    Input Shapers: 2HUMP_EI & 3HUMP_EI + Auto Tuning
    Firmware wishlist
    20
    64
    11.3k
    • Adrian52undefined
      Adrian52 @appjaws
      @appjaws for the connection via the daughterboard see:
      https://forum.duet3d.com/topic/22904/duet-2-wifi-accelerometer-connection/1
      • appjawsundefined
        appjaws
        Thanks for the help.
        I am totally confused....(not hard)
        from the Wiki*****
        Two further signals must be connected on the accelerometer breakout board: SPI CS, and INT1. The INT1 pin must be connected to a Duet pin with interrupt capability. This is what we suggest:
        On Duet WiFi, Duet Ethernet and Duet Maestro all the SPI CS pins have interrupt capability, so you can use any two spare CS pins on the daughter board connector. For example, on a Duet WiFi or Duet Ethernet you could connect the accelerometer CS pin to SPI.CS3, and the INT1 pin to SPI.CS4. Then use this command to tell RRF about it:
        M955 P0 C"spi.cs3+spi.cs4"
        I can not see any markings on my daughter board for SPI.CS3 or CS4
        from the Wiki*****
        To use a direct connection, connect the accelerometer MOSI (also called SDI), MISO (also called SDO), SCLK and GND pins to the corresponding pins on the SPI daughter board connector. You can also pick up +3.3V on the daughter board connector to feed to the Vcc pin of the accelerometer.
        On the accelerometer the markings are:
        I2,A3,A2,A1,SDO,CS
        Vin, GND,SCL, SDA INT
        So would SDI actually be SDA?
        Would SCLK actually be SCL?
        Where are the corresponding SCLK, GND, Vcc SDI,SDO, SPI.CS3, SPI.CS4 on the daughter board?
        I already have a PT100 connected to RTD1 on the daughter board
        appjaws - Core XYUV Duet Ethernet Duex5
        firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
        Ormerod 1-converted to laser engraver, Duet wifi
        OpenSCAD version 2024.03.18
        Simplify3D 5.1.2
        sebkritikelundefined 1 Reply Last reply Reply Quote 0
        • sebkritikelundefined
          sebkritikel @appjaws
          @appjaws Here is my wiring diagram I used when connecting to the daughter board header on the Duet2 - see important notes below about actually connecting to the daughter board itself.
          For the daughter board, I think the two key notes are
          You would have needed to use spi.cs3 or spi.cs4(because spi.cs1 and spi.cs2 are used by the daughter board. Those pins are routed to the top of the daughter board on different pins (the pins that would be spi.cs1 and spi.cs2 respectively if those were routed straight through).
          and
          So when connecting via the daughterboard, I should connect cs to pin position 3, and int1 to pin position 1, to pick up cs3 and cs4?
          Using M955 P0 C"spi.cs3+spi.cs4"
          Large(ish?) IDEX - 6HC, 1HCL
          Stratasys Dimension 1200es to 6HC Conversion
          appjawsundefined 1 Reply Last reply Reply Quote 0
          • appjawsundefined
            appjaws @sebkritikel
            @sebkritikel perfect, thanks, I'll crack on in the morning.
            Simplify3D 5.1.2
              dc42 administrators @appjaws
              @appjaws, the diagram posted by @sebkritikel is valid if you don't have a daughter board already plugged into the connector.
              If you do have a single daughter board plugged in to it, then on the top of the daughterboard CS3 and CS4 are shifted 3 pins to the left in the above diagram. CS1 and CS2 are not available because the daughter board uses them.
              CCS86undefined 1 Reply Last reply Reply Quote 2
              • CCS86undefined
                CCS86 @dc42
                Accelerometer has arrived.
                Man, this component is close to the mounting screw! Might have to grind down the head.
                Have a nice mount for my carriage designed and ready to print:
                @dc42 What are the odds input shaping makes it to the Maestro?
                  dc42 administrators @CCS86
                  @ccs86 said in Input Shapers: 2HUMP_EI & 3HUMP_EI + Auto Tuning:
                  Not good, because the Maestro does not have hardware floating point.
                  CCS86undefined 1 Reply Last reply Reply Quote 0
                  • CCS86undefined
                    CCS86 @dc42
                    @dc42 said in Input Shapers: 2HUMP_EI & 3HUMP_EI + Auto Tuning:
                    That is super disappointing to hear. I was under the impression that it did: https://duet3d.dozuki.com/Wiki/Comparison_of_Duets_vs._other_32-bit_controller_boards
                    • zaptaundefined
                      zapta @CCS86
                      @ccs86, notice the difference in the link you posted between Maestro and Duet2, one is M4 and one is M4F.
                      https://en.wikipedia.org/wiki/ARM_Cortex-M#Cortex-M4 .
                      Sometimes the fine prints make a big difference. 😉
                      CCS86undefined 1 Reply Last reply Reply Quote 1
                      • CCS86undefined
                        CCS86 @zapta
                        @zapta said in Input Shapers: 2HUMP_EI & 3HUMP_EI + Auto Tuning:
                        I was talking about this:
                        This reads to me as the Maestro having floating point hardware. So, when one of the most anticipated firmware features isn't likely to be supported on the Maestro because of a "lack of floating point hardware", it seems reasonable to be confused/disappointed.
                        zaptaundefined dc42undefined 2 Replies Last reply Reply Quote 0
                        • zaptaundefined
                          zapta @CCS86
                          Good point. It is represented to have hardware FP similar to the Duet2 which is expected to support input shaping. Same goes for RAM size and CPU speed.
                            @ccs86 that entry in that table is incorrect.
                            Edit: I have corrected it.
                            • garyd9undefined
                              garyd9
                              It's interesting that the table shown above differentiates between the Cortex M4 and M4F, but then doesn't use the "F" suffix on the processor for the Duet3 6HC. That might lead a person to believe that the chip used on the Duet3 does NOT contain the optional FPU.
                              • Nuramoriundefined
                                Nuramori
                                I received from Filastruder an email about great new products from Duet, including a new toolboard, version 1.01 that "is now shipping with a built in accelerometer."
                                I really hope that purchase I just made 2 minutes ago isn't any more a mistake as the sammy-c21 and LIS3DH I bought the week before 😛
                                • CCS86undefined
                                  CCS86 @dc42
                                  @dc42 That makes a lot more sense. Would you mind shooting me a PM?
                                  • Norderundefined Norder referenced this topic
