    Duet 2 Mosfet switch off ringing
    1.2k
    • jens55undefined
      jens55 @alankilian
      Did you calibrate your probe (adjust probe capacitance) before you started your experimentation? Did you use a proper 10X probe or a straight wire hooked to your measuring point? If properly adjusted, the second trace should show a much cleaner signal.
      Besides that, switching an inductive load will always result in some ringing and can be reduced with a flyback diode as alankilian mentions but short of some major circuit design effort you will not get rid of the ringing.
      Also, the hotend is not purely resistive .... it is a wire wound element so it experiences some (very small) inductive effects.
      Peter_Oundefined 1 Reply Last reply Reply Quote 0
      • Peter_Oundefined
        Peter_O @alankilian
        @alankilian said in Duet 2 Mosfet switch off ringing:
        @peter_o What signal is your probe connected to?
        Do you have a "flyback" diode connected across the fan?
        Hi Alan, thanks for your feedback and questions.
        The probe is connected to the print head connectors with about 1m cable length to the board and 10cm to the fan.
        I had connected a flyback diode several times with a desk lab setup and never saw a real difference. Te be sure, I've just connected a flyback diode to the print head connector. Here's the screenshot:
        • Peter_Oundefined
          Peter_O @jens55
          @jens55 said in Duet 2 Mosfet switch off ringing:
          Hi Jens,
          thank you for your feedback and questions.
          I'm using a diffential probe in 10x-mode.
          Here is the same probe with same probe connectors, connected to a function generator providing a comparable 10V 50% duty cycle square puls:
          Timebase is 50ns/div in zoom window, so the probe seems to be sufficient for the job above.
          I somehow was expecting this kind of answer, but was not shure due to lack of electronics experience.
          I played with an external mosfet module on the desk some time ago. That module had an optocoupler between control and power circuit, and it works much cleaner.
          But it would be difficult to change the gate side of the mosfet on a 3d printing main board.
          That would explain the sine ripple with the heater switch off, maybe together with the 1m wire from board to heater.
          I wonder if this ringing would be present at all 3d printers, if I should just get used to it, or if there is anything in addition that might be considered.
          Is it a good idea to add a capacitor to the fan like 100µF or 1000µF, or is there a risk that the initial current overloads the mosfet?
          • jens55undefined
            jens55 @Peter_O
            @peter_o, just to clarify, when the mosfet output goes low, the fan is switched on and when it goes high the fan switches off.
            I am not sure what you are referring to when you say 'sine ripple with the heater off'.
            If I was in your situation and super curious, I would hook up a different fan and look at the signal again. Chances are you will see something pretty similar. Beyond that I would forget about it.
            Re caps on the fan outputs ... that's a good way to blow the mosfet(s)
            • Peter_Oundefined
              Peter_O @jens55
              Thanks for clarification. The probe is connected across the fan, So it's "fan off", not "mosfet off". I will correct that above.
              2nd screenshot in the first post
              I already did with my desk test setup. Different blower, premium sunon fans, 120mm PC case fan, all the same.
              Ok. Then I will move ahead and leave this topic as it is: Some common noise from 3d printers. 🙂
              Thanks for corfirming that thougth.
              (I've already killed one of the fan mosfets of the duet 2 with a simple short some month ago. Better fix that one first. 🙂 )
              dc42undefined jens55undefined 2 Replies Last reply Reply Quote 0
                dc42 administrators @Peter_O
                @peter_o, please can you post a trace using a single x10 probe connected to the negative fan wire, with oscilloscope ground connected to Duet ground. I will find that easier to interpret.
                Peter_Oundefined 1 Reply Last reply Reply Quote 1
                • jens55undefined
                  jens55 @Peter_O
                  @peter_o said in Duet 2 Mosfet switch off ringing:
                  You talked 'differential' mode earlier and here you are talking single probe. If you connected the scope ground lead to one side of the fan, unless your scope is running on battery power and not connected to AC or grounded any other way, you can cause all manor of havoc.
                  As dc42 suggests, the proper way of doing the measurement is referenced against the Duet ground.
                  Also since the Duet switches the ground line, that introduces some unexpected things in your measurements and you really need to be aware of what is happening.
                  • zaptaundefined
                    zapta @Peter_O
                    @peter_o Most fans have electronics inside and are not specified for intermittent power supply such as PWM.
                    You may find this thread interesting https://forum.duet3d.com/topic/21680/designing-a-pwm-to-analog-mini-board-for-fans
                    • Peter_Oundefined
                      Peter_O @dc42
                      @dc42 said in Duet 2 Mosfet switch off ringing:
                      @dc42, here as requested: Standard probe x10, ground connected to "always on fan GND" and probe to PWM fan 2 "-" in question.
                      The pattern is changing from pulse to pulse, I've shot two different ones:
                      • Peter_Oundefined
                        Peter_O @jens55
                        Yes, thanks for giving the warning. I've learned that from Daves Eevblog videos.
                        Sorry, that I didn't write this clear enough:
                        I used a diffentical probe with resistor chains and amplifier. (Micsig DP 10007)
                        See last post. That is now standard x10 probe.
                        N-type mosfets, yes. That was the reason for me to use a "real" differential probe except for the last two shots. Sorry for not clarifying this enough.
                          @peter_o, thanks. It looks to me that your fan has no input capacitor at all and doesn't like PWM. It may look better if you connect a 0.1uF capacitor in parallel with the fan.
                          • Peter_Oundefined
                            Peter_O @dc42
                            Yes it's one of these cheap 50mm blowers often used in chinese style 3d printers.
                            (Sometimes I write for the german hobbyists 3d print forum, e.g. [https://drucktipps3d.de/duet-2-erste-eindruecke/]. That's the main reason, why I'm nerding into things like this, to gain a better understanding. The forum community is using low cost components. It's not that easy to convince them to use higher quality components like premium fans or duet boards. 😉 )
                            I've added a 100nF and now it looks like this, again with a changing pattern:
                            • Peter_Oundefined
                              Peter_O @Peter_O
                              I'll try some different capacitor values on my cheap lab setup to avoid overloading the duet's mosfet and will come back with the best result.
                              Thx so far, dc42 and all for spending the time!
                              jens55undefined dc42undefined 2 Replies Last reply Reply Quote 0
                              • jens55undefined
                                jens55 @Peter_O
                                Amazing difference for 100 nF !
                                  Don't make it too large, or you will increase power dissipation in the mosfet.
                                  • Peter_Oundefined
                                    Peter_O @dc42
                                    For convenience I used an arduino setup with an IRF3708 mosfet in my "lab2".
                                    Measurement with the differential probe over the fan.
                                    First the same blower as above with 0.1µF again.
                                    It's a different mosfet, but the pattern ist exactly the same. Changing bewtween patterns:
                                    Same setup with 0.47µF
                                    Quite some switching time. I understand your warning, @dc42.
                                    A Sunon Maglev 40mm fan without capacitor is not behaving better.
                                    Sunon Maglev with 0.1µF
                                    Sunon Maglev with 0.47µF
                                    My conclusion: A more premium fan shows the same problem.
                                    And a capacitor can improve the situation, but seems not to solve it completely.
                                    Thanks for the tip, @dc42!
                                    If there are no other ideas, I will leave it with that for now and do some experiments on breadboards with an optocoupler in front of the gate to have 12V avaiable for the gate. Of course this would be no solution for a given 3D printer board.
                                    • alankilianundefined
                                      alankilian @Peter_O
                                      What kind of signal are you expecting to see with a differential probe over the fan when the MOSFET turns off?
                                      The fan will be as we say "Hanging in the breeze" with a connection to VPOWER+ on one end and the other end will have no connection anywhere so the fan coils will be able to boing all over the place if they want to. That doesn't mean the fan is going to turn on and off at all, just that the flying-free voltage on this disconnected fan is boinging around a lot.
                                      What do you want to see under these conditions?
                                      • Peter_Oundefined
                                        Peter_O @alankilian
                                        @alankilian
                                        Ok. I see. That's a strong argument indeed. Thx.
                                        The argument should be the same, when measuring the "Fan -" Pin vs. GND with a standard probe and high impedance oscilloscope setting.
                                        On the other hand I remember, that these effects vanished, when I used a cheap external mosfet board with optocouplers. Have to go back and check and look into that schematics.
                                        I will fiddle around some time the next days and take your argument into account. Maybe I gain some more understanding. The electronics beginner I am. 🙂
                                        • zaptaundefined
                                          zapta @Peter_O
                                          Are you sure that that board had an open drain configuration with no additional components attached to the mosfet's Drain pin? Having additional components such as the resistor/diode in the diagram below may suppress voltage changes by the fan when the mosfet is off.
                                          • Peter_Oundefined
                                            Peter_O @zapta
                                            @zapta
                                            Quite sure. The schematics of the Duet 2 seem to be basic:
                                            https://github.com/Duet3D/Duet-2-Hardware/blob/master/Duet2/Duet2v1.04/Duet2_1.04c_Schematic.pdf
                                            No gate driver as in your example.
                                            @alankilian
                                            Alan, in addition to my last post I think we can see cases within my screenshots, where the inductance effects of the motor are high enough to trigger the gate again and swith the mosfet on for some time. That would be a little more than just flapping around.
