checksum foutregel 44/57
PanelDue
393
    Kevin
    hello
    i have sins a few days that my panel due i7 keeps saying conncting and dont find the sd card.
    (does work via webcontrol)
    all cables are checked and tightened
    after a few times off / on it does it again
    when I press home all it indicates
    checksum error line 44
    checkum error line 57
    firmware version1.23.2
    Firmwareversion dwc2.05.1
    what could this be?
    undefined 1 Reply Last reply 20 Apr 2021, 20:54 Reply Quote 0
      it sounds like a cabling error. Either the cable itself is failing, or it's being routed near other wires which are acting as a source of interference.
      Are you sure nothing has changed in the configuration? What Baud rate is the PanelDue set to use on the Setup page?
      undefined 1 Reply Last reply 20 Apr 2021, 19:51 Reply Quote 0
        Kevin @Phaedrux
        @phaedrux said in checksum foutregel 44/57:
        nothing has changed in the meantime since the screen is mounted Baud rate 57600 on panel due
          Phaedrux Moderator @Kevin
          @kevin said in checksum foutregel 44/57:
          Can you upload your homeall.g?
          Do you get errors on any other homing files or macros? Perhaps the problem is a corrupted file.
          undefined 1 Reply Last reply 21 Apr 2021, 14:53 Reply Quote 0
            Kevin @Phaedrux
            @phaedrux said in [checksum foutregel 44/57]
            homeall.g
            if the screen is connected, everything works as it should
            when it indicates connecting no sd or temperatures to see and cannot go to home x, y, z or all
              At this point I think it would be prudent to replacing the cabling.
              undefined 1 Reply Last reply 21 Apr 2021, 19:06 Reply Quote 0
                Kevin @Phaedrux
                thanks for your comments i am going to order new cables.
                I currently use stepper motor cable 0.33 mm² + -1.2 meter to board
                undefined 1 Reply Last reply 7 May 2021, 16:39 Reply Quote 0
                  Kevin @Kevin
                  I've watched it for a few weeks and haven't had any more mistakes.
                  replaced the cables and laid them along a different route
                    Good to hear you've solved it.
