    Software package 3.3beta3 released
    Beta Firmware
    34
    96
    11.0k
    • Nurgelrotundefined
      Nurgelrot @Phaedrux
      @phaedrux Well that was a major PITA but they are now in sync again. Had to tear my lab apart and move crap all over the place. If I had wanted to make direct connections to the printer board I would have used the Wifi version of the card. But I got there in the end. Any thoughts on why this happened? Not looking forward to that next time I update.
        droftarts administrators @Nurgelrot
        @nurgelrot I think by ‘directly’ @Phaedrux didn’t mean by USB; you should have been able to send M997 S0 (the matching firmware should have downloaded with DSF), or uploaded the firmware file in DWC, and it would ask if you want to update it. I’ve done this a lot recently, when testing firmware.
        Nurgelrotundefined 1 Reply Last reply Reply Quote 0
          Nurgelrot @droftarts
          @droftarts Well sadly I'm not a walking encyclopedia of gcode... But I'll file that one away if it happens again...
          • nmsmith89undefined
            nmsmith89
            After upgrading (SBC) it looks like neither variables nor RGBW Neopixels work which sucks because I've been dying for both!
            @nurgelrot said in Software package 3.3beta3 released:
            So everything but the board is upgraded what did I miss?
            the right package is installed on the PI:
            ii reprapfirmware 3.3-b3-1 all RepRapFirmware Software Bundle
            Rebooting nothing working.
            I'm in the same boat where the firmware doesn't upgrade. I'm considering just reflashing the SD card but that would be a pain.
              droftarts administrators @nmsmith89
              @nmsmith89 see my post 2 above to update board.
              • Sytac072undefined
                Sytac072 @Stephen6309
                @stephen6309 said in Software package 3.3beta3 released:
                @paulhew If you are using PrusaSlicer you need to add to the Before layer change G-Code: ;LAYER:[layer_num]
                It's under Custom G-Code in Printer Settings.
                Hi, I have the same problem using S3D 4.1.2
                  Phaedrux Moderator @Nurgelrot
                  I've updated the link I sent earlier to include the basic update procedures (uploading via DWC or sending the M997)
                  • SIamundefined
                    SIam @pkos
                    @pkos I have an 3 meter USB3 extension cable killed 😈, and now it's working as expected (with 3 Meters)
                    And I found a small bug in DWC if i have more than one CSV file and click on an entry another entry (not clicked) will be highlighted.
                    Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                    Duet WiFi 1.02 or later + DueX5
                    RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                    Duet WiFi Server: 1.26
                    Duet Web Control 3.4.0beta4 (2021-09-27)
                    Diamondbackundefined 1 Reply Last reply Reply Quote 2
                    • Diamondbackundefined
                      Diamondback @SIam
                      @siam Interesting, can you post some more detail? I'm about to mess up an ethernet extension cable, but USB might be better for me since the connector is smaller...
                      SIamundefined 1 Reply Last reply Reply Quote 0
                      • SIamundefined
                        SIam @Diamondback
                        @diamondback i use this cable https://www.amazon.de/gp/product/B08BJSK567/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 I cut of the plugs and I crimped it to dupont connectors thats all
                        Diamondbackundefined 2 Replies Last reply Reply Quote 0
                          Diamondback @SIam
                          @siam Any specific pins for specific functions? Or just randomly took what was there?
                          • SIamundefined
                            SIam @Diamondback
                            @diamondback USB_3.0_Kabel_und_Stecker.png (picture was stolen at wikipedia 😉
                            Red = 3.3V
                            Black = GND
                            Blue = SDA => MOSI
                            Yellow = SDO => MISO
                            Green = CS =>CS3
                            Orange = INT => CS4
                            Violet = SCL => SCK
                            White = NC
                            • TheBasedDogeundefined
                              TheBasedDoge
                              I see that Duet 2 can now do neopixel LEDs, which is super cool, but how do I wire them up and configure? Which pins should I use?
                                Phaedrux Moderator @TheBasedDoge
                                @thebaseddoge said in Software package 3.3beta3 released:
                                https://duet3d.dozuki.com/Wiki/Neopixel_and_DotStar_LEDs
                                TheBasedDogeundefined A Former User? 2 Replies Last reply Reply Quote 0
                                  TheBasedDoge @Phaedrux
                                  @phaedrux I saw that but it seems to only be for Duet 3 right? Duet 2 has no NP_LED pins
                                  Phaedruxundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                    @thebaseddoge Correct. Duet2 lacks the hardware.
                                    Duet 3 MB6HC supports both DotStar and NeoPixel LED strips. Duet 3 Mini supports NeoPixel only. Duet 2 and Duet Maestro do not support these LED strips directly, but you can use an Arduino to interface them to a Duet.
                                    TheBasedDogeundefined 1 Reply Last reply Reply Quote 0
                                      @phaedrux Right, but this line in the 3.3beta3 changelog implies that Duet 2 can now do it. That is where my confusion comes from.
                                      Bit-banged NeoPixel LED strips are supported on Duet WiFi/Ethernet. On these boards RRF will wait stop movement while updating the LED strip, so M150 commands should not be issued while the machine is printing, other than at places where a short pause is acceptable such as at layer change and in the start and end scripts.
                                        droftarts administrators @TheBasedDoge
                                        @thebaseddoge I think a pin has been enabled for controlling the Neopixels on 12864 displays. But I don’t know if it works outside this use case. Will need some @dc42 guidance.
                                        TheBasedDogeundefined 1 Reply Last reply Reply Quote 1
                                          TheBasedDoge @droftarts
                                          @droftarts I didn't think the Duet 2 Wifi supported the 12864 either, only the Maestro? Hopefully dc42 can clarify everything.
                                          thanks.
                                          • Print3dundefined
                                            Print3d @dc42
                                            @dc42 I upgraded and noticed user variables in SBC mode are not showing up. I know integration was pulled in b2 and a fix was in the works for 3.3b3... Is this is a bug or have plans changed for user variable integration in SBC mode?
