    A Software Solution to Eliminate Ringing?
    71
    9.8k
    • DigitalVisionundefined
      DigitalVision @bot
      @bot thanks for running this test. I must say it's hard to spot the ringing in the pictures. One thing I found useful was to limit the y axis acceleration to a very low value, say 500 while increasing x axis acceleration to a high value to avoid the cross talk. (Also make sure you've adjusted both M204 and M201).
      It seems like a good strategy for the time being (for avoiding the effects of this variation) is to simply select an acceleration value that is low enough to not exhibit ringing to any discernible amount: this way, the variation is basically irrelevant.
      The ringing magnitude is proportional to the acceleration so while you can mitigate it with lower acceleration settings it has the potential to affect the print time significantly, especially on print geometries with shorter path lengths. An illustration of print speed vs acceleration for different segment lengths.
      Do you think s-curve acceleration alone, before any cancellation of frequencies, would provide speed benefits in this regard?
      In addition to what dc42 said – the photo at the very top of this topic shows an s-curve vs linear acceleration ramp profile without any appreciable difference in ringing.
      • botundefined
        bot
        So it's safe to say we can rule out S-curve as beneficial? Or it is only beneficial with your modelling implementation?
        I definitely understand the print time implications of acceleration, and will support any and all theories which can improve print time while maintaining or improving quality.
        I have highlighted the photo to better show what I think are signs of ringing. By my eye it's easier to see and tell that they are at least different, which supports your theory.
        *not actually a robot
        DigitalVisionundefined 1 Reply Last reply Reply Quote 1
          DigitalVision @bot
          @bot said in A Software Solution to Eliminate Ringing?:
          I think, dc42, you've been right all along that the instantaneous speed change "problem" is the one to focus on first. The last bit of HF ringing I get seems related to jerk more than acceleration, and finding a low enough "jerk" speed for sharp corners while maintaining curve speed/quality is kind of impossible.
          I personally don't think the implementation of "jerk"/instantaneous speed change as implemented in all current firmwares is very good. The purpose of jerk is to allow continuous speed through linearly segmented curves, but as a consequence you get abrupt changes (and ringing) for sharp corners too. A quick thing I don't know has been tested and I would expect to be a better heuristic would be to add a corner angle threshold and disable jerk for any corner beyond a certain angle. This is quite often used in 3D graphics as a heuristic to for when to smooth vs flat shade a 3d mesh and seems to work fairly well. You may want to mix in segment length as well in a heuristic, but in either case it shouldn't be hard to prevent "jerk" from applying to a 90° corner between two long segments.
            DigitalVision @bot
            I'd be surprised if s-curves by themselves allow you to increase the print speed, but they will eliminate the HF transients at the ends of ramps. The trade-off is that they lead to higher peak accelerations if you want to preserve the same print time, and that means that you load the "spring" more. But s-curves allows the spring compensation model to work without requiring instantaneous position changes. And I've found this allows for substantially higher accelerations.
            Thanks, those lines help! Could you give a rough estimate of the short and long belt length for the two print locations?
            • botundefined
              bot @DigitalVision
              @DigitalVision Sure the belt lengths are like this:
              It's a 50 mm edge length on that print
              X axis "best case"
              Short length: 166 mm to 216 mm
              Long length: 970 mm to 920 mm
              X axis "worst case"
              Short length: 366 mm to 416 mm
              Long length: 770 mm to 720 mm
              Y axis numbers are similar.
              DigitalVisionundefined 1 Reply Last reply Reply Quote 0
                DigitalVision @bot
                X axis "worst case"
                Cool. Your "best" case should have up to 75 % higher spring constant than the worst side (very dependent on which side of the print was at the most extreme point). If your belts dominate ringing, this should translate into ~32% higher ringing frequency, so the good side ringing period should be as little as ~3/4 of the worse side (with the stepper motor and other serial springs the difference will be slightly smaller though). That seems possible from your photo.
                I don't know what that secondary ringing at around 2/3s of the print is though. That far too early to be at the deceleration ramp but also too late to be a late residual from the earlier corner.
                • botundefined
                  bot @DigitalVision
                  @DigitalVision I think it's best not to look to deeply into my tests. I didn't isolate the Y axis as you mentioned, and my Y axis is insanely stupid to begin with (there is a longer "short side" on the primary drive than at any point of the secondary drive belt. I don't know what I was thinking at the time). I have plans to change it to be "the same" as the X axis, just with more weight to move around. Then I will perform more tests.
                  All I wanted to do was confirm or deny the idea that the ringing was variable (in frequency) depending on where it was printed. I feel like I confirmed that and your theories all seem to line up.
                  So, given all that, would using your method be as simple as determining the different frequencies at different parts of the axes, and cancelling as required based on position?
                    DigitalVision @bot
                    Yes, in theory at least. For a cartesian all you would need is to determine the frequencies at two different positions per axis and provide the positive and negative belt lengths at a known location. One could probably create a nice script to automatically generate the right structures to print at the known locations. I found it most easy and consistent to spot the acceleration ringing (where the extrusion width oscillates), and especially when printing in a semi-translucent material. Here's a photo on silver filament which is very hard to capture on photo showing the phase inversion in the ringing pattern as the f_n parameter was varied across the print z. If you get it right, there is a rather sharp region without ringing that's fairly easy to spot and measure:
                    botundefined DigitalVisionundefined 2 Replies Last reply Reply Quote 0
                    • botundefined
                      bot @DigitalVision
                      @DigitalVision The results are truly fantastic.
                      Do you think it would be easier or harder to determine the "positional frequency" on a corexy machine? A delta?
                        DigitalVision @DigitalVision
                        This post is deleted!
                          DigitalVision @bot
                          @bot a CoreXY has a more complex model, but it seems to be enough to measure 3 points per axis instead of 2. I haven't yet started to work on a position dependence model for a delta yet – and I still need to get some time to implement and test the CoreXY one. The delta geometry is more symmetric, so it may be easier to calibrate – unless the wire bundle ends up messing up things. I did get great results in the center of bed though, and I haven't yet tested how they vary with position.
                            DigitalVision
                            Another approach that should be very straightforward for calibrating the ringing dynamic would be to attach a cheap MEMS accelerometer to the print head and log samples at different locations. Accelerometers with up to 8kHz sampling rates are less than $1 each in volume. Determining the ringing frequency should be trivial and very accurate.
                            A more crazy idea: You could easily build a closed loop system with an IMU. The filter lag in an accelerometer can be as low as 1 ms, and with say 1kHz sampling we’d be well within reasonable latencies. So you could simply measure the x,y,z acceleration in real-time and compare to the desired acceleration - and apply a motion compensation signal (using the spring model) to correct for any deviation.
                            • oliofundefined
                              oliof
                              @DigitalVision klipper's input shaper implementation uses an ADXL accelerometer to measure vibrations and and configure the input shaper.
                                dc42 administrators @bot
                                @dc42 In my experience, it's easy to avoid the low-frequency ringing by choosing sensible acceleration/jerk/speed settings. It's the high-frequency ringing that is nearly impossible to be rid of. No matter how low of a jerk and accel/speed value I use, there is always a tiny amount of HF ringing.
                                That's exactly opposite to my experience. I find low frequency ringing to be a problem at any sensible acceleration. I would need to use really low acceleration to avoid it, which would slow the prints down too much.
                                • botundefined
                                  bot @dc42
                                  @dc42 said in A Software Solution to Eliminate Ringing?:
                                  Interesting. I have a somewhat different setup than most: there is a lot of mass to be moved by most of my axes. What printer are you thinking of when you say you experience the opposite? All printers you've used? Do they all tend to be lightweight?
                                  It's entirely possible that the low-frequency ringing on my printer is of such low-frequency that it is hard to see it. As mass increases in a system, the resonant frequency decreases, right?
                                  Edit: When I think about it, the low-frequency ringing I experience shows up at high print speeds, maybe regardless of how low I have the acceleration. How fast are you printing, normally, dc42? I've settled on quite low perimeter print speeds, so I don't see or notice any ringing in my prints.
                                  • Egon.Netundefined
                                    Egon.Net
                                    Just registered to say thanks for your work @DigitalVision, it's like magic!
                                    My custom CoreXY-Toolchanger has quite a heavy gantry and would benefit a lot from something like that, because if I want to print ringingless, I have to slow down quite a lot.
                                    If you want me to test something in particular, just drop me a line.
                                    • CCS86undefined
                                      CCS86
                                      Any updates on this?
                                        dc42 administrators @CCS86
                                        See the threads on accelerometers and input shaping.
                                        CCS86undefined 1 Reply Last reply Reply Quote 1
                                        • CCS86undefined
                                          CCS86 @dc42
                                          I just went ahead and ordered the recommended Adafruit accelerometer. Any time estimate on a first pass at input shaping?
                                            @ccs86 said in A Software Solution to Eliminate Ringing?:
                                            I have some preliminary results, see https://forum.duet3d.com/topic/22296/input-shapers-2hump_ei-3hump_ei-auto-tuning/17?_=1619123752409.
