    Input Shapers: 2HUMP_EI & 3HUMP_EI + Auto Tuning
    Firmware wishlist
    20
    64
    10.9k
      dc42 administrators @appjaws
      @appjaws, the diagram posted by @sebkritikel is valid if you don't have a daughter board already plugged into the connector.
      If you do have a single daughter board plugged in to it, then on the top of the daughterboard CS3 and CS4 are shifted 3 pins to the left in the above diagram. CS1 and CS2 are not available because the daughter board uses them.
      CCS86undefined 1 Reply Last reply Reply Quote 2
      • CCS86undefined
        CCS86 @dc42
        Accelerometer has arrived.
        Man, this component is close to the mounting screw! Might have to grind down the head.
        Have a nice mount for my carriage designed and ready to print:
        @dc42 What are the odds input shaping makes it to the Maestro?
          dc42 administrators @CCS86
          @ccs86 said in Input Shapers: 2HUMP_EI & 3HUMP_EI + Auto Tuning:
          Not good, because the Maestro does not have hardware floating point.
          CCS86undefined 1 Reply Last reply Reply Quote 0
          • CCS86undefined
            CCS86 @dc42
            @dc42 said in Input Shapers: 2HUMP_EI & 3HUMP_EI + Auto Tuning:
            That is super disappointing to hear. I was under the impression that it did: https://duet3d.dozuki.com/Wiki/Comparison_of_Duets_vs._other_32-bit_controller_boards
            • zaptaundefined
              zapta @CCS86
              @ccs86, notice the difference in the link you posted between Maestro and Duet2, one is M4 and one is M4F.
              https://en.wikipedia.org/wiki/ARM_Cortex-M#Cortex-M4 .
              Sometimes the fine prints make a big difference. 😉
              CCS86undefined 1 Reply Last reply Reply Quote 1
              • CCS86undefined
                CCS86 @zapta
                @zapta said in Input Shapers: 2HUMP_EI & 3HUMP_EI + Auto Tuning:
                I was talking about this:
                This reads to me as the Maestro having floating point hardware. So, when one of the most anticipated firmware features isn't likely to be supported on the Maestro because of a "lack of floating point hardware", it seems reasonable to be confused/disappointed.
                zaptaundefined dc42undefined 2 Replies Last reply Reply Quote 0
                • zaptaundefined
                  zapta @CCS86
                  Good point. It is represented to have hardware FP similar to the Duet2 which is expected to support input shaping. Same goes for RAM size and CPU speed.
                    @ccs86 that entry in that table is incorrect.
                    Edit: I have corrected it.
                    • garyd9undefined
                      garyd9
                      It's interesting that the table shown above differentiates between the Cortex M4 and M4F, but then doesn't use the "F" suffix on the processor for the Duet3 6HC. That might lead a person to believe that the chip used on the Duet3 does NOT contain the optional FPU.
                      • Nuramoriundefined
                        Nuramori
                        I received from Filastruder an email about great new products from Duet, including a new toolboard, version 1.01 that "is now shipping with a built in accelerometer."
                        I really hope that purchase I just made 2 minutes ago isn't any more a mistake as the sammy-c21 and LIS3DH I bought the week before 😛
                        • CCS86undefined
                          CCS86 @dc42
                          @dc42 That makes a lot more sense. Would you mind shooting me a PM?
                          • Norderundefined Norder referenced this topic
