    Toolboard 1.01 has a built-in accelerometer?!
    908
    • Nuramoriundefined
      Nuramori @T3P3Tony
      @t3p3tony have I recently said I both love and hate you guys? ๐Ÿ˜›
      I kind of wish I knew - I literally bought the Sammy-c21 and LIS3DH last week. Lol.
      Oh well. Iโ€™ll find a use. Order placed, and excited to see I made a good guess a few weeks ago!
        T3P3Tony administrators @Nuramori
        @nuramori just have add more machines to use all the tools! ๐Ÿ˜‰
        Nuramoriundefined 2 Replies Last reply Reply Quote 1
        • Nuramoriundefined
          Nuramori @T3P3Tony
          @t3p3tony it's like you know me!
          • Nuramoriundefined
            Nuramori @T3P3Tony
            @t3p3tony
            Ok after zooming in, I either have a question (or two) or a critique.
            On the adafruit LIS3DH they have a graphic icon that indicates the accelerometer orientation, so for the purposes of setting the parameter to report itโ€™s Cartesian orientation, itโ€™s easy. On the new toolboard I donโ€™t see any similar graphic, so I would ask what is the assumed x/y/z position so I can properly set the parameter?
            Second question would be, if the accelerometer is now on the toolboard, what would the โ€œpโ€ parameter look like if say the toolboard can address is โ€œ20?โ€
            T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
              @nuramori yes that graphic is planned for the next silkscreen, I had it on my list already. In the meantime I will update the documentation. To show the orientation of the IC relative to the board
              • Dougal1957undefined
                Dougal1957
                Tony
                Not sure if this may be possible or not but in theory could the accelerometer also be able to be used as a Z-Probe?
                Doug
                • botundefined
                  bot
                  Pardon my ignorance, I've been busy and out of the loop for a while so I've missed the details of the accelerometer action going on lately.
                  What kind of wiring/cabling is needed to put an accelerometer on an extruder temporarily to acquire data? Could some fan wiring be temporarily repurposed?
                  Is the accelerometer meant to be permanently on board? I assumed it was only needed for tuning.
                  *not actually a robot
                  matt3oundefined 1 Reply Last reply Reply Quote 0
                  • matt3oundefined
                    matt3o @bot
                    @bot https://duet3d.dozuki.com/Wiki/Accelerometers
                    the accelerometer doesn't need to be fixed on the head, you can put it on only when calibrating (and every time you change something that can vary the machine kinetics)
                      dc42 administrators @Dougal1957
                      @dougal1957 said in Toolboard 1.01 has a built-in accelerometer?!:
                      Tony
                      Doug
                      Maybe, but we don't support that yet.
                        A Former User @Nuramori
                        @nuramori
                        https://forum.duet3d.com/topic/22992/announcement-duet-3-toolboard-revision-v1-1/6
                        Nuramoriundefined 1 Reply Last reply Reply Quote 0
                          Dougal1957 @dc42
                          @dc42 said in Toolboard 1.01 has a built-in accelerometer?!:
                          Tony
                          Doug
                          Yeah I realise it isn't supported as of now my query was more a case of is it possible and if so do you intend to look at it at some point down the line and I think you have answered so thanks.
                          Doug
                            @nuramori I realise I missed the rest of the question. The second part, of how you address it on a tool board:
                            https://duet3d.dozuki.com/Wiki/Gcode#Section_M955_Configure_Accelerometer
                            The P parameter selects which accelerometer to use and is mandatory. To use an accelerometer on a CAN-connected expansion board, use the form P''board-address.device-number'' for example P22.0
                            So if the toolboard address was 20 it would be
                            M955 P20.0
                            The documentation is now updated with the orientation information:
                            https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board?#Section_Accelerometer
                            • Nuramoriundefined
                              Nuramori @A Former User
                              @lbi yeah, I posted this before that was even up, as Filastruder jumped the gun, or were quicker on the draw than even Tony to get it on the internet ๐Ÿ™‚
