 P"Retracting filament..." R"Unloading ABS" T5 ; Display another message
          G1 E-20 F300 ; Retract 20mm of filament at 300mm/min
          G1 E-480 F3000 ; Retract 480mm of filament at 3000mm/min
          M400 ; Wait for the moves to finish
          M292 ; Hide the message again
          M84 E0:1 ; Turn off extruder drives 1 and 2
            luca Massimiliano
            This post is deleted!
              Phaedrux Moderator @luca Massimiliano
              @luca-Massimiliano said in DWC 3.1.1:
              WITH WHAT I CONVERT STL IN GCODE
              Cura or PrusaSlicer
                luca Massimiliano
                  https://duet3d.dozuki.com/Wiki/Duet_Web_Control_v2_and_v3_(DWC)_Manual#Section_Jobs
                  The JOBS tab on the left side bar will show you all the gcode files.
                  luca Massimilianoundefined 1 Reply Last reply Reply Quote 0
                    luca Massimiliano
                    E' PARTITA SPERIAMO
                      luca Massimiliano @Phaedrux
                      MI POTRESTI CONSIGLIARE QUALE web camera USARE ACQUISTARE PER ABBINARE ALLA STAMPENTE ?
                        There are many webcams to choose from. The important thing is that the cam can output a image URL rather than just a video feed.
                        I use a Raspberry Pi Zero W and a Pi cam module with MotionOS.
                        https://www.adafruit.com/product/3414
                        https://github.com/ccrisan/motioneyeos/wiki
                          ciao Phaedrux ho ventola una e ventola 2 correttamente sulla scheda , comportamento da me chiesto al raggiungimento a 100 gradi del riscaldatore on . comportamento : ventola 1 al raggiungere 100 ok ventola 2 sempre on ecco config g riguardante
                          M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                          M308 S1 P"e0temp" Y"thermistor" T100000 B4388 ; configure sensor 1 as thermistor on pin e0temp
                          M308 S2 P"e1temp" Y"thermistor" T100000 B4388 ; configure sensor 2 as thermistor on pin e1temp
                          M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
                          M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                          M143 H2 S280 ; set temperature limit for heater 2 to 280C
                          M106 P0 S0 H1 T100 ; set fan 0 value. Thermostatic control is turned on
                          M106 P1 S1 H2 T100 ; set fan 1 value. Thermostatic control is turned on
                          M563 P0 S"1" D0 H1 F-1 ; define tool 1
                          M563 P1 S"2" D0 H2 F-1 ; define tool 2
                          G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
                          G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
                            Fan1 and Fan2 or do you mean Fan0 and Fan1?
                              luca Massimiliano
                              @Phaedrux said in DWC 3.1.1:
                              ho capito ,hai ragione diventa :
                              M950 F2 C"fan2" Q500 ; create fan 0 on pin fan0 and set its frequency
                              M106 P2 S2 H2 T100 ; set fan 0 value. Thermostatic control is turned on
                              M106 P1 S1 H1 T100 ; set fan 1 value. Thermostatic control is turned on
                                luca Massimiliano
                                cartesiane JPG.JPG io ho una delta kossel piano cerchio e diverse x y dove posso modificare il dvwc per avere una rappresentazione realistica? graze
