    DWC 3.1.1
    Duet Web Control
    6.1k
    • luca Massimilianoundefined
      luca Massimiliano
      This post is deleted!
        Phaedrux Moderator @luca Massimiliano
        @luca-Massimiliano said in DWC 3.1.1:
        WITH WHAT I CONVERT STL IN GCODE
        Cura or PrusaSlicer
          luca Massimiliano
            https://duet3d.dozuki.com/Wiki/Duet_Web_Control_v2_and_v3_(DWC)_Manual#Section_Jobs
            The JOBS tab on the left side bar will show you all the gcode files.
            luca Massimilianoundefined 1 Reply Last reply Reply Quote 0
              luca Massimiliano
              E' PARTITA SPERIAMO
                luca Massimiliano @Phaedrux
                MI POTRESTI CONSIGLIARE QUALE web camera USARE ACQUISTARE PER ABBINARE ALLA STAMPENTE ?
                  There are many webcams to choose from. The important thing is that the cam can output a image URL rather than just a video feed.
                  I use a Raspberry Pi Zero W and a Pi cam module with MotionOS.
                  https://www.adafruit.com/product/3414
                  https://github.com/ccrisan/motioneyeos/wiki
                    ciao Phaedrux ho ventola una e ventola 2 correttamente sulla scheda , comportamento da me chiesto al raggiungimento a 100 gradi del riscaldatore on . comportamento : ventola 1 al raggiungere 100 ok ventola 2 sempre on ecco config g riguardante
                    M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                    M308 S1 P"e0temp" Y"thermistor" T100000 B4388 ; configure sensor 1 as thermistor on pin e0temp
                    M308 S2 P"e1temp" Y"thermistor" T100000 B4388 ; configure sensor 2 as thermistor on pin e1temp
                    M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
                    M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                    M143 H2 S280 ; set temperature limit for heater 2 to 280C
                    M106 P0 S0 H1 T100 ; set fan 0 value. Thermostatic control is turned on
                    M106 P1 S1 H2 T100 ; set fan 1 value. Thermostatic control is turned on
                    M563 P0 S"1" D0 H1 F-1 ; define tool 1
                    M563 P1 S"2" D0 H2 F-1 ; define tool 2
                    G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
                    G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
                      Fan1 and Fan2 or do you mean Fan0 and Fan1?
                        luca Massimiliano
                        @Phaedrux said in DWC 3.1.1:
                        ho capito ,hai ragione diventa :
                        M950 F2 C"fan2" Q500 ; create fan 0 on pin fan0 and set its frequency
                        M106 P2 S2 H2 T100 ; set fan 0 value. Thermostatic control is turned on
                        M106 P1 S1 H1 T100 ; set fan 1 value. Thermostatic control is turned on
                          luca Massimiliano
                          cartesiane JPG.JPG io ho una delta kossel piano cerchio e diverse x y dove posso modificare il dvwc per avere una rappresentazione realistica? graze
