    checksum foutregel 44/57
    PanelDue
    391
    • Kevinundefined
      Kevin
      hello
      i have sins a few days that my panel due i7 keeps saying conncting and dont find the sd card.
      (does work via webcontrol)
      all cables are checked and tightened
      after a few times off / on it does it again
      when I press home all it indicates
      checksum error line 44
      checkum error line 57
      firmware version1.23.2
      Firmwareversion dwc2.05.1
      what could this be?
        it sounds like a cabling error. Either the cable itself is failing, or it's being routed near other wires which are acting as a source of interference.
        Are you sure nothing has changed in the configuration? What Baud rate is the PanelDue set to use on the Setup page?
        Kevinundefined 1 Reply Last reply Reply Quote 0
        • Kevinundefined
          Kevin @Phaedrux
          @phaedrux said in checksum foutregel 44/57:
          nothing has changed in the meantime since the screen is mounted Baud rate 57600 on panel due
            Phaedrux Moderator @Kevin
            @kevin said in checksum foutregel 44/57:
            Can you upload your homeall.g?
            Do you get errors on any other homing files or macros? Perhaps the problem is a corrupted file.
            • Kevinundefined
              Kevin @Phaedrux
              @phaedrux said in [checksum foutregel 44/57]
              homeall.g
              if the screen is connected, everything works as it should
              when it indicates connecting no sd or temperatures to see and cannot go to home x, y, z or all
                At this point I think it would be prudent to replacing the cabling.
                • Kevinundefined
                  Kevin @Phaedrux
                  thanks for your comments i am going to order new cables.
                  I currently use stepper motor cable 0.33 mm² + -1.2 meter to board
                  • Kevinundefined
                    Kevin @Kevin
                    I've watched it for a few weeks and haven't had any more mistakes.
                    replaced the cables and laid them along a different route
                      Good to hear you've solved it.
