    Toolboard 1.01 has a built-in accelerometer?!
    908
    • Nuramoriundefined
      Nuramori @T3P3Tony
      @t3p3tony it's like you know me!
      • Nuramoriundefined
        Nuramori @T3P3Tony
        @t3p3tony
        Ok after zooming in, I either have a question (or two) or a critique.
        On the adafruit LIS3DH they have a graphic icon that indicates the accelerometer orientation, so for the purposes of setting the parameter to report it’s Cartesian orientation, it’s easy. On the new toolboard I don’t see any similar graphic, so I would ask what is the assumed x/y/z position so I can properly set the parameter?
        Second question would be, if the accelerometer is now on the toolboard, what would the “p” parameter look like if say the toolboard can address is “20?”
        T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
          T3P3Tony administrators @Nuramori
          @nuramori yes that graphic is planned for the next silkscreen, I had it on my list already. In the meantime I will update the documentation. To show the orientation of the IC relative to the board
          • Dougal1957undefined
            Dougal1957
            Tony
            Not sure if this may be possible or not but in theory could the accelerometer also be able to be used as a Z-Probe?
            Doug
            • botundefined
              bot
              Pardon my ignorance, I've been busy and out of the loop for a while so I've missed the details of the accelerometer action going on lately.
              What kind of wiring/cabling is needed to put an accelerometer on an extruder temporarily to acquire data? Could some fan wiring be temporarily repurposed?
              Is the accelerometer meant to be permanently on board? I assumed it was only needed for tuning.
              *not actually a robot
              matt3oundefined 1 Reply Last reply Reply Quote 0
              • matt3oundefined
                matt3o @bot
                @bot https://duet3d.dozuki.com/Wiki/Accelerometers
                the accelerometer doesn't need to be fixed on the head, you can put it on only when calibrating (and every time you change something that can vary the machine kinetics)
                  dc42 administrators @Dougal1957
                  @dougal1957 said in Toolboard 1.01 has a built-in accelerometer?!:
                  Tony
                  Doug
                  Maybe, but we don't support that yet.
                    A Former User @Nuramori
                    @nuramori
                    https://forum.duet3d.com/topic/22992/announcement-duet-3-toolboard-revision-v1-1/6
                    Nuramoriundefined 1 Reply Last reply Reply Quote 0
                      Dougal1957 @dc42
                      @dc42 said in Toolboard 1.01 has a built-in accelerometer?!:
                      Tony
                      Doug
                      Yeah I realise it isn't supported as of now my query was more a case of is it possible and if so do you intend to look at it at some point down the line and I think you have answered so thanks.
                      Doug
                        @nuramori I realise I missed the rest of the question. The second part, of how you address it on a tool board:
                        https://duet3d.dozuki.com/Wiki/Gcode#Section_M955_Configure_Accelerometer
                        The P parameter selects which accelerometer to use and is mandatory. To use an accelerometer on a CAN-connected expansion board, use the form P''board-address.device-number'' for example P22.0
                        So if the toolboard address was 20 it would be
                        M955 P20.0
                        The documentation is now updated with the orientation information:
                        https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board?#Section_Accelerometer
                        • Nuramoriundefined
                          Nuramori @A Former User
                          @lbi yeah, I posted this before that was even up, as Filastruder jumped the gun, or were quicker on the draw than even Tony to get it on the internet 🙂
