    Homex - and I am getting fed up
    31
    1.9k
    • jens55undefined
      jens55 @Reefwarrior
      I strip the wires using a sharp knife.
      <shudder> ..... bad ju ju all around !
      • fcwiltundefined
        fcwilt @Reefwarrior
        @Reefwarrior said in Homex - and I am getting fed up:
        I suddenly am not sympathetic. 😉
          I met Ben Heck in person and he stripped some wire with his fingernails. Never meet your heroes. 😛
          gaweyoundefined 1 Reply Last reply Reply Quote 1
          • jens55undefined
            jens55
            Fingernails won't nick your wire!
            I can't help but wonder what @Reefwarrior uses to crimp the connectors .....
            Reefwarriorundefined 1 Reply Last reply Reply Quote 0
            • gaweyoundefined
              gaweyo @Phaedrux
              @Phaedrux said in Homex - and I am getting fed up:
              silicone wire and some wirewrap wire (and probably other types) strips relatively easily with just fingernails - no big deal tbh
                Phaedrux Moderator @gaweyo
                @gaweyo said in Homex - and I am getting fed up:
                no big deal tbh
                I thought it badass to be honest.
                • Reefwarriorundefined
                  Reefwarrior @jens55
                  @jens55 16cb3311-28b7-4488-9012-1b60bc671249_1.493efc01497c7e1bd08a73efacebd4b5.jpeg
                  • jens55undefined
                    jens55 @Reefwarrior
                    To be honest, I was expecting a pair of pliers 🙂
                    If the jaws are machined then you are golden, if they are cast then you still have a problem.
                      They look identical to what I use. For what it's worth I found that I had to do a slightly lighter than full squeeze on some cables to prevent it from pinching the wire. I've since upgraded to a nicer pair with interchangeable jaws that are much better formed and it works perfectly everytime.
                        Reefwarrior @Phaedrux
                        @Phaedrux Yeah waiting for my new one to arrive 🙂
                          Reefwarrior @jens55
                          @jens55 Yep machined - not cast. 🙂
                          • o_lampeundefined
                            o_lampe @Reefwarrior
                            @Reefwarrior
                            Copper quality can also vary and the cheaper ones can break easier than others.
                            For the record, I use a formerly sharp knife to cut the insulation or (*) sometimes my teeth 😬
                            And I'm a big fan of soldering (after crimping with pliers or instead of)
                            *) don't try this at home kids 😉
                            • mrehorstdmdundefined
                              mrehorstdmd @o_lampe
                              @o_lampe It is my professional opinion as a dentist that using your teeth to strip wires is a bad idea. This is a better option, and much cheaper than a single trip to the dentist to repair a chipped tooth: https://www.homedepot.com/p/KNIPEX-7-in-Automatic-Wire-Stripper-12-62-180/205333645
                              o_lampeundefined 1 Reply Last reply Reply Quote 3
                              • o_lampeundefined
                                o_lampe @mrehorstdmd
                                @mrehorstdmd
                                I agree, but after opening a few beer with teeth they can stand it 😉
                                Just kidding, I don't drink beer.
