Duet3D PCB delta printer effector sneak preview
Smart effector for delta printers
53
367
78.1k
    DjDemonD
    Or the flex3drive (in the interests of fairness). Which does the same thing.
    Both of these options are IMO much better for a delta than a direct extruder, even a titan with 20mm motor (which works really well) is around 230g which is a lot to add to your effector. These are much better than using bowden tubes albeit a well tuned bowden with pressure advance and as short a tube as possible (flying extruder setup for example) can be quite successful.
    I have an aluminium effector currently with flex3drive and e3d v6, and its total mass is 250g, it would be twice the mass with a direct titan, even with a minimal motor. I am looking forward to trying the PCB effector, which should be even lighter. If you truly never want to print at speed then the added mass is not really a problem, but then why opt for a delta unless you want to maximise one of its key attributes - lightweight printhead, enabling accuracy at speed?
    There is another option and that is a lightweight adaptor which is the shape/size of a nema 17 but is driven by a drive cable, so you can reduce the mass of your titan extruder's motor to a lot less than it currently weighs. This enables you to mount a titan on an effector with less mass than with a motor attached but you would need to come up with a mounting option to attach it to the pcb effector.
    www.precisionpiezo.co.uk
      Bear in mind that to use the Nimble with the production effector, you will need a different adaptor compared to the prototype that Doug used. The new heatsink doesn't come with the threaded collar that the old one did, instead there is a shorter threaded section and a M12 fine pitch half nut and washer. OTOH the effector now has 3 additional 2.9mm holes at 120 degree intervals on a 17mm radius.
        Alexander Mundy
        I am assuming that the kit will be available at Filastruder here in the US?
        If so, will there be a large lag in availability?
          Dougal1957
          The PCB Effector with Nimble and mounting adaptor plus custom E3D V6 comes in at 159 grammes.
          Don't know how the Flex would fit TBH the mounting for the custom heatsink is 3x M3 holes on a 18mm PCD which would be tight.
          Right time to go put it back on the printer
          Doug
            Dougal1957
            Ah David I thought that the only change was in the thread didn't realise that the Collar was no longer included. That may mess things up a bit?
            Doug
              Zesty_Lykle
              @dc42:
              Ah, OK, no problem. New adapter up and coming!
              David, do yo know the height of the top surface to the PCB?
              Lykle
              Lykle
              Design, make and enjoy life
              Co Creator of the Zesty Nimble
                @Zesty_Lykle:
                @dc42:
                Lykle
                Not including the collet, it's close to 7.5mm.
                EDIT: I just checked the heatsink drawing and it's 8mm from the PCB centering step to the top. Allowing for the 1.6mm PCB thickness, that should leave 7.4mm from the top of the PCB. The top of the half nut is approximately flush with the top of the heatsink.
                  Zesty_Lykle
                  OK, that will work.
                  Then I can clamp the adapter on top of that and lock the PTFE tube in, without need for the collet.
                  Lykle
                    loic
                    @Dougal1957:
                    http://i1014.photobucket.com/albums/af270/dougal1957/DSC_0117_zps5zgaq1gs.jpg
                    Doug
                    where is the fan for the print piece?
                    we need one to have good quality print.
                    i agree the nimble is top notch but if i need to buy everything i will have for 280e only for the head..110euro for arm+rod kit+ 60euro for pcb+100 with shpping cost for nimble..it s a lot expansive
                    it s almost the price for my anycubic i3 mega only for parts..
                      Dougal1957
                      I hav'nt included the part fan as I use the Berdair system
                        DjDemonD
                        That's a nice feature being able to disconnect it easily, due to the magnets and the electrical couplings used. Is there one connector for the whole effector, or multiple connectors?
                          Zesty_Lykle
                          OK, new adapter is available.
                          This adapter is mounted onto the PCB using 6.6 mm tall standoffs. The PCB has 3 holes of 2.9 mm diameter and the adapter has space for 3 M2.5 bolts that go through the standoffs.
                          The bottom of the adapter sits on top of the hot end and has a 4mm opening that is 5 mm deep. This hole is for the PTFE tube. It locks the tube into the hot end, so that there is no need for the collet.
                          edit: corrected the standoff length.
                          https://www.thingiverse.com/thing:2453322
                          Lykle
                            jannisj
                            @dc42:
                            Damn, I ordered the adapter from shapeways last weekend..
                            Hopefully they are able to cancel the order
                            -Jannis
                              jannisj
                              @Zesty_Lykle:
                              This adapter is mounted onto the PCB using 7.4 mm tall standoffs. The PCB has 3 holes of 2.9 mm diameter and the adapter has space for 3 M2.5 bolts that go through the standoffs.
                              Will this be available from shapeways too?
                              I ordered the Nimble today (and already got the tracking number)
                              -Jannis
                                Dougal1957
                                DJ there are 2 connectors on it a 8 way single row for thesensors etc and a 3x2 for heater fan and thermistors/temp sensor it took me about 3 minutes to take it of the machine for the photo
                                  olee
                                  Hello. It's my first message in this forum but I has been reading it for a few month. Sorry for my english it's not my native language. I'm going to build my first delta 3D printer based on David's Kossel XL. I've got almost all main mechanical parts: extrusions, buildplate, heater, stepper motors etc. Now I'm waiting for the PCB effector to order it with electronics (Duet an so on). On the way to me is the Nimble extruder which I want to pair with the effector. Reading this thread I got sure that the adaptor from shapeways allow me to do that (obviously can't print it myself). But now I see that I need a new version of the adaptor. So it is a question. Can I order this new adaptor from shapeways right now or should I wait some time before this version will be available there? Thanks in advance.
                                  Oleg
                                    Dougal1957
                                    Yes
                                    https://www.shapeways.com/product/62MB3QZJ7/nimble-mount-base-for-smart-effector?optionId=62810434
                                      olee
                                      @Dougal1957:
                                      Yes
                                      That is a new one is the same as the old adaptor except it needs to use 7.4mm stands that I should make by myself?
                                        Dougal1957
                                        it is quite a bit different to the old one although it may look the same and the stand offs can be purchased tho wether you will get 7.4 mm ones I am not sure but 10 would do you would just have to extend the PTFE Tube a bit further I think check ebay for standoffs.
                                        Found some 8mm long ones here http://www.ebay.co.uk/itm/M3-M4-M5-M6-M8-Nylon-plastic-spacers-standoff-washers/282477022050?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D2%26asc%3D20140122125356%26meid%3D757a377c307d47cf806cde39a5736fa8%26pid%3D100005%26rk%3D4%26rkt%3D6%26sd%3D272505748740 you will also need some m2.5 screws and nuts probably around 20mm long screws should do I think
                                          olee
                                          @Dougal1957:
                                          Thank you! It is just not obvious that the link points to a new version of adaptor as it looks much the same as the old one that I was ready to order before read las posts in this thread. So I will order this right now and if I got it right I can use standard bronze or plastic standoffs that used for PCB mounting. Thanks one more!
                                          Oleg
                                          231 out of 367
