Solved Missing Steps - Cant Print SpreadCycle StealthChop tuning help
@droftarts I can still send mine to you, I thought as we discussed my issue is not unique to the 0.9's to rule those out?
@carcamerarig I am hearing the same bang on my machine when printing as your first video, then there is a rather large layer shift, ruining the print in progress.
I thought you also had 0.9° motors since that was brought up earlier in the thread (sorry for assuming!). So I won't bother installing my old 1.8° motors, maintenance is never fun but it's worse if you do it for no good reason.
I still have my old Duet2+Duex5 boards, those worked great on the same printer!
@droftarts My motors are from OMC StepperOnline, 17HM19-2004S, running at 24V of course. I have some LDO 0.9° HT steppers on hand now but I have not yet installed them.
@fulg I’m using a 12V PSU, so will need to swap that for 24V. Thanks for reminding me!
@fulg Correct I was running the LDO 0.9's when I set up the duet for the 1st time, I changed them to the 0.9's from the 1.8's that shipped with the machine with the promise of higher resolution, ive switched back to the original 1.8's to test if its unique to the motors as other have success with the 1.8's. Mine issue is happening on both 0.9 and 1.8.
Any type of an update on this issue ? TMC have any input and perhaps narrow down the testing options ?
@sputnikoc3d unfortunately, due to Easter holidays and me being a parent, I haven’t made any progress. If you can share your settings that trigger the problem, that would be helpful.
When I get the chance, one of the first things I’m going to look at is using low jerk settings with high acceleration. To my mind, this is a bad combination. @carcamerarig @fulg do you still get bangs if you set X and Y jerk and acceleration to:
M566 X900.00 Y900.00 M201 X500.00 Y500.00
(This is the default from the configuration tool.)
@droftarts those videos I just posted were at the default Jerk settings, I darent go any higher in fear of breaking printed parts again.
@droftarts can you get me a 6hc, duet 2 sent out or something I can use in the meantime. It’s turned the printer into a paper weight...
@droftarts I only set low jerk to try and work around this issue. If you are somehow saying that low jerk and high accel could cause this, IMO this means RRF is broken (at least on Mini5+) because while it may not be ideal, this always worked before with previous Duet boards.
One thing that was suggested to me (outside of this forum) is that I am not doing
M17
andG4 P100
before moving motors the first time, reading the docs this seems to say that the required stealthChop/spreadCycle calibration of the TMC2209 will not occur. I would have expected RRF to do this implicitly, but perhaps it does and I am misunderstanding.There are several fixes that have been made recently that specifically target the Duet3 mini, maybe 3.3b3 will help resolve this.
Low jerk and medium to high acceleration is basically the standard setup for cartesian and Core XY printers. Also input shaper do not like high jerk values to function properly. Klipper limits "Jerk" (they use a different name for it) to 5 mm/s when using input shapers. This should not cause any trouble.
StealthChop initialization or calibration.
This is what I put into my config.g (bottom part):; StealthCop calibration
M17
G4 P150
G1 X1 Y1 Z1
G4 S2
M84 ; disable motorsI'm using 1.8 LDO motors with my Mini 5+. No bonging, no issues. Prints 24/7 at the moment.
@carcamerarig has the "bang" issue with both 0.9 LDOs and 1.8 LDOs and @fulg has the bang issues with 0.9 motors but has not tested it with 1.8 LDOs so far.
With 0.9 LDOs I needed more current and could not print as fast but never had any "bang" issues during movement.
Imo the issue with vibrations and noise that TMC2209 + 0.9 motors are having is a different chapter / issue.The question I'm beginning to ask myself: Can a hardware issue on the Mini5+ cause the "bang" issue?
I can reproduce those little hiccups (bangs) by enabling hybrid mode (V parameter) and set the threshold setting at a too high speed (like 100+ mm/s). The switch from StealthChop to SpreadCycle is then causing a "bang" sound which then also often leads to layer shifts.
BUT I checked the config of @carcamerarig (which is basically mine) which does not use hybrid mode (V0) so we can rule that out.So maybe it's a hardware issue / problem with the board itself?
@carcamerarig I had the problem with
M566 X600 Y600 ...
and only reduced it to troubleshoot this issue by reducing instant direction changes, which I thought were causing the problem. I can go ahead and reduce acceleration too. -
@argo I think the point that my machine is only 6 months old, had less than 3 rolls of filament through it and performed perfectly before the upgrade. I only changed x and y motors and the board, nothing else changed and the issue was immediate. With the exception of repacking the misumi X carriage bearings I’ve stripped everything else down checked and rebuilt, repacking the Y bearing blocks and it changed nothing for the better. Then one or more of the large hard bangs broke my Y motor holder which I replaced.
@argo the bang issue is the more pressing concern. It’s enough to cause layer shifts. Even when locked in spreadcycle by specifying mode 2 instead of 3, OP still gets the slight banging on both 0.9, and to a lesser degree 1.8 motors.
@argo said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
... but locked into StealthChop 100% of the time - at reduced travel speed moves and reduced print speeds below what the OP's machine was designed to operate at.
Important to be concise.
The mini 5+ duet and the .9* motors were supposed to be an upgrade in performance [ speed and print resolution ] over the Einsy and 1.8* LDO steppers.
@sputnikoc3d
@sputnikoc3d
I ordered an SKR board yesterday with 2209 steppers to run klipper on, I feel uneasy about all the radio silence if I’m honest... I’m really hoping it gets resolved over the next week or two after which I think I’ll return the mini. -
Not really reduced. I have a cartesian / bed slinger printer. I could do travel moves up to 200 mm/s but I don't because at those bed speeds I add additional cooling and also it's quite noisy. But doable without losing steps. We do btw almost have the same printer. He has Caribou, I have a Bear.
TMC2209 are a huge upgrade compared to TMC2130 (EINSY). Much less VFA and comparing the print results of 1.8 motors to 0.9 motors are (to me) only visible when making photos with a macro lens. You can also increase your steps to 200/mm and interpolate from 32 microstepping which the TMC2130 can't.
The Mini 5+ can handle 0.9 motors up to 120 mm/s but with much more noise during my tests. That issue I also have with Marlin 2. So it's a general problem with TMC2209 in my opinion.
The problem with the "bangs" and missing steps is a different chapter though and should not happen with 1.8 motors nor with 0.9 motors.
Hello @droftarts, one interesting data point we seem to have found, the problem is apparently much much more likely to happen if you use bed mesh compensation. Even @oc_geek who was quoted earlier as not having isssues, enabled a bed mesh and instantly started having the same layer shifts issue.
I looked at the start of the thread and @carcamerarig is also using a bed mesh (as shown in his
M122
dump). So am I.So perhaps that is the key to reproduce this issue. Personally I use a 11x11 mesh to correct a 0.1mm variation in my bed (not a lot but more than enough to ruin prints!)...
