    A Software Solution to Eliminate Ringing?
    71
    9.8k
    • DigitalVisionundefined
      DigitalVision @DigitalVision
      This post is deleted!
        DigitalVision @bot
        @bot a CoreXY has a more complex model, but it seems to be enough to measure 3 points per axis instead of 2. I haven't yet started to work on a position dependence model for a delta yet – and I still need to get some time to implement and test the CoreXY one. The delta geometry is more symmetric, so it may be easier to calibrate – unless the wire bundle ends up messing up things. I did get great results in the center of bed though, and I haven't yet tested how they vary with position.
          DigitalVision
          Another approach that should be very straightforward for calibrating the ringing dynamic would be to attach a cheap MEMS accelerometer to the print head and log samples at different locations. Accelerometers with up to 8kHz sampling rates are less than $1 each in volume. Determining the ringing frequency should be trivial and very accurate.
          A more crazy idea: You could easily build a closed loop system with an IMU. The filter lag in an accelerometer can be as low as 1 ms, and with say 1kHz sampling we’d be well within reasonable latencies. So you could simply measure the x,y,z acceleration in real-time and compare to the desired acceleration - and apply a motion compensation signal (using the spring model) to correct for any deviation.
          • oliofundefined
            oliof
            @DigitalVision klipper's input shaper implementation uses an ADXL accelerometer to measure vibrations and and configure the input shaper.
              dc42 administrators @bot
              @bot said in A Software Solution to Eliminate Ringing?:
              @dc42 In my experience, it's easy to avoid the low-frequency ringing by choosing sensible acceleration/jerk/speed settings. It's the high-frequency ringing that is nearly impossible to be rid of. No matter how low of a jerk and accel/speed value I use, there is always a tiny amount of HF ringing.
              That's exactly opposite to my experience. I find low frequency ringing to be a problem at any sensible acceleration. I would need to use really low acceleration to avoid it, which would slow the prints down too much.
              • botundefined
                bot @dc42
                @dc42 said in A Software Solution to Eliminate Ringing?:
                Interesting. I have a somewhat different setup than most: there is a lot of mass to be moved by most of my axes. What printer are you thinking of when you say you experience the opposite? All printers you've used? Do they all tend to be lightweight?
                It's entirely possible that the low-frequency ringing on my printer is of such low-frequency that it is hard to see it. As mass increases in a system, the resonant frequency decreases, right?
                Edit: When I think about it, the low-frequency ringing I experience shows up at high print speeds, maybe regardless of how low I have the acceleration. How fast are you printing, normally, dc42? I've settled on quite low perimeter print speeds, so I don't see or notice any ringing in my prints.
                *not actually a robot
                • Egon.Netundefined
                  Egon.Net
                  Just registered to say thanks for your work @DigitalVision, it's like magic!
                  My custom CoreXY-Toolchanger has quite a heavy gantry and would benefit a lot from something like that, because if I want to print ringingless, I have to slow down quite a lot.
                  If you want me to test something in particular, just drop me a line.
                  • CCS86undefined
                    CCS86
                    Any updates on this?
                      dc42 administrators @CCS86
                      See the threads on accelerometers and input shaping.
                      CCS86undefined 1 Reply Last reply Reply Quote 1
                      • CCS86undefined
                        CCS86 @dc42
                        I just went ahead and ordered the recommended Adafruit accelerometer. Any time estimate on a first pass at input shaping?
                          @ccs86 said in A Software Solution to Eliminate Ringing?:
                          I have some preliminary results, see https://forum.duet3d.com/topic/22296/input-shapers-2hump_ei-3hump_ei-auto-tuning/17?_=1619123752409.
