    Software package 3.3beta3 released
    Beta Firmware
    34
    96
    11.0k
    • Sytac072undefined
      Sytac072
      Hello... I have tried to upgrade my Tevo delta today from RRF 3.2.2 to 3.3 beta 3 but after the upgrade, the extruder disappeared from the DWC and from the paneldue.
      This is how the motors are configured:
      I don't what is wrong.
      Stephen6309undefined 1 Reply Last reply Reply Quote 0
      • Stephen6309undefined
        Stephen6309 @Sytac072
        @sytac072 I have a 1LC with my 6HC & Mini 5+, mine is M584 X0.0 Y0.1 Z0.2 E121.0
        If you have a Duet 3, try adding 0. to the drive numbers. That's what the reprapfirmware configurator does.
        Sytac072undefined 1 Reply Last reply Reply Quote 0
        • Sytac072undefined
          Sytac072 @Stephen6309
          @stephen6309 Thank you very much for your tip. I have a duet2 Wifi. I am not sure if your settings may also work on mine.
            @sytac072 Have you tried the good ol' turnoff/turnon fix? ๐Ÿ™‚
            The config.g is still valid?
            • Sytac072undefined
              @stephen6309 Yes, I did it... The config.g is the same I was using with RRF 3.2.2. I reinstalled it and the printer was working again.
              SIamundefined 1 Reply Last reply Reply Quote 0
              • SIamundefined
                SIam @Sytac072
                @dc42 I had the same issue with "long" cable to the Accelerometer long means in my case 1.5 meters with this cable the Accelerometer doesn't work ๐Ÿ˜ž
                25.4.2021, 14:00:31	M955 P0 C"spi.cs3+spi.cs4"
                Error: M955: Accelerometer not found on specified port
                I have measured the cable with all the crimps and this is ok. After that I have build a second cable with ca 40 cm and connected this to the Accelerometer and the duet board and surprise the Accelerometer works!
                25.4.2021, 16:37:37	M955 P0 C"spi.cs3+spi.cs4"
                Accelerometer 0 with orientation 20 samples at 1344Hz with 10-bit resolution
                But i can't use it because the cable is to short to move the print head. Now my question can we do something with pull up, pull down or a capacitor to use "Long" cables?
                Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                Duet WiFi 1.02 or later + DueX5
                RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                Duet WiFi Server: 1.26
                Duet Web Control 3.4.0beta4 (2021-09-27)
                pkosundefined 1 Reply Last reply Reply Quote 0
                • Nurgelrotundefined
                  Nurgelrot
                  Okay I'm lost. In SBC Mode. I've switched my SBC software repository to unstable and atp-get update|grade.
                  DWC is listing Duet Web Control 3.3.0-b3 and
                  Machine is showing :
                  Board: Duet 3 Mini 5+ (Mini5plus)
                  DSF Version: 3.3-b3
                  Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.2.2 (2021-02-11)
                  M115:
                  FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.2.2 ELECTRONICS: Duet 3 Mini5plus Ethernet FIRMWARE_DATE: 2021-02-11
                  So everything but the board is upgraded what did I miss?
                  the right package is installed on the PI:
                  ii reprapfirmware 3.3-b3-1 all RepRapFirmware Software Bundle
                  Rebooting nothing working.
                    Phaedrux Moderator @Nurgelrot
                    @nurgelrot Try updating the mini5 firmware directly to get back in sync with DSF.
                    https://duet3d.dozuki.com/Wiki/Duet_3_Mini_5plus_Firmware
                    Nurgelrotundefined 1 Reply Last reply Reply Quote 0
                    • pkosundefined
                      pkos @SIam
                      @siam I know it sounds janky, but wrap your wire in aluminum foil or any other kind of shielding. Should work then.
                      Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron Trident (Duet 3 mini 5+ standalone), Voron 0.1
                      SIamundefined 2 Replies Last reply Reply Quote 0
                      • SIamundefined
                        SIam @pkos
                        @pkos that will not work so easy the cable is inside a Energy chain, but I think I have some shielded cable here if so i will try a test with it
                          Nurgelrot @Phaedrux
                          @phaedrux Well that was a major PITA but they are now in sync again. Had to tear my lab apart and move crap all over the place. If I had wanted to make direct connections to the printer board I would have used the Wifi version of the card. But I got there in the end. Any thoughts on why this happened? Not looking forward to that next time I update.
                            droftarts administrators @Nurgelrot
                            @nurgelrot I think by โ€˜directlyโ€™ @Phaedrux didnโ€™t mean by USB; you should have been able to send M997 S0 (the matching firmware should have downloaded with DSF), or uploaded the firmware file in DWC, and it would ask if you want to update it. Iโ€™ve done this a lot recently, when testing firmware.
                              Nurgelrot @droftarts
                              @droftarts Well sadly I'm not a walking encyclopedia of gcode... But I'll file that one away if it happens again...
                              • nmsmith89undefined
                                nmsmith89
                                After upgrading (SBC) it looks like neither variables nor RGBW Neopixels work which sucks because I've been dying for both!
                                @nurgelrot said in Software package 3.3beta3 released:
                                I'm in the same boat where the firmware doesn't upgrade. I'm considering just reflashing the SD card but that would be a pain.
                                  droftarts administrators @nmsmith89
                                  @nmsmith89 see my post 2 above to update board.
                                  • Sytac072undefined
                                    @stephen6309 said in Software package 3.3beta3 released:
                                    @paulhew If you are using PrusaSlicer you need to add to the Before layer change G-Code: ;LAYER:[layer_num]
                                    It's under Custom G-Code in Printer Settings.
                                    Hi, I have the same problem using S3D 4.1.2
                                      I've updated the link I sent earlier to include the basic update procedures (uploading via DWC or sending the M997)
                                      • SIamundefined
                                        SIam @pkos
                                        @pkos I have an 3 meter USB3 extension cable killed ๐Ÿ˜ˆ, and now it's working as expected (with 3 Meters)
                                        And I found a small bug in DWC if i have more than one CSV file and click on an entry another entry (not clicked) will be highlighted.
                                        Diamondbackundefined 1 Reply Last reply Reply Quote 2
                                        • Diamondbackundefined
                                          Diamondback @SIam
                                          @siam Interesting, can you post some more detail? I'm about to mess up an ethernet extension cable, but USB might be better for me since the connector is smaller...
                                          • SIamundefined
                                            SIam @Diamondback
                                            @diamondback i use this cable https://www.amazon.de/gp/product/B08BJSK567/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 I cut of the plugs and I crimped it to dupont connectors thats all
                                            Diamondbackundefined 2 Replies Last reply Reply Quote 0
