    Pressured air cooling controlled with servo and ball valve
    61
    3.8k
    • MaxGyverundefined
      MaxGyver
      @o_lampe
      So just to recap, these are my values:
      • min_in = 0 (M106 S0 ->Fan off)
      • max_in = 255 (M106 S255 -> Fan full on)
      • min_out = 0 (M280 P0 S0 -> Servo at 0° -> valve closed)
      • max_out =90 (M280 P0 S90 -> Servo at 90° -> valve fully open)
      So my code should look like this ?
      [**pseudo** code]
      var scale_factor = {(90 - 0) / (255 - 0)}
      var servo_out = {scale_factor * (fans[0].actualValue - 0) + 90}
      M280 P0 S{var.servo_out}
      I have not used G-Code meta commands before, so I would need a little help here to put this in clean meta code and make this work.
      -Max
      o_lampeundefined OwenDundefined 3 Replies Last reply Reply Quote 0
      • o_lampeundefined
        o_lampe @MaxGyver
        @maxgyver
        I haven't written anything in Meta-code yet, but I read a little.
        E.g. the waved brackets {} are mandatory for the outmost math-expressions.
        If you want to test it, you can replace M280...with a harmless echo P"var.servo_out"
        I believe, there is a way to call daemon.g more often to get a faster response, maybe the experts can chime in here?
        For later editing it could be useful to put the min/max values in variables too, otherwise you can cut a few corners, where a value is zero.
        • OwenDundefined
          OwenD @MaxGyver
          @maxgyver
          @maxgyver
          You would probably be better off declaring global variables in config.g then updating the value in your macro ( or daemon.g)
          If you're running in daemon.g it just seems counter productive to be declaring and freeing variables constantly.
          Config.g
          ; create variables - must be after servo is created
          global scale_factor = {(90 - 0) / (1 - 0)} ; no need for the math in this instance but it makes it clear how you arrive at the value.
          global servo_out = 0 ; set to zero initially
           M280 P0 S{global.servo_out} ; start with valve closed
          Daemon.g
          set global.servo_out = {global.scale_factor * (fans[0].actualValue - 0) + 0} ; calculate position required
          M280 P0 S{global.servo_out} ; adjust valve position.
          You could optionally use an IF statement to only adjust when required, which I suppose would reduce the traffic and cpu time by a tiny amount.
          • OwenDundefined
            OwenD @MaxGyver
            @maxgyver said in Pressured air cooling controlled with servo and ball valve:
            @o_lampe
            Actually , thinking about this, the value you get back from fans[0].actualValue will be in the range 0-1, not 0-255
            You will need to change your code accordingly.
            • OwenDundefined
              OwenD
              It's a rainy day here, so for something to do I decided to fully test this.
              Using a YM2763 13kg/cm hobby servo (externally powered so as to not risk damaging the duet).
              This has an input range of 0-180 which corresponds to the angle.
              Please refer to the notes for M280 as other servos may require different values
              It's not really necessary to create variables for all settings, but it makes adjustment and readability easier.
              in config.g
              ;Valve Control
              ; Set up scaling variables {(output_end - output_start) / (input_end - input_start)}
              M950 S1 C"exp.heater4"  ; assign GPIO port 1 to heater4 on expansion connector, servo mode
              global InputStart = 0
              global InputEnd = 1
              global OutputStart = 0
              global OutputEnd = 90
              global ScaleFactor = (global.OutputEnd - global.OutputStart) / (global.InputEnd - global.InputStart) ; no need for the math in this instance but it makes it clear how you arrive at the value.
              global ServoOut = floor(global.ScaleFactor * (fans[0].actualValue - global.InputStart) + 0.5) + global.OutputStart ; calculate position required on sevo - use floor() to apply rounding
              M280 P1 S{global.servo_out} ; adjust valve position to reflect fan speed.
              in daemon.g or macro
              set global.ServoOut = floor((global.ScaleFactor * (fans[0].actualValue - global.InputStart)) + 0.5) + global.OutputStart ; calculate position required - use floor() to apply rounding to nearest whole number
              ;echo {global.ServoOut}
              M280 P1 S{global.ServoOut} ; adjust valve attached to servo on P1 to reflect scaled fan speed.
              o_lampeundefined MaxGyverundefined 2 Replies Last reply Reply Quote 2
              • o_lampeundefined
                o_lampe @OwenD
                @owend
                Thank you for chiming in!
                Can you confirm that in math formulas no waved brackets are necessary, but when I call eg. M280 the parameter has to be wrapped in {}?
                How do I know, I have enough free memory to write longer meta-code? (AI for TicTacToe can get quite voluminous)
                OwenDundefined 1 Reply Last reply Reply Quote 0
                • OwenDundefined
                  OwenD @o_lampe
                  @o_lampe said in Pressured air cooling controlled with servo and ball valve:
                  @owend
                  Correct on both counts
                  You can use M122 to see how much of the heap is used.
                  See here
                  • o_lampeundefined
                    o_lampe @OwenD
                    @owend
                    I just found this thread, please see my reply there
                    • o_lampeundefined
                      o_lampe
                      @OwenD and @MaxGyver
                      Thinking further and having pity with the servo, it would be better to add a 'hysteresis' in the code, such as
                      [pseudo code]
                      If (abs(new_fan_value - old_fan_value) > hysteresis)
                         go on
                      else
                        break
                      That's not necessarily a problem with fan-values changing in big numbers, but a Servo also has a'deadband' which you have to keep in mind. (and for further reference, if someone wants to reuse the code for something else)
                      • MaxGyverundefined
                        MaxGyver @OwenD
                        @owend
                        I am getting the following error after inserting your code in my config.g
                        "Error: Failed to read code from macro config.g: Failed to parse major G-code number (lobal) in line 85"
                        To me, it looks like the global variable are not recognized by the firmware:
                        I am using firmware version 3.3-b2.
                        • o_lampeundefined
                          o_lampe
                          You have written servoout and also servo_out.
                          MaxGyverundefined OwenDundefined 2 Replies Last reply Reply Quote 0
                          • MaxGyverundefined
                            MaxGyver @o_lampe
                            Nope, this did not cause the error... 😕
                            "Error: Failed to read code from macro config.g: Failed to parse major G-code number (lobal) in line 4"
                            ;Valve Control
                            M950 S1 C"io4.out"  ; assign GPIO port 1 to heater4 on expansion connector, servo mode
                            global InputEnd = 1
                            M280 P1 S{global.ServoOut} ; adjust valve position to reflect fan speed.
                            OwenDundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                            • OwenDundefined
                              OwenD @MaxGyver
                              @maxgyver
                              @maxgyver
                              I'm assuming you are running the correct versions on DWC, etc etc
                              We are both running RRF3.3b2 and it works for me.
                              I'm on a Duet 2 wifi.
                              I don't have a duet 3, but I suspect it's actually coming from your M950 command on the previous line.
                              Either that are it's one of this SBC specific issues.
                              What happens when you run those commands individually from the console command line?
                              MaxGyverundefined 1 Reply Last reply Reply Quote 0
                              • OwenDundefined
                                OwenD @o_lampe
                                @o_lampe
                                That was actually my error in the original.
                                • o_lampeundefined
                                  o_lampe @MaxGyver
                                  Your parser believes global is the beginning of a move command and it can't parse "lobal" as number (0,1,2,3,4 expected)
                                  I'm with @OwenD it might be related to SBC issues.
                                  • MaxGyverundefined
                                    MaxGyver @OwenD
                                    @owend said in Pressured air cooling controlled with servo and ball valve:
                                    (...)I suspect it's actually coming from your M950 command on the previous line.
                                    It's not the M950 command (I have checked by commenting out this line)
                                    I get the same error message.
                                    -Max
                                    • MaxGyverundefined
                                      MaxGyver @MaxGyver
                                      @maxgyver
                                      After upgrading to Beta3.3 the error message has changed to the following:
                                      the code in config.g:
                                      ;Valve Control
                                      global InputEnd = 1
                                      and deamon.g
                                      -Max
                                      • OwenDundefined
                                        OwenD @MaxGyver
                                        @maxgyver
                                        Try removing all the spaces around the variable names and in the equations
                                        I'm pretty sure I read another post where that was an issue on SBC
                                        There is also a 3.3RC1+2 binary you might try.
                                        Also note that daemon.g only runs once every 10 seconds now, so there's going to be a delay between setting the fan and the servo reacting.
                                        Moot until you get it working again of course.
                                        • MaxGyverundefined
                                          MaxGyver @OwenD
                                          I recon this would make this solution almost useless considering the motion of the servo itself introduces another small delay.
                                          I will submit a Firmware Feature request to add Stepper/RC-Servo Support for M106
                                          -Max
                                            dc42 administrators @jay_s_uk
                                            @jay_s_uk said in Pressured air cooling controlled with servo and ball valve:
                                            @MaxGyver can you not use the L and X commands of M106 to do that?
                                            Lnnn Set the minimum fan speed (0 to 255 or 0.0 to 1.0) when a non-zero fan speed is requested.
                                            Xnnn Set the maximum fan speed (0 to 255 or 0.0 to 1.0) when a non-zero fan speed is requested. (supported in RRF >= 2.02)
                                            Yes that should work.
