    Arduino as Z-Probe questions
    958
    • AdrAsundefined
      AdrAs
      That's great. And I learned, that I skip all the arduino 5V conversion stuff, and just go for an ESP module for my project 🙂 More Mhz, more memory, and free WIFI I'll never use 😄
      • alankilianundefined
        alankilian
        They also make 3.3 Volt Arduino-compatible boards if you want to stick with that.
        (And a Trinket USB-attached Arduino, although I've had problems with trinkets before.)
        AdrAsundefined 1 Reply Last reply Reply Quote 0
        • AdrAsundefined
          AdrAs @alankilian
          @alankilian Thanks, they are a bit too slow though. I need at least 16 Mhz
          fcwiltundefined alankilianundefined 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @AdrAs
            @AdrAs said in Arduino as Z-Probe questions:
            There are several Arduino boards that use 3.3 volts and have 16 MHz or better clock speeds.
            I was looking at one the other day that had 1M of program memory, 256KB of ram and a clock speed of 64MHz.
              alankilian @AdrAs
              There are SOME of Arduino-compatible 3.3 Volt boards that run fast available.
              • AdrAsundefined
                AdrAs @alankilian
                @alankilian Thanks for the list. However I couldn't find anything which is small, running on 3.3v and has >16 mhz. Nevermind though, The ESP should arrive today and suits all my needs for now.
                • fcwiltundefined
                  fcwilt @AdrAs
                  Did you see this one:
                  nano-33-ble
                  No WiFi but even smaller than the ESP and runs at a respectable 64 MHz.
                  • zaptaundefined
                    zapta
                    For 3.3v Arcuino the SMT32 blue/blackpill are a good choice. Inexpensive, good documentation, support hardware debugger, support the Arduino framework, have USB C connector (e.g. for serial output), have a builtin DFU bootloader (for dongle-less field programming), and are compatible with platformio (great dev experience).
                    E.g.
                    https://www.amazon.com/Aideepen-Programming-Emulator-Downloader-STM32F103C8T6/dp/B07WRL3DF8
                    https://www.aliexpress.com/item/4001049840288.html
                    • AdrAsundefined
                      AdrAs
                      @fcwilt @zapta
                      Thank you guys, both look awesome.
                      • AdrAsundefined
                        AdrAs
                        @dc42 I've got another question I hope you can help me.
                        • When are the deployprobe and retractprobe macros executed? Only when a BLTouch is connected, or for the other probe types as well?
                          dc42 administrators @AdrAs
                          For BLTouch they are executed before and after every probing move. For other probe types, when running G29 S0 they are executed at the start and the end of the entire probing operation. They are also executed when you run M401 and M402.
                          • AdrAsundefined
                            AdrAs
                            Ok, thank you very much!
