    PT1000 not working. no heatbed in DWC.
    1.3k
    • duttiundefined
      dutti
      Hey
      I have the Problem, that I can´t heat up the heatbed and e0 heater. No temperatur information and heated bed is not in the DWC..
      Can you pleaaase help me?
      KR
      richard```
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Apr 19 2021 01:03:22 GMT+0200 (Mitteleuropäische Sommerzeit)
      M550 P"Z9.Hemera" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M92 X80.00 Y80.00 Z100.00 E408.00 ; set steps per mm
      M566 X4800.00 Y900.00 Z1800.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y6000.00 Z1800.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X1500.00 Y1500.00 Z1500.00 E500.00 ; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1200 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X300 Y300 Z300 S0 ; set axis maxima
      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T600 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X2 Y2 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X10:290 Y10:290 S35 ; define mesh grid
      M308 S0 P"bedtemp" Y"pt1000" ; configure sensor 0 as thermistor on pin bedtemp
      M143 H0 S80 ; set temperature limit for heater 0 to 80C
      M308 S1 P"e0temp" Y"pt1000" ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S250 ; set temperature limit for heater 1 to 250C
      M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
      ![0b6c792b-2e30-405d-9b6e-045508a85154-image.png](/assets/uploads/files/1618861312400-0b6c792b-2e30-405d-9b6e-045508a85154-image-resized.png)
        droftarts administrators @dutti
        @barbarossa-cologne Please send M115 and post response, to show firmware version.
        • duttiundefined
          dutti
          duttiundefined 1 Reply Last reply Reply Quote 0
          • duttiundefined
            dutti @dutti
            @barbarossa-cologne
            @droftarts
            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
              @barbarossa-cologne said in PT1000 not working. no heatbed in DWC.:
              You're using RepRapFirmware 2.03, but your configuration is for RepRapFirmware 3.x. Either update firmware, or generate a new configuration set with the configuration tool, for RRF 2.x.
              • duttiundefined
                dutti @droftarts
                @droftarts
                download Json or configuration bundle?
                thanks
                  @barbarossa-cologne configuration bundle zip, then upload it in DWC. Though it's useful to have the json file to, as you can use that to reload your settings into the configuration tool.
                  To be honest, you're better off updating. At least update to 2.05.1 (the last version of RRF 2.x), which fixes many bugs over 2.03.
                  • duttiundefined
                    dutti @droftarts
                    @droftarts
                    ok. I´ll try to update!
                    I think what I did is very stupid... see picture.
                    duttiundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                    • duttiundefined
                      dutti @dutti
                      @barbarossa-cologne
                      which firmware should I upload to dwc?
                      I guess Duet2 Combined Firmware.bin?
                      Thanks
                        @barbarossa-cologne You can't go directly from 2.03 to 3.2.2. You need to install 3.0 first. See https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_from_RRF_2_x_to_3_x
                        Don't worry about all the other firmware files for the other boards, they will be ignored.
                          If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
                          https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                          https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
                          That will get your firmware and DWC up to date.
                          You can see the change logs here:
                          https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
                          For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
                          https://configtool.reprapfirmware.org/Start
                          Backup your existing config files in the sys folder in case you want to switch back to RRF3. IT’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
                          These documents will come in handy during the conversion.
                          https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
                          https://duet3d.dozuki.com/Wiki/Gcode
                          • duttiundefined
                            dutti @Phaedrux
                            @phaedrux
                            Ok... with firmware 3.0 it was working
                            ... updating to rrf 3.2.2 is now installing since 10min. I hope it won't be a bigger problem
                            Thanks for all information
                            • duttiundefined
                              dutti @dutti
                              @barbarossa-cologne
                              Ok... can't open dwc anymore. Do I have to make the yat procedure again, now?
                              Thanks
                              Richard
                                What URL are you trying to use to reach DWC?
                                How did you try applying the firmware? Upload the zip file from DWC?
                                • duttiundefined
                                  dutti
                                  @phaedrux @phaedrux
                                  http://192.168.2.111/ and http://duettest.local/ --> like bevor
                                  yes... upload to dwc. Just failed with version 3.2.2. installing.... nothing happened.
                                  3.0 was fine
                                  Is there a possibility to reset the board to start from beginning?
                                  thanks
                                    Phaedrux Moderator @dutti
                                    @barbarossa-cologne connect via Yat and usb and send m115 to see what firmware is applied.
                                    Also from Yat you can send m997 to initiate the update.
                                    It's possible it's just the WiFi firmware failed to apply successfully. So also send m997 S1. And then m552 S1 and see if it connected to wifi then.
                                    • duttiundefined
                                      dutti @Phaedrux
                                      M115
                                      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.2.2 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-02-11
                                      • duttiundefined
                                        dutti
                                        M997
                                        Error: M997: Firmware binary "Duet2CombinedFirmware.bin" not found
                                        • duttiundefined
                                          dutti
                                          M997 S1
                                          Error: M997: File DuetWiFiServer.bin not found
                                          • duttiundefined
                                            dutti
                                            M551 S1
                                            ok
                                            Nothing more....
                                            blue wifi led is off.
