    Low cost, public domain, stepper analyzer - season 2.
    49
    3.2k
    • tenajaundefined
      tenaja @PCR
      @PCR I will take one! (If you can ship to USA.)
      • zaptaundefined
        zapta @arhi
        @arhi said in Low cost, public domain, stepper analyzer - season 2.:
        @zapta that's QFN I need soic and taht's 2.5A I need 5A ..
        SOIC is definitely easier to solder and I would love to find one.
        I modified the QFN footprints on the board be easier to hand solder, having longer pads, somewhat similar to the Schmartboard boards.
          In SOIC parts, ACS724LLCTR-05AB-T is very good, much better than ACS712 in our experience. We use them in our latest automated test equipment.
          • arhiundefined
            arhi @dc42
            @dc42 said in Low cost, public domain, stepper analyzer - season 2.:
            Thanks, I'll try to find them, I started using JLCPCB full service recently so I try to go with parts they have (and acs712 they do have on offer). will see what else is there but if I can get easily acs724 (issue with digikey is that shipping is rather expensive so I wait till I have a need for more parts to order something to spread the shipping cost on to more parts 😄 as I pay same for 1 and for 1000 parts, same small box) locally I don't mind soldering them myself ... those QFN I really hate 😞 and if JLC had them it would be no problem as they would solder them on but ... they don't
              droftarts administrators
              @zapta's stepper motor analyzer is the star of this Teaching Tech video! https://youtu.be/4iII25DGIdA
              zaptaundefined 1 Reply Last reply Reply Quote 1
              • zaptaundefined
                zapta @droftarts
                @droftarts, he did a very good job IMO, precise and informative.
                There are two analyzers shown in that video, one with the standard base and another with the enclosed case design. Functionality wise they are identical and the open frame design is easier to build and therefore the default option.
                The enclosed case is documented in the link below but is more complex to build so I am not sure it worth it.
                https://github.com/zapta/simple_stepper_motor_analyzer/blob/master/case_option.md
                And the Onshape design is at https://cad.onshape.com/documents/146b8b994145177887407b23/v/c2dc7870c6f0bf989cd611b5/e/b6453eca2ba530476c30538a
                BTW, how does your analyzer progress? Any problems?
                droftartsundefined 2 Replies Last reply Reply Quote 1
                  droftarts administrators @zapta
                  @zapta I sent it to Tony, who has the equipment and time to put it together! However, we’re waiting for screens to come from China. I think we’re going to use the 411 Blackpill, as the 401 seems unavailable.
                  • StepperAnalyzerundefined
                    StepperAnalyzer @fma
                    @fma Hello, Sorry to be so late getting on the bandwagon with this, but I would definitely buy the PCB and SMT components, even ALL the parts if possible. I live in Switzerland. Please let me know what you need from me to do this. Thanks so much!
                      @zapta And now on Hackaday: https://hackaday.com/2021/04/23/stepper-motor-analyzer-reveals-all/
                        droftarts administrators @StepperAnalyzer
                        @stepperanalyzer I don't think anyone is producing a kit at the moment. It's an open source project, so you can send the files to a PCB manufacturer and get them to populate the board for you. You'll probably have to find the Blackpill (the 401 version seems to be out of stock everywhere, but the 411 version is available) and the display yourself.
                        GeorgeMundefined 1 Reply Last reply Reply Quote 0
                        • GeorgeMundefined
                          GeorgeM @droftarts
                          Is @PCR still creating pcb's? I would like to get one if so.
                          PCRundefined 1 Reply Last reply Reply Quote 0
                          • zaptaundefined
                            zapta @droftarts
                            @droftarts said in Low cost, public domain, stepper analyzer - season 2.:
                            Teaching Tech video was a great help.
                            Now let's see some entrepreneur makes it available to the community, as is or a variant. Could be a great kickstarter campaign.
                            • PCRundefined
                              PCR @GeorgeM
                              @georgem Still have them
                              • zaptaundefined
                                zapta @PCR
                                Apparently the current version of the PCB leaves one of the TFT inputs (RD, pin 26) floating. If you encounter any problem, you may want to attach a pullup resistor as explained in the updated schema. https://github.com/zapta/simple_stepper_motor_analyzer/blob/master/kicad/stepper_analyzer-sch.pdf
                                BTW, I am working on a Raspberry Pico version. It will have a single board design similar to the Dustin Watts ESP32 Touchdown. With the shipping times from China, it will probably take a few months to be ready.
                                If everything will go as planned, it will have the exact same functionality but will be easier to solder (SOIC-8 current sensors), lower profile, larger mounting screw clearance, easier firmware update process, no external EEPROM IC needed, a more stable source for microcontroller modules, lower cost TFT module, and hopefully smoother display updates due to the larger RAM that fits an entire screen). However, it will have a micro USB connector instead of the existing Type C.
                                • woodscooterundefined
                                  woodscooter
                                  If it's any help, I have a small batch of PCBs for the original Simple Stepper Motor Analyzer, not the new board using the Raspberry Pi Pico.
                                  They are on Tindie: Electro-General Stores, and I'm selling at a no-profit price because this is a great project. Thanks, @zapta!
                                  • zaptaundefined
                                    zapta @woodscooter
                                    Thanks @woodscooter, that was my hope, that somebody will make them available to the community. What is your store's URL? (I hope it's OK with the moderators).
                                    • CCS86undefined
                                      CCS86
                                      Definitely interested in the new version.
                                        droftarts administrators @CCS86
                                        @ccs86 here’s a thread about the Pico version: https://forum.duet3d.com/topic/23461/anybody-wants-a-stepper-motor-analyzer?_=1623217766458
