    [RRF3.3b2] Possibly incorrect behavior when homing Z
    Beta Firmware
    1.0k
    • pkosundefined
      pkos @OwenD
      @owend
      Just to be clear.
      You take the gantry to 100.
      You turn the printer off completely.
      You turn the printer on and Home z - and then it also just raises a tiny bit even though the first probe needed a drop fo 100?
      The switched off printer is the key here. If it's already homed, the problem does not exist.
      This is a problem for me, since I often have prints running and the printer shuts itself off completely after it cools down.
      So then, when I want to print again, the gantry is often quite high and it takes a long time to get it to home again.
      Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron Trident (Duet 3 mini 5+ standalone), Voron 0.1
      fulgundefined OwenDundefined 2 Replies Last reply Reply Quote 0
      • fulgundefined
        fulg @pkos
        @pkos My printer is down at the moment but as far as I remember this works for me? Granted I did not run 3.3b2 for long, but the first trigger of the probe should establish Z=0 (you should see the "Home Z" button turn blue in DWC as soon as the probe is triggered), then the gantry rises by the dive height and the 2nd probe occurs...
        VORON V2 CoreXY + Duet3 Mini5+ Ethernet v1.0 with Mini2+ expansion, VORON V0 CoreXY + Duet2 Maestro
        pkosundefined 1 Reply Last reply Reply Quote 0
        • pkosundefined
          pkos @fulg
          They say a picture tells a thousand words.
          This is what I see.
          https://www.youtube.com/watch?v=0EZ7CqDl-Io
          The key to make this happen is set double speeds for probing.
          So in my case it's F350:60
          fulgundefined 1 Reply Last reply Reply Quote 0
          • fulgundefined
            fulg @pkos
            @pkos Ok, I can reproduce this here on my VORON Zero if I replace the Z endstop with a Z probe connected to the same spot (so I can use G30 Z-99999 in my homing sequence instead of G1 H1 Z-125).
            When using a single probing speed, Z=0 is established on the first probe, so the move to the dive height is small.
            When using dual probing speeds, Z=0 is not established until after the second probe, so the move to the dive height is "power up position + dive height".
            • OwenDundefined
              OwenD @pkos
              @pkos said in [RRF3.3b2] Possibly incorrect behavior when homing Z:
              @owend
              Just to be clear.
              You could be right. I didn't turn the printer off.
              • pkosundefined
                pkos @Phaedrux
                @phaedrux Just checking in - is this possibly something that can be checked seeing as how others are now confirming the issue?
                  Yes I've asked @DC42 to comment when he gets a chance.
                  • pkosundefined
                    pkos @Phaedrux
                    @phaedrux FYI - checked with 3.3b3 - behavior still there.
                    • sebkritikelundefined
                      sebkritikel
                      I can verify this behavior as well
                      Duet2 Wifi +Duex5
                      Duet Web Control 3.3.0-b3
                      RepRapFirmware for Duet 2 WiFi/Ethernet 3.3beta3 (2021-04-22)
                      Large(ish?) IDEX - 6HC, 1HCL
                      Stratasys Dimension 1200es to 6HC Conversion
                        dc42 administrators @sebkritikel
                        I've tried and failed to reproduce this behaviour. However, I have found a bug:
                        • If I set M558 F1000:300 A1 (or I don't specify the A parameter in the original M558 command), then homing Z using G30 probes just once and then reports "Homing failed".
                        • If I set M558 F1000:300 A2, then homing Z works. It probes once at the fast speed, moves up to the dive height (even if I started at a much greater height with Z not homed), then probes twice at the slow speed.
                        My G30 command to home Z has no parameters.
                        @pkps and @fulg, does the issue still occur if you remove the Z-99999 parameter from the G30 command?
                        @pkos and @sebkritikel, what A parameter are you using?
                        pkosundefined sebkritikelundefined 2 Replies Last reply Reply Quote 0
                        • pkosundefined
                          pkos @dc42
                          @dc42 I am using A10.
                          Just in case, my config is at the top.
                          I am not sure if you need the whole config.g or if the things up there are enough.
                            dc42 administrators @pkos
                            @pkos, I just found a way to reproduce the issue you saw:
                            • Send Z to +50
                            • Send G92 Z0
                            • Send M18 Z to flag Z as not homed
                            • Send G30 (after setting M558 A2 to avoid the other bug)
                            I am about to test the fix.
                            • pkosundefined
                              pkos @dc42
                              @dc42 Nice. I saw that M18 would also trigger this, but couldn't always reproduce it (so didn't want to waste your time with it).
                              For the time being, I just removed M18 from my end gcode 😉
                              Awesome you found it.
                                The fix is working and will be in 3.3RC1.
                                pkosundefined 1 Reply Last reply Reply Quote 1
                                • pkosundefined
                                  pkos @dc42
                                  @dc42 Awesome. Can't wait 🙂 Thank you.
                                    sebkritikel @dc42
                                    @dc42 said in [RRF3.3b2] Possibly incorrect behavior when homing Z:
                                    For posterity:
                                    M558 P9 C"^zprobe.in" H5 F1000:200 A8 R0.75 T6000 S.02
