    Missing Steps - Cant Print SpreadCycle StealthChop tuning help
    286
    36.3k
      droftarts administrators @fulg
      @fulg @carcamerarig Thanks for the feedback. Can you please post your current config.g and a gcode file that causes the skipping/thumping, so I can replicate this on my test bench, as I'm looking at this today.
      carcamerarigundefined fulgundefined 2 Replies Last reply Reply Quote 0
      • carcamerarigundefined
        carcamerarig @droftarts
        @droftarts
        Shape-Box_0.2mm_PET_MK3S_1h10m.gcode
        Standalone config, sbc config is above.
        G90                                         ; Send absolute coordinates...
        M83                                         ; ...but relative extruder moves
        M550 P"Duet Caribou 420"                        	; Set machine name
        M552 S1                                     	; Enable network
        ;*** Access point is configured manually via M587
        ;M586 P0 S1                                  ; Enable HTTP
        ;M586 P1 S0                                  ; Disable FTP
        ;M586 P2 S0                                  ; Disable Telnet
        M575 P1 S1 B57600							; Panel Due
        ; Drive Mappings
        M569 P0.0 S0 V0                             ; Drive 0: X Axis
        M569 P0.1 S0 V0                             ; Drive 1: Y Axis
        M569 P0.2 S0 V0                             ; Drive 2:  Z Axis
        M569 P0.3 S0 V0                             ; Drive 3: E Axis
        M569 P0.4 S0 V0                             ; Drive 4: E1 used for Z1
        ; Motor remapping for dual Z and axis Limits
        M584 X0 Y1 Z2:4 E3				; two Z motors connected to driver outputs Z and E1
        M671 X-37:287 Y0:0 S4			; leadscrews at left (connected to Z) and right (connected to E1) of X axis
        ; Micrpstepping and Speed
        M350 X32 Y32 E16 Z16 I1                     ; Configure microstepping with interpolation
        M92 X200.00 Y200.00 Z400.00 E830.00         ; Set steps per mm
        ; Speeds, Acceleration and Jerk
        M566 X240.00 Y240.00 Z25.00 E600.00 P1      ; Set maximum instantaneous speed changes (mm/min)
        M203 X7500.00 Y7500.00 Z720.00 E1200.00     ; Set maximum speeds (mm/min)
        M201 X1500.00 Y1500.00 Z1200.00 E4000.00     ; Set accelerations (mm/s^2)
        ; Motor currents
        M906 X700.00 Y700.00 Z700.00 E700.00 I20    ; Set motor currents (mA) and motor idle factor in percent X,Y,Z=1000/1.414 E=1400/1.414
        M84 S30                                     ; Set idle timeout
        ; Printer geometry
        M208 X0:250 Y-4:215 Z-0.5:410               ; Axis Limits
        M564 H0							            ; allow unhomed movement
        ; Endstops for each Axis
        M574 X1 S3								 	; Set endstops controlled by motor load detection
        M574 Y1 S3                               	; Set endstops controlled by motor load detection
        ; Stallgaurd Sensitivy
        M915 X S-2 F0 H200 R0		                ; Set X axis Sensitivity
        M915 Y S-1 F0 H200 R0		                ; Set y axis Sensitivity
        ; Input Shaper
        ;M593 F58.5 P4 S0.2  ; Input Shaping 3.3/3.4
        ;M593 F54.26
        ; Z-Probe Super PINDA
        M574 Z1 S2														; Set endstops controlled by probe
        M558 P5 C"^io3.in" I1 H1 F500 T4800 A30 S0.004
        ; Mesh Grid
        M557 X24:221 Y10:195 P8	                         ; Define mesh grid for probing
        ; Sheets
        ;G31 P1000 X23 Y5 Z1.730 	                    ; Satin Sheet
        G31 P1000 X23 Y5 Z1.91 	  	                  ; Textured Sheet
        ;G31 P1000 X23 Y5 Z1.445 					    ; PEI Sheet
        ;G31 P1000 X23 Y5 Z1.445 					    ; PEI Sheet 0.6 nozzle -10 offset
        ; Heatbed Heaters and Thermistor Bed
        M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.060000e-8       ; Set thermistor + ADC parameters for heater 0 Bed
        M950 H0 C"out0" T0 Q10					                        ; Creates Bed Heater Qnn PWM frequency in Hz. Valid range: 0-65535, default: 500. (optional) 10hz stopped clicking
        M307 H0 R0.273 C345.3 D10.89 S1.00 V23.8						; PID 3.2
        M140 H0										                    ; Bed uses Heater 0
        M143 H0 S120                                                    ; Set temperature limit for heater 0 to 120C Bed
        ; HotEnd Heaters and Thermistor HotEnd
        M308 S1 P"temp1" Y"thermistor" T500000 B4725 C1.19622e-7	       	; define E0 temperature sensor e3d
        M950 H1 C"out1" T1 						                            ; Create HotEnd Heater
        M307 H1 R2.383 C178.5:130.6 D5.32 S1.00 V23.9						; PID
        M143 H1 S285                                                    	; Set temperature limit for heater 1 to 285C HotEnd
        M302 S185 R185
        M950 F1 C"out5" Q250				; Creates HOTEND Fan
        M106 P1 T45 S235 H1                 ; HOTEND Fan Settings
        M950 F0 C"out6" Q100				; Creates PARTS COOLING FAN
        M106 P0 H-1                         ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off PARTS COOLING FAN
        M563 P0 D0 H1 F0                            ; Define tool 0
        G10 P0 X0 Y0 Z0                             ; Set tool 0 axis offsets
        G10 P0 R0 S0                                ; Set initial tool 0 active and standby temperatures to 0C
        ; StealthCop calibration
        M17
        G4 P150
        G1 X1 Y1 Z1
        G4 S2
        M84 ; disable motors
        ; Filament Sensor Logic
        M98 P"0:/macros/02_Functions/StartupFilamentSensorCheck"  ; Runout Sensor Logic: Startup with filament = runout sensor active   Startup without filament = autoload active
        • fulgundefined
          fulg @droftarts
          @droftarts Here is my config.g.
          ; Configuration file for Duet3 Mini5+ with Mini2+ expansion (firmware version 3.2.2 or newer)
          M111 S0                     ; Debugging off
          G21                         ; Work in millimetres
          M669 K1                     ; Select CoreXY mode
          M564 S1 H1                  ; Forbid axis movements when not homed
          M918 P2 R6 C30 E-4 F200000  ; Fysetc 12864 display
          M550 PVoron V2.015          ; Set machine name
          M586 P0 S1                  ; Enable HTTP (for DWC)
          M586 P1 S1                  ; Enable FTP (for remote backups)
          ; --- Z Drive map ---
          ;     _______
          ;    | 1 | 2 |
          ;    | 0 | 3 |
          ;      front
          ; (looking at the printer from the top)
          ; Drive directions
          M569 P0 S1 ; Z0
          M569 P1 S0 ; Z1
          M569 P2 S1 ; Z2
          M569 P3 S0 ; Z3
          M569 P4 S0 ; Extruder
          M569 P5 S1 ; A
          M569 P6 S0 ; B    TODO I wired one of them backwards of course :(
          ; Motor mapping and steps per mm
          M584 X5 Y6 Z0:1:2:3 E4
          M350 X16 Y16 Z16 E16 I1         ; Use 1/16 microstepping with interpolation everywhere
          ;M92 X80 Y80 Z400               ; Set XYZ steps per mm (1.8deg motors)
          M92 X160 Y160 Z800              ; Set XYZ steps per mm (0.9deg motors)
          M92 E406                        ; Set Extruder steps per mm
          ; Drive currents
          M906 X1500 Y1500 Z1200 E600     ; XYZ and E current
          M906 I30                        ; Idle current percentage
          M84 S120                        ; Idle timeout
          ; Accelerations and speed
          M98 P"/macros/print_scripts/speed_printing.g"
          ; Axis travel limits
          M208 X-9 Y0 Z0 S1               ; Set axis minima
          M208 X312 Y325 Z275 S0          ; Set axis maxima
          M574 X2 S1 P"^!io1.in"          ; Xmax endstop on hall effect board
          M574 Y2 S1 P"^!io2.in"          ; Ymax endstop on hall effect board
          M574 Z0 P"nil"                  ; No Z endstop
          ; Z probes
          M558 K0 P8 C"^io6.in" T18000 F120 H5 A5 S0.01 R0.2
          G31 K0 P500 X0 Y25 Z2.0             ; Don't really care about inductive probe Z offset
          M558 K1 P8 C"^io5.in" T18000 F60 H2 A10 S0.005 R0.2
          G31 K1 P500 X0 Y0 Z-0.07            ; Z switch offset (if positive, greater value = lower nozzle. if negative, more negative = higher nozzle)
          ; Bed leveling
          M671 X-65:-65:365:365 Y0:395:395:0 S20      ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right)
          M557 X25:275 Y25:275 S25                    ; Define bed mesh grid (inductive probe, positions include the Y offset!)
          ; Bed heater (dual thermistor setup)
          M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed Heater"  ; configure sensor 0 as thermistor on pin temp0 (heater sensor)
          M308 S2 P"temp1" Y"thermistor" T100000 B3950 A"Bed Plate"   ; configure sensor 2 as thermistor on pin temp1 (mic6 sensor)
          M950 H0 C"out0" T2 Q10                                      ; create bed heater output on out0 and map it to sensor 2 (mic6 sensor). Set PWM frequency to 10Hz
          M140 P0 H0                                                  ; Mark heater H0 as bed heater (for DWC)
          M143 H0 P1 T0 A2 S115 C0                                    ; Regulate (A2) bed heater (H0) to have pad sensor (T0) below 115°C. Use Heater monitor 1 for it
          M143 H0 P2 T0 A1 S125 C0                                    ; Shut off (A1) bed heater (H0) if pad sensor (T0) exceeds 125°C. Use Heater monitor 2 for it
          M143 H0 S110                                                ; Set bed heater max temperature to 110°C, use implict monitor 0 which is implicitly configured for heater fault
          M307 H0 B0 S0.6                                             ; disable bang-bang mode and set PWM to 60% to avoid warping
          ; Hotend heater
          M308 S1 A"Hotend" P"temp2" Y"pt1000"                        ; Hotend is 2-wire PT1000 on pin temp2
          M950 H1 C"out1" T1                                          ; Hotend heater is connected to out1
          M307 H1 B0 S1.00                                            ; disable bang-bang mode for heater and set PWM limit
          M143 H1 S350                                                ; Set temperature limit for heater 1 to 350C
          ; MCU sensors
          ;M308 S3 Y"mcu-temp" A"MCU"
          ;M308 S4 Y"drivers" A"Duet Drivers"
          ;M308 S5 Y"drivers-duex" A"Duex Drivers"
          ; Todo: Chamber temperature sensor via io port (needs RRF3.3b1+)
          ;M308 S10 P"io4.out+io4.in" Y"dht21" A"Chamber Temp[C]"      ; Set DHT21 for chamber temp
          M950 F0 C"out3" Q250                ; Create fan 0 (hotend) on pin out3 and set its frequency
          M106 P0 S1 H1 T50 C"Hotend"         ; Configure fan 0: Thermostatic control is turned on, based on sensor #1
          M950 F1 C"out4" Q250                ; Create fan 1 (cooling) on pin out4 and set its frequency
          M106 P1 S0 H-1 C"Cooling"           ; Configure fan 1: Thermostatic control is turned off
          M950 F2 C"out5" Q30                 ; Create fan 2 (electronics bay) on pin out5 and set its frequency
          ;M106 P2 S0.25 H1 T50 C"Bay"         ; Run the fans at 25% if the hotend is over 50C
          M106 P2 S0 H-1 C"Bay"               ; (temporary manual setup)
          M950 F3 C"out6" Q30                 ; Create fan 3 (chamber) on pin out6 and set its frequency
          M106 P3 S1 H2 T50 C"Chamber"        ; Configure fan 3: Thermostatic control is turned on, based on sensor #2 (mic6 temp)
          ;M106 P3 S0 H-1 C"Chamber"           ; (temporary manual setup)
          ; LEDs
          M950 F4 C"out2"                     ; Create fan 4 (top leds) on pin out2
          M106 P4 S255 B0 H-1 C"Top Lights"
          M563 P0 D0 H1 F1                    ; Define tool 0 using fan 1 for M106
          ; Misc
          ;M572 D0 S0.075                      ; Pressure Advance
          M572 D0 S0.01                       ; Pressure Advance
          M592 D0 A0.015 B0.0012 L0.2         ; Non-linear extrusion
          M376 H10                            ; Fade mesh out compensation over 10mm Z
          ; DAA tuning (you will need to change this for your slicer)
          ;M593 F26.6                          ; Cura 4.5 stock profile @ 40mm/s outer printing speed
          M593 F42.5                          ; PrusaSlicer @ 40mm/s outer perimeter
          M80                                 ; turn on PSU & mains voltage
          ; set default LCD color
          M150 X2 R100 U80 B255 P250 S3
          M501                                ; load config-override.g
          T0                                  ; select tool 0
          I've also attached my complete config + macros and a sample gcode file here: https://www.dropbox.com/sh/wte9u7omvpuif29/AABRm7ewZEVrzH9UWG4pw3mta?dl=0
          VORON V2 CoreXY + Duet3 Mini5+ Ethernet v1.0 with Mini2+ expansion, VORON V0 CoreXY + Duet2 Maestro
            @fulg @carcamerarig Thanks, both! Just finishing off wiring up the 5+ in place of my Duet WiFi board (one of the early white PCB beta boards, it's been on the printer a loooong time!)
              @fulg @carcamerarig I've set up my printer (basically something like a Prusa i3 bedslinger) with settings as close to yours as possible. The basic motor settings are:
              M569 P0.0 S1 V0                                     ; physical drive 0.0 goes forwards
              M569 P0.1 S0 V0                                     ; physical drive 0.1 goes forwards
              M569 P0.2 S1 V0                                     ; physical drive 0.2 goes forwards
              M569 P0.3 S0 V0                                     ; physical drive 0.3 goes forwards
              M569 P0.4 S1 V0                                     ; physical drive 0.3 goes forwards
              M584 X0.0 Y0.1 Z0.2:0.4 E0.3                              ; set drive mapping
              M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
              M92 X80.00 Y80.00 Z800.00 E743.50                  ; set steps per mm
              M566 X100.00 Y100.00 Z12.00 E300.00                ; set maximum instantaneous speed changes (mm/min)
              M203 X18000.00 Y18000.00 Z600.00 E3600.00            ; set maximum speeds (mm/min)
              M201 X2000.00 Y2000.00 Z20.00 E600.00                ; set accelerations (mm/s^2)
              M906 X1000 Y1000 Z800 E450 I30                          ; set motor currents (mA) and motor idle factor in per cent
              I ran a quick test of 100 iterations at full speed (F18000 or 300mm/s) going from X0 Y0 to X200 to Y200 and back. No problems. I then printed (air print, no nozzle or bed heating, no extrusion, but all motors moving) @carcamerarig gcode file, which is a cube and a cylinder. Travel moves are at 80mm/s, where I think you were seeing the problem, but these were okay for me, too.
              One thing I've noticed; both of you have your M566 (max instantaneous speed change/jerk) set very low on X and Y. I usually have mine set at the default from the configuration tool, which I regard as pretty conservative, which is:
              M566 X900.00 Y900.00 Z12.00 E300.00 (ignore Z and E)
              fulg: M566 X100 Y100 Z30 E4000
              carcamerarig: M566 X240.00 Y240.00 Z25.00 E600.00 P1
              The effect of this is that it may slow down on curves. The sinusoidal fill seemed slow on the air print, but otherwise shouldn't particularly matter.
              My only other current observation is that I have a v0.5 Mini 5+. What are your board versions?
              I'll should have a little time over the coming days to run some more tests, to try and get it to skip. Any suggestions welcome!
              carcamerarigundefined fulgundefined 3 Replies Last reply Reply Quote 1
                @droftarts
                Not sure on board version I have a Board ID: Z9NZN-A296U-D65J0-40KM4-LY03Z-ZPQPD can you tell from that? Purchased direct from Roland in Jan 21.
                In my SBC setup I was at M566 X600 Y600 Ill try at 900 now and report back but I fear it will make it worse...
                  @droftarts Can you give me your AirPrint gcode file?
                    droftarts administrators @carcamerarig
                    @carcamerarig said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
                    Sorry, away from machine now. I just commented out the heater commands in the Gcode file, sent M302 P1 to allow cold extrusion, and unloaded filament. It just fits on my 200x200 bed!
                      It’s printed on the back of the PCB.
                      carcamerarigundefined 1 Reply Last reply Reply Quote 0
                      • fulgundefined
                        fulg @droftarts
                        @droftarts My Mini5+ was a v1.0. I say "was" because it is no longer in my hands, I sent it back for warranty exchange for an unrelated problem. I am getting a replacement in a few days.
                        The speeds are quite low in order to try and work around this issue, my usual speeds were 6x higher (M566 X600 Y600 Z60 E8000). I saw it with print speeds of 40mm/s and travel speeds of 100mm/s and those very slow instant speeds. Similarly my motor currents are higher than what I usually run.
                        I see that you are running 1.8° motors (80 steps/mm!), as far as I know everyone affected here is running 0.9° motors.
                        Cheers,
                        Ben.
                          @fulg said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
                          Yes, you’re quite right, I wanted to get a baseline, though @carcamerarig reported the same issue with 1.8 motors. I’ll swap X and Y for 0.9 motors the first chance I have. I don’t have any LDO motors yet, so will have to be Wantai and E3D. Thanks for the info!
                            @droftarts
                            Yep its worse with a higher jerk level but at least you can hear it on the videos now as its been difficult to show/hear with the fans running... It literally shakes everything in and on my cabinet.
                            While setup on SBC mode I found out one or more of the bigger bangs broke my Y motor holder (cracked it), its replaced now with a spare I had but it can't be good for the printer or the bearings...
                            A mild travel bang
                            Infill mini bangs
                            fulgundefined 1 Reply Last reply Reply Quote 0
                              @droftarts I can still send mine to you, I thought as we discussed my issue is not unique to the 0.9's to rule those out?
                              • fulgundefined
                                fulg @carcamerarig
                                @carcamerarig I am hearing the same bang on my machine when printing as your first video, then there is a rather large layer shift, ruining the print in progress.
                                I thought you also had 0.9° motors since that was brought up earlier in the thread (sorry for assuming!). So I won't bother installing my old 1.8° motors, maintenance is never fun but it's worse if you do it for no good reason.
                                I still have my old Duet2+Duex5 boards, those worked great on the same printer!
                                • fulgundefined
                                  fulg @droftarts
                                  @droftarts My motors are from OMC StepperOnline, 17HM19-2004S, running at 24V of course. I have some LDO 0.9° HT steppers on hand now but I have not yet installed them.
                                    @fulg I’m using a 12V PSU, so will need to swap that for 24V. Thanks for reminding me!
                                      carcamerarig @fulg
                                      @fulg Correct I was running the LDO 0.9's when I set up the duet for the 1st time, I changed them to the 0.9's from the 1.8's that shipped with the machine with the promise of higher resolution, ive switched back to the original 1.8's to test if its unique to the motors as other have success with the 1.8's. Mine issue is happening on both 0.9 and 1.8.
                                      • SputnikOC3dundefined
                                        SputnikOC3d
                                        Any type of an update on this issue ? TMC have any input and perhaps narrow down the testing options ?
                                          droftarts administrators @SputnikOC3d
                                          @sputnikoc3d unfortunately, due to Easter holidays and me being a parent, I haven’t made any progress. If you can share your settings that trigger the problem, that would be helpful.
                                          When I get the chance, one of the first things I’m going to look at is using low jerk settings with high acceleration. To my mind, this is a bad combination. @carcamerarig @fulg do you still get bangs if you set X and Y jerk and acceleration to:
                                          M201 X500.00 Y500.00
                                          (This is the default from the configuration tool.)
                                          carcamerarigundefined fulgundefined 4 Replies Last reply Reply Quote 0
                                            @droftarts those videos I just posted were at the default Jerk settings, I darent go any higher in fear of breaking printed parts again.
